Old 01-09-2012, 07:08 AM   #5386
Billtr96sn
Flange Furtler
Oddometer: 393
Re the Honda shop Manual for XL600 84/85. Honda UK will only supply a photocopied manual and it is in the region of 40.
I have one, it came with the bike and is extremely useful. If I knew how to do PDF's I would make it available.
Billtr96sn is offline   Reply With Quote
Old 01-09-2012, 08:20 AM   #5387
kennythetiger
Kennythetiger
kennythetiger's Avatar
Oddometer: 53
Re: Onderer and Shortlife
I went with trailtech for the DC part and found an MSR AC regulator for $15 at a local shop. It made a huge difference in lighting and startup. I've taken the carbs out a couple of times. It is a pain, but not nearly as bad as my 96 tiger was.
kennythetiger is offline   Reply With Quote
Old 01-11-2012, 06:50 PM   #5388
BRPtourer
Oddometer: 158
Kenny,
Any more info on the MSR AC regulator? Such as part number? Is it a generic unit you wire in, or an application specific for an XL?
BRPtourer is offline   Reply With Quote
Old 01-11-2012, 08:32 PM   #5389
sh0rtlife
Oddometer: 796
the trail tech one is just a tad more at 20$..but as a bonus its got a voltage adjustment pot to turn up or down the voltage as you see fit
sh0rtlife is offline   Reply With Quote
Old 01-12-2012, 04:59 PM   #5390
kennythetiger
Kennythetiger
Oddometer: 53
MSR Regulator
It's just a standard wire in: Here's a link: http://www.motorcycle-superstore.com...Regulator.aspx
Old 01-12-2012, 07:53 PM   #5391
Onederer
Crunch Nugget
Onederer's Avatar
Oddometer: 826
I had mentioned a newer ISD2 Supertrapp for a XR650L would fit the XL600R IF the XL already had the midpipe for the old racing series Trapp, so here are some pics of what it looks like.
Mine has a rack and it was close, but not touching.
The ISD2 and the old Racing Series it replaced.
I staired a whole thru the breaks until I remembered the carb prolly has a problem to.
Onederer is offline   Reply With Quote
Old 01-12-2012, 08:57 PM   #5392
sh0rtlife
Oddometer: 796
so..uh..what did ya do with the poor old trap?....well seems i have the right mid pipe for that setup atleast...which is good to know
Old 01-12-2012, 10:11 PM   #5393
Onederer
Crunch Nugget
Onederer's Avatar
Oddometer: 826
The old one got crunched up and hole poked in it from a crash. I'm not sure what I am going to do with it, I hate to chunk it because I just put that deflector on it ($) but the deflector and most of the disc are bent up. I might pound it back out, weld in the hole and put it on one of my 3 wheelers. I took the IDS2 off of my XR650L and put the stock muffler back on it. I try to keep my bikes looking decent, but my 3 wheeler is gawd awful ugly to start with and gets the snot beat out of it, so anything goes that keeps it going.
Really a wonder why Supertrapp doesn't off offer the IDS2 for the XL600R seeing as they still offer the racing series which has the mid pipe it takes to make the IDS2 for a XR650L work.
Old 01-13-2012, 12:01 AM   #5394
sh0rtlife
Oddometer: 796
hell yeah stick it on the wheeler...sounds like your 3 and my 4 would sit nice and ugly together lol
they probably dont realise that they have a setup for the bike is all it really is
Old 01-13-2012, 12:57 AM   #5395
lookfar
from the land of OZ
Oddometer: 627
Originally Posted by Onederer View Post
How do you find that rear tyre on dirt?
I have the same on my XL, doesn't seem to grip much on dirt, good on the slab, though. Trying to get mine to wear so that I can replace it with something more suitable
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 01-13-2012, 05:12 AM   #5396
brucifer
brucifer's Avatar
Oddometer: 2,460
Off Topic
Onderer, is that a '79 Ford pick-up or Bronco you have there?
I bought a '79 F-100 short bed when I was 21 in 1987 and had it until 2008. I loved that truck. It was my daily driver and drag racer. I installed a functional 428CJ style hood scoop and painted it Rangoon Red, which was an early '60s factory Galaxie color. For an engine, I built a 9:1 compression 460 for it and ran consistant 12:70s in the quarter. It was all kinds of fun. Scared a couple friends in it.
Unfortunately the rust that had been repaired in the mid '90s came back with a vengeance and wasn't worth fixing. Still miss that thing...
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 01-13-2012, 09:51 AM   #5397
sh0rtlife
Oddometer: 796
ive got an even more streety tire on my xl.....so long as the dirt aint wet its not bad..mud.wet grass is like ice..but ice it grips
Old 01-13-2012, 03:50 PM   #5398
kmequint
kmequint's Avatar
Oddometer: 57
Originally Posted by kennythetiger View Post
I picked up and 84 XL600 over the summer. It ran OK, but smoked quite a bit, so I'm doing my first top end and valve job. This forum has been very helpful in diagnosing the issues with the bike. I've put in a ricky stator, and replaced both the AC and DC regulators. Interesting setup and can be run without a battery. After 24k miles the cylinder still looks good and the stock rings were barely worn. I sandblasted and painted the swingarm today. Not sure where it's going, but I'm having a lot of fun with the project. I will put up pics As it starts to come together.
Don't know if you have, make sure you check the wrist pin and connecting rod. I learned this the hard way and had to tear the engine back down to replace them.
kmequint is offline   Reply With Quote
Old 01-13-2012, 04:17 PM   #5399
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
just finished making these bid finned valve cover caps for you XR/XL 600R riders..
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 01-13-2012, 04:23 PM   #5400
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,088
How do you take them off? The stock ones have the nut on the top so you can get a wrench on them.
Carter Pewterschmidt is online now   Reply With Quote
Times are GMT -7.   It's 03:53 PM.
