Old 06-05-2012, 07:23 AM   #5761
WoldM
Oddometer: 8
Originally Posted by cynicwanderer View Post
yes, check compression, which will tell you something about the rings/valves. besides that, there is
the usual:
1. worn timing chain (approx $150-175, plus gaskets) - there will be clacking noise coming from the side of
the engine. worn rockers or camshaft will cost more. you have to take the engine out of the frame to get the
valve/rocker cover off.
2. oil pump check valve (relatively cheap) - this is where the oil doesn't want to stay in the frame
3. tires ($50-???/wheel)
4. broke/lose spokes (relatively cheap)
5. front brakes slave/master/hose (relatively cheap if you go after market)
6. all the gears work (lots of effort to fix) - you have to split the case for 90% of the transmission problems.
7. any leaks from the top end/base gasket (cheap but lots of effort) - you have to pull the engine out of the bike to get the valve/rocker cover off, even for the little o-ring on the cam chain tensioner shaft. thats why many xl600's will leak some oil on the top end, before it gets bad enough to bother pulling it out. just depends on how much that bothers you.
8. clutch, relatively minor/easy
over all, they are pretty bullet proof bikes with proper maintenance.
Thanks alot! I hope I'll find a nice xl soon, the previous one I was looking to buy got taken right before my nose :(
WoldM is offline   Reply With Quote
Old 06-05-2012, 07:32 AM   #5762
kmequint
kmequint's Avatar
Oddometer: 57
it just talks about replacing the camchain/tensioner/gear, I didn't see how you got the top end off with the engine in the frame. I'd really like to figure that out, since I have to replace a rocker box gasket on mine and have been putting it off. it's not like I haven't tried three or four times and given up in the past and then removed the engine. maybe there is a slight difference between a '83 and a '85 ?
You won't be able to remove the valve cover while the engine is still in the frame. What I was able to do was seperate the cover enough to gain access to the pin holding the auto adjuster shaft in place, By doing that you can pull the shaft out far enough to replace the o-ring.
kmequint is offline   Reply With Quote
Old 06-05-2012, 08:49 PM   #5763
cynicwanderer
cynicwanderer's Avatar
Oddometer: 555
Ah, OK, that makes more sense. I'll have to try that the next time I need to change the O-ring. thanks.
cynicwanderer is offline   Reply With Quote
Old 06-06-2012, 12:58 AM   #5764
Licky
Licky's Avatar
Oddometer: 82
my usd conversion 83 XL600R
Well I got the forks mounted. I think I may have post that a while back. I have been collecting parts since then and it's been over two months since I got to ride. Since then I ordered a headlight with turn signals built in, a Tusk turn signal switch, a Vapor computer and choke knob conversion and some other little crap.
I took the compression release lever off as the fat bars didn't like the extra junk. I put on a late model clutch perch with a hot start lever on it and ran the decom cable to it. kinda hard to pull but it works. I put a choke knob on the carb and got rid of the entire choke pull system. I got my Tusk wired and just need to add connectors to the turn signals to finish up tomorrow.
My ignition switch was getting touchy and my dash lights and tail lights would go out intermitently so I put a differnt switch on. I don't have many photos to show so far but I'll try to put one in to show my cool little plate I made for switch and dummy lights to work with the Vapor.
I gotta go get a brake light switch tomorrow that goes in the banjo bolt of the front brake master since it is a CR500 mater now to match the rest of the front brakes.
hmmm. cant see a button to add a pic.
Licky screwed with this post 06-06-2012 at 01:03 AM Reason: pics
Licky is offline   Reply With Quote
Old 06-06-2012, 11:25 PM   #5765
scrubby81
Auto Builder
Oddometer: 138
1983 XL600r here love the bike but hard as heck to find parts for it I have been all over the net looking for things for it nobody seems to make parts for these anymore. No salvage yards seem to have them laying about either, so where yall getting your parts at?
Depending on the day its a goodin or its a
Thanks Scrubby
scrubby81 is offline   Reply With Quote
Old 06-07-2012, 05:10 AM   #5766
Billtr96sn
Flange Furtler
Oddometer: 393
Parts are here in the UK and Europe, and at good prices as well.
If you see me coming, better step aside. A lot of men didn't, a lot of men died, all because of my shit brakes.
Billtr96sn is offline   Reply With Quote
Old 06-07-2012, 05:26 AM   #5767
jon2xc
Oddometer: 2
Cool2 Xl600 RMG Noob
Hi Guys, have just picked up an XL600 RMG (1986) and trying to get 'er roadworthy and registered. Have managed to track down the easy bits and pieces, including a new seat cover, but can't find a replacement tail light lens or speedo assembly.
Anybody know where I might be able to pick these up? Also has an engine knock which sounds like the cam chain and tensioner needs replacing. Starts great, runs like a train, can't wait to get the old girl up to spec. Any tips?
jon2xc is offline   Reply With Quote
Old 06-07-2012, 06:10 AM   #5768
BRPtourer
Oddometer: 158
Scrubby....
I get most of my stuff off ebay or from Bike Bandit online unless it is generic bike parts like filters, mirrors, lights, etc, those I get from my local bike shop.
BRPtourer is offline   Reply With Quote
Old 06-07-2012, 10:09 AM   #5769
scrubby81
Auto Builder
Oddometer: 138
Wicked
My local bike shop don't like me lol they never have it or can't get it is always there words they just don't want to look I think. I did get somthing sent from the UK to me last week needed the ignition switch found it on E-bay there haven't got it yet tho... Not realy a E-bay user tho I been screwed alot on there looked in bikebandit web site not much there I am looking for Racks bags and aftermarket stuff like that. thanks for the link tho I am looking in to it now
Thanks Scrubby
Old 06-07-2012, 12:45 PM   #5770
Billtr96sn
Flange Furtler
Oddometer: 393
Scrubby, If you need anything from the UK, I am happy to get it for you and forward it on, that applies to all of you.
Old 06-07-2012, 02:37 PM   #5771
XLElder
Oddometer: 7
Hello and a question
Its great to find a thread like this and still active! Hail to the mighty XL600R!!!
Hello fellow riders from smoky New Mexico. I say that because we're dealing with the largest wildfire in state history right now. Some great and pristine land is scorched and won't recover in my lifetime. Saddens me but it was started by lightning so its natural I guess.
I have an '84 I bought used in '85. I rebuilt the motor immediately because the airbox leaked and the previous owner rode in sand. I think the guy had to go .040 over to get all the scratches out of the bore. Anyway the bike got rode for a few years and then things changed and I quit riding. But I kept her and took her with me wherever I moved. Over half the time she was stored in a garage or shed so she still looks decent. I started her up now and then. Now over 20 years and 60+ lbs. later I am starting a riding renaissance at age 53. I used to ride nearly every day in my youth.
I went over the bike and replaced what was necessary. Wheel bearings, fork seals, chain and sprocket, rebuilt the carbs. She's running like a top. If she sits a long time I get smoke at startup and I gather the valve seals are shot. But I'm not pulling the motor just for that. The only mod is a Super Trapp pipe. I wrapped the header tubes also. All else is stock except the gearing is 15/45 and I plan to go to 14/45 since I'm doing forest roads mostly. Oh and I installed a switch so I can turn the headlight off. Now I'm thinking of an oil cooler and the Progressive Suspension coils. Any opinions on those?
Sorry about being so long-winded but I am pretty excited about getting back into something I consider a way of life. The main question is I recently replaced the stator with a Ricky and did an Iridium sparkplug. What a difference! But now I notice the headlight pulses and dims at idle. Not sure if it did this before. I'm wondering if a rectifier or regulator is bad or if this is normal. Any insight? Thanks
XLElder is offline   Reply With Quote
Old 06-07-2012, 09:54 PM   #5772
scrubby81
Auto Builder
Oddometer: 138
thank you
I might just do that if you happen across a rear rack or bag mounts for an 83 let me know. Also in responce to head light pulsing I'm not realy sure if its normal but I did up grade my head light also to an HID with different case for it much brighter but it does pulse at idle, mine been doing it for over a year with no problems. I am also looking for a disk brake converson for the rear of my bike any ideas on this one?
Thanks Scrubby
Old 06-08-2012, 03:37 AM   #5773
Billtr96sn
Flange Furtler
Oddometer: 393
Re the oil cooler. I dont think it is needed. I have a chair on the side of mine and ride it in traffic and it has never showed any signs of overheating.
Old 06-08-2012, 07:09 AM   #5774
XLElder
Oddometer: 7
Thanks for the replies.
I would like to see a pic of the XL with chair (sidecar?)
Happy Friday
Old 06-08-2012, 10:03 AM   #5775
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
It might get a tad warmer in Albuquerque than it does in Somerset.
In addition, these engines often won't complain until something begins to melt. I'm not sure if that's good or bad. Very slow speeds and sustained high-speed is when RFVCs run hottest. Oil coolers are probably a good idea when oil temperatures regularly exceed ~280F/138C.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Times are GMT -7.   It's 10:22 PM.
