Old 04-18-2012, 07:38 AM   #5686
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
Originally Posted by Chobro View Post
*yes, I did a search and came up with nada...
The bike is an '85.
Is the decompression lever properly adjusted when the shaft is just about to contact with the rocker at TDC? (the shaft that is attached to the mechanism at the right side of the head, it has a little cut away on the end which pushes the rocker/valve down) The book seemed fuzzy on this. Any help appreciated.
Thanks.
You're fine as long as it works when you need it and doesn't contact the rocker when the engine is running. There can actually be a good bit of clearance and it will still work.
1995 XR628R - Lots of goodies...room for more.
1985 Kawasaki GPZ600R - Another project.
HeadTrauma is offline   Reply With Quote
Old 04-18-2012, 07:48 AM   #5687
Chobro
spinning the wheel
Chobro's Avatar
Oddometer: 805
Thumb
I got it close and rotated the engine, the rocker did not come into contact, only when the decomp lever was pulled did it touch. Thanks!
-Chobro
Chobro is online now   Reply With Quote
Old 04-19-2012, 06:19 AM   #5688
BRPtourer
Oddometer: 158
Just going by memory, I recall reading there should be 3 mm slack in the cable at TDC. I took mine off a long time ago. Mine never seemed to work right, maybe I was adjusting it wrong?
Sorry, I thought you were asking about the auto decomp, I should read more carefully. I just adjust my decomp so there is a little slack in the cable with the bars turned both ways.
BRPtourer screwed with this post 04-19-2012 at 05:32 PM
BRPtourer is offline   Reply With Quote
Old 04-19-2012, 08:38 PM   #5689
Chobro
spinning the wheel
Chobro's Avatar
Oddometer: 805
Ah, good point, I'll check it with bars left/right. Thanks.
-Chobro
Old 04-21-2012, 04:01 PM   #5690
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,105
Fork oil type?
I'm looking to stiffen up the front end a touch so I'd like to change out the ATF I put in the forks last year with something a bit thicker. Any recommendations?
Carter Pewterschmidt is offline   Reply With Quote
Old 04-21-2012, 06:08 PM   #5691
BRPtourer
Oddometer: 158
Depending on the ATF you used I believe most is about 7.5 weight. Try 10 or 15 weight fork oil and experiment around with different oil levels, a couple cc either way often makes a noticeable difference.
I haven't messed with the forks on my XL600 in the 2 years I've had it because they seem to work great as is and don't leak, but I have quite a bit on other bikes. Here in the high desert daytime temps can often vary as much as 50 degrees through the day. On my FJ12 I felt the forks were a bit harsh when riding to work at 45-50 deg, then when riding home at 90-95+ deg they were a bit squishy. I found some Bel-Ray 10w30 multi-viscosity fork oil and was very happy with the results.
Old 04-23-2012, 08:33 AM   #5692
bdcorrigan
bdcorrigan's Avatar
Oddometer: 653
We got them all together last night, finally!
bdcorrigan is offline   Reply With Quote
Old 04-23-2012, 05:59 PM   #5693
BRPtourer
Oddometer: 158
Oh Geeez..... When I saw that first pic I thought, is that a KLR with a milk crate on it sitting with them nice bikes? After seeing the 3rd pic I feel better.
Old 04-25-2012, 07:51 AM   #5694
12120
Indenturedx5
12120's Avatar
Oddometer: 487
Cool2 best enduro ever.
Hey, just got my '83 XL600. I have had a few enduros over the years, this one is the king. Sure glad I didn't get the 350 I was looking at. 600 might be heavy, but I am happy to fight the weight on the trails. 65 on the hwy smoothly is a way better deal.
12120 is offline   Reply With Quote
Old 04-26-2012, 06:27 AM   #5695
BRPtourer
Oddometer: 158
weight
Actually, according to most of the tech articles I've read, both the 350 and 600 weigh about the same. Have fun!
Old 05-02-2012, 05:11 AM   #5696
kmequint
kmequint's Avatar
Oddometer: 57
Timing Chain
Has any one replaced there 83 XL600 original "style" timing sprockets and chain with the ones that fit a 90 XR600R. The reason I am asking is that my lower sprocket is in bad shape and it is the only part not available anymore. So that is why I am thinking about going with the newer equipment. I need to also mention is that I have the newer parts sitting on my bench, the only difference that I can tell is that they are not as wide as the original ones. Is that going to cause a problem with the guides and tensioner?
Thanks,
Mark
kmequint screwed with this post 05-02-2012 at 05:18 AM
kmequint is offline   Reply With Quote
Old 05-02-2012, 09:42 PM   #5697
12120
Indenturedx5
12120's Avatar
Oddometer: 487
timing chain
I would think as long as the chain/sprockets are narrower then the guide/tensioner it would not be a problem. Assuming that they center on them. Not really had to fool with them much, so you might wanna get to more info first, but if it all looks good when installed, should be fine. READ the disclaimer
If you find yourself in a fair fight, your tactics are wrong.
'83 XL 600r
Old 05-03-2012, 05:23 AM   #5698
Dessert Storm
Dances With Drunks
Dessert Storm's Avatar
Oddometer: 809
Hmmmmmmmmmm........
A bit spendy though: 105UK/$170US
More info (but not very much) here: http://www.bikermart.co.uk/proddetail.asp?prod=HLUTR
and here: http://www.bikermart.co.uk/proddetai...prod=SCRUDOM01
Pretty soon I knew the tune,
And we sat and sang under the Moon
Dessert Storm is offline   Reply With Quote
Old 05-03-2012, 07:13 AM   #5699
kmequint
kmequint's Avatar
Oddometer: 57
That's kind of what I was thinking, wanted some else to verify.
Old 05-04-2012, 04:11 PM   #5700
jontow
Oddometer: 107
BRP food?
So, had my '85 for a few weeks, title showed up yesterday.. had it registered yesterday afternoon, didn't get a chance to ride it on the slab until this morning. Rode it over to the inspection shop before something quit working and it was running a bit funny on the way there and back. Float height on at least one of the carbs seems wrong, 'cause it feels like I can empty a carb too quick and it gets a bit stumbly after that. Jets probably are a bit gummed up, too. The bike was in storage for a while when I got it.
Anyway, got it home and was going to pull the carbs and all that to give 'em a quick cleaning and check the float height. Started by popping open the air box cover and, well, imagine my surprise. I'll let the image do a bit of the talking:
So, I have a series of questions:
* BRP food?
* Onboard survival kit?
* Doing some badass offroading in a dog food factory?
Guess it was at least a good surprise to find a UNI filter in there behind all the damned kibbles and bits.
jontow is offline   Reply With Quote
Times are GMT -7.   It's 07:53 AM.
