Old 05-31-2012, 11:04 PM   #5746
INTMD8
Oddometer: 124
I was at the local dealer today and wandered over to a new xr650l. Was surprising to see that the engine still appeared to be the same basic architecture as our old XL's nearly 30yrs later.
86 xl600r.
INTMD8 is offline   Reply With Quote
Old 06-02-2012, 10:30 AM   #5747
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
The 650L hasn't changed since '93 and its engine hasn't changed since '89. The kickstart-related parts from an '83 XL600 will actually fit in a 2012 650L.
EDIT: now that I say that, maybe only '85-87 XL parts will fit. The countershaft is involved with a swap and I looked in the manual to find that the XL has a different 1st gear ratio...
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma screwed with this post 06-02-2012 at 10:36 AM
HeadTrauma is offline   Reply With Quote
Old 06-02-2012, 03:31 PM   #5748
BajaDoug
Swabbie
BajaDoug's Avatar
Oddometer: 465
My son just bought a 86 xl600r and we want to know how do you guys check your oil?
BajaDoug is online now   Reply With Quote
Old 06-02-2012, 04:26 PM   #5749
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
Get it up to operating temperature and immediately check the oil level by setting the dipstick on the threads. Keep the bike upright on level ground, not leaning on the stand.
Old 06-02-2012, 09:24 PM   #5750
BRPtourer
Oddometer: 158
Laugh
Originally Posted by HeadTrauma View Post
Get it up to operating temperature, shut it off, and immediately check the oil level by setting the dipstick on the threads. Keep the bike upright on level ground, not leaning on the stand.
Sorry Head, had to add my .02
BRPtourer is offline   Reply With Quote
Old 06-02-2012, 11:43 PM   #5751
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
I meant to put that there, but forgot. Yes, shut the engine off before checking the oil.
Old 06-03-2012, 05:12 PM   #5752
BajaDoug
Swabbie
BajaDoug's Avatar
Oddometer: 465
Thanks guys
Old 06-04-2012, 05:52 PM   #5753
kmequint
kmequint's Avatar
Oddometer: 57
Originally Posted by cynicwanderer View Post
yes, check compression, which will tell you something about the rings/valves. besides that, there is
the usual:
1. worn timing chain (approx $150-175, plus gaskets) - there will be clacking noise coming from the side of
the engine. worn rockers or camshaft will cost more. you have to take the engine out of the frame to get the
valve/rocker cover off.
2. oil pump check valve (relatively cheap) - this is where the oil doesn't want to stay in the frame
3. tires ($50-???/wheel)
4. broke/lose spokes (relatively cheap)
5. front brakes slave/master/hose (relatively cheap if you go after market)
6. all the gears work (lots of effort to fix) - you have to split the case for 90% of the transmission problems.
7. any leaks from the top end/base gasket (cheap but lots of effort) - you have to pull the engine out of the bike to get the valve/rocker cover off, even for the little o-ring on the cam chain tensioner shaft. thats why many xl600's will leak some oil on the top end, before it gets bad enough to bother pulling it out. just depends on how much that bothers you.
8. clutch, relatively minor/easy
over all, they are pretty bullet proof bikes with proper maintenance.
I have done #7 without removing the engine from the frame.
kmequint is offline   Reply With Quote
Old 06-04-2012, 06:43 PM   #5754
mcma111
mcma111's Avatar
Oddometer: 12,066
Cable
Someone on here a week or so ago was looking for the decom cable from the kicker. I have one in very good condition.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-04-2012, 08:15 PM   #5755
cynicwanderer
cynicwanderer's Avatar
Oddometer: 555
that's pretty cool. are you sure it was a xl600r, I have been able to do it on most XR/XL including xr600r, except the xl600r. well, technically, it's possible to do it if you remove all the engine bolts and tilt the engine, while in the frame. in any case, it's a pain for a simple O-ring.
cynicwanderer is offline   Reply With Quote
Old 06-04-2012, 08:43 PM   #5756
kmequint
kmequint's Avatar
Oddometer: 57
Go to page 3. Yes it would defiantly be a pain if you had to remove the engine for a simple o-ring.
http://www.thumpertalk.com/topic/957...ain-tensioner/
Old 06-04-2012, 10:56 PM   #5757
cam14
Oddometer: 175
PM sent, thanks
cam14 is offline   Reply With Quote
Old 06-04-2012, 11:06 PM   #5758
cynicwanderer
Oddometer: 555
it just talks about replacing the camchain/tensioner/gear, I didn't see how you got the top end off with the engine in the frame. I'd really like to figure that out, since I have to replace a rocker box gasket on mine and have been putting it off. it's not like I haven't tried three or four times and given up in the past and then removed the engine. maybe there is a slight difference between a '83 and a '85 ?
Old 06-04-2012, 11:14 PM   #5759
randylahee
Oddometer: 77
just finished the rebuild on my 83
2001 XR650L
2006 CRF450R
randylahee is offline   Reply With Quote
Old 06-05-2012, 01:15 AM   #5760
S.t.t.G.
Mind over metal...
S.t.t.G.'s Avatar
Oddometer: 1,691
WTB oem silencer that fits a '93 XR600R
Looking for factory exhaust for '93 XR600R...I have the head pipe, need rear section...want to quiet it down a bit.
Can use exhaust off of: '83-'87 XL600R, '83-'84 XR500R and '91-'00 XR600.
S.t.t.G. is offline   Reply With Quote
Times are GMT -7.   It's 02:41 PM.
