Old 03-23-2012, 09:12 AM   #5626
bdcorrigan
bdcorrigan's Avatar
Oddometer: 653
Originally Posted by randylahee View Post
check out this valve spring compressor my cheap ass made
Where is the beer can in this picture?
bdcorrigan is offline   Reply With Quote
Old 03-23-2012, 11:01 PM   #5627
Mopowa
Mopowa's Avatar
Oddometer: 202
Carb needles
Been doing some jetting changes lately. Raising needle position and all the other tedious stuff, and now I want to try different needle shapes/sizes. Where do I go to find the needles I need? Will XR carb parts work in our carbs? I don't claim to be a carb expert, but I will stick with it until it's right, so any advice is welcome.
'83 XL600
101mm bore
10.5:1 JE piston
Reed valve blocked off
stock exhaust(wrapped)
Uni air filter(de-snorkled)
Mopowa is offline   Reply With Quote
Old 03-24-2012, 12:41 PM   #5628
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
Originally Posted by Mopowa View Post
XL600
10.5:1 JE piston
Something's not right here....
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 03-24-2012, 08:08 PM   #5629
Mopowa
Mopowa's Avatar
Oddometer: 202
Oh yeah, and it's got Ferrea valves too....
Old 03-24-2012, 08:11 PM   #5630
Mopowa
Mopowa's Avatar
Oddometer: 202
So, HeadTrauma, watcha got in them carbies?
Old 03-24-2012, 09:56 PM   #5631
scrminbanshee
Awsome
scrminbanshee's Avatar
Oddometer: 815
Hey i got a bunch of xl600 parts up for sale i posted them on craigslist heres the link i am willing to ship and willing to sell part out the group. let me know pm if you want
http://seattle.craigslist.org/tac/mcy/2920828070.html
2000 KTM 640 enduro
1997 KTM 620 adventure
scrminbanshee is offline   Reply With Quote
Old 03-24-2012, 11:38 PM   #5632
Watcher
Oddometer: 59
1988+ cam mod for the XL600R update
The valves on the new ( old ) E-bay head were leaking some so that is off to the machine shop. In the meantime I have learned a few things. The Hot Cam in combination with the 1989 cylinder head cover ( from E-bay again ) is just a straight forward bolt it up job. The only things different are the sprocket end camshaft bearing needs to be from a 1988 or later XR or XRL. Also the sprocket needs to be flipped around if keeping the original chain is desired.
I posted a series of these pictures of the cam installed in the old head sans valves over on the Call all XR600R!!! thread. The rockers and lobes seem to line up pretty well. On the two heads that I have the cam is located in the head with the two end dowels, there is between .025" and .030" axial play between the dowels with the Hot Cam. With the stock XL600 cam this play is around .040".
Left side intake
The idea that I prefer because it should cost less and retain the original cylinder head cover ( and manual decompressor ), is to do a slight mod on the Original XL600R to allow use of the later model stock camshafts.
All measurements of the cylinder head covers are the same and there are very only very minor differences in the castings. The only significant exception is where the left side intake rocker shaft area has been machined to allow the use of the larger rocker arm in the 1988+ cover.
1986 cylinder head cover left intake rocker shaft area not machined.
1989 cylinder head cover left intake rocker shaft area machined.
This machined out are allows for the use of different rocker arms on the left side of the 1988+ cylinder head covers. The rockers on the right side are the same configuration as the pre 1988 XL600R rocker arms. Even though I used a Hot Cam ( and 1989 cover ), it is my believe that by machining out this area and changing these two rocker arms (and the small helper arm on the intake rocker ), the stock 1988+ cams could be used with the original XL600 cover.
The two rocker arms that would need to added to the pre 1988 covers. This is from a 1989, I believe that the later years did not have the extra wide exhaust rocker.
The only issue I see with would be plugging the decompressor hole in the stock 88+ camshafts.
1989 intake rocker arm
1986 Intake rocker arm. Subtracting 23.98mm from 29.22mm is the amount of material that needs to be removed in the original cover ( 5.24mm ).
The base measurements of the exhaust rockers were the same at 23.95mm and 23.96mm. Just buy a 1988+ exhaust rocker arm and put it in. The small helper arm is the same, so no change needed on the exhaust side. On the Intake side a 1988+ small helper arm will need to be bought but that to will slip right in to the original XL600 cover.
One interesting note is that if you had a 1989 or later RFVC engine, I don't see why you couldn't take an old XL cover, machine it out, swap rockers and go with a manual decompressor. I don't know if anyone wants to do that but I thought I would mention it.
I know about when the ride begins, I just don't know when it's going to end.
Watcher is offline   Reply With Quote
Old 03-25-2012, 04:24 AM   #5633
Edouard_Bracame
Oddometer: 86
XL 600 Paris-Dakar
Nice one...1500 euros with a revised engine...and + another revised spare engine...
http://www.leboncoin.fr/motos/301481564.htm?ca=1_s
Edouard_Bracame is offline   Reply With Quote
Old 03-25-2012, 07:05 AM   #5634
RA Carter
RD dragbike
Oddometer: 1
XL-600R price
Originally Posted by jkrpan View Post
What would a xl600 cost to buy, if you found a good one?
I just picked-up a nice '84,600R. In Canada it cost me two grand. New it was $2,300! Seems like a lot for a old bike, but the new bikes are beyond my cash flow. Great bike.
RA Carter is offline   Reply With Quote
Old 03-25-2012, 07:12 AM   #5635
georgej
Oddometer: 184
Removing the sparkplug
I'll admit i'm not a great mechanic,and I usually seem to figure things out. But.....what is the trick to getting the sparkplug out?I can get the socket on it but can't fit the ratchet handle onto it.Any tips?
Thanks in advance.
georgej screwed with this post 03-25-2012 at 09:06 AM
georgej is offline   Reply With Quote
Old 03-25-2012, 09:54 AM   #5636
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,798
Use the tool that comes in the tool kit. It works perfect in that spot.
Hate gets you nowhere.
Old 03-25-2012, 10:36 AM   #5637
georgej
Oddometer: 184
I would if I had a tool kit.This is all part of the fun of it right.
Old 03-25-2012, 11:23 AM   #5638
Reposado1800
Juicy J fan!
Oddometer: 5,798
Use an extension, preferably a u joint, to get a little curve to it. Just make sure to reinstall the plug with your fingers to make sure it doesn't cross thread.
Old 03-25-2012, 12:56 PM   #5639
georgej
Oddometer: 184
Yup,that's what did it.The u-joint.All I can say is what a stupid place to put the sparkplug.
Old 03-25-2012, 11:44 PM   #5640
sh0rtlife
Oddometer: 796
the right 18mil socket and a stub extension means no silly joint needed
sh0rtlife is offline   Reply With Quote
Times are GMT -7.   It's 12:49 PM.
