Old 06-28-2012, 12:32 PM   #5866
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
And all of the production cylinders are the same height. The '88+ HRC jug is slightly taller, which will lower compression with anything but the HRC piston. Head bolts and dowels got larger in '88 so heads and cylinders cannot be mixed and matched without mods or fabrication.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 06-29-2012, 12:17 AM   #5867
Dessert Storm
Dances With Drunks
Dessert Storm's Avatar
Oddometer: 793
When fastening down the cylinder head cover, when should the 8mm bolt be torqued down?
After the 6mm bolts have all been tightened in the approved 'diagonally opposite' manner; first, before the 6mm bolts are tightened; or at the same time as part of that process?
'You like motorcycles, beer, and ladies. I'm afraid I have the same illness' - Thierry.
Dessert Storm is offline   Reply With Quote
Old 06-29-2012, 06:21 PM   #5868
12120
Indenturedx5
12120's Avatar
Oddometer: 430
score
Found a motor minus crank. 200. Pretty cool.. Figure out when I can go get it and get to work on motor. YYYAAAA!!
If you find yourself in a fair fight, your tactics are wrong.
'83 XL 600r
12120 is offline   Reply With Quote
Old 06-29-2012, 07:58 PM   #5869
tractor4play
Oddometer: 108
cdi
this is a bit off topic although i am sure ill get good advise.i am about to put xl600r motor into xl 600lm.i have a xt 600 cdi from mid eighties so rather than hunting down a xl cdi if i match sator and ignit coil etc will it work?xt cdi is apparantly better speced.
tractor4play is offline   Reply With Quote
Old 06-29-2012, 11:12 PM   #5870
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
The XT600 is a Yamaha.
Old 06-30-2012, 02:18 AM   #5871
lookfar
from the land of OZ
Oddometer: 627
There are quite a few XL600 CDI units on ebay, rather than using a Yamahaha unit that may or may not work.....
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 07-02-2012, 03:46 AM   #5872
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 380
Hi
as reqested i start a new thread
How to build dual flatslide Carbs for the Honda XL/XR 600
http://www.advrider.com/forums/showthread.php?t=804951
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Old 07-02-2012, 11:28 AM   #5873
1Bonehead
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,113
Originally Posted by Schrauberklaus View Post
Hi
That looks great. how well does she run now?
1Bonehead is offline   Reply With Quote
Old 07-02-2012, 05:13 PM   #5874
cynicwanderer
cynicwanderer's Avatar
Oddometer: 555
Hi
awesome !
cynicwanderer is offline   Reply With Quote
Old 07-04-2012, 12:41 AM   #5875
tractor4play
Oddometer: 108
Wicked obvious
apart from it being obvious the xt is a yamaha i can only guess your not a fan of yamaha.
i do not care what its of as long as it works.
got a few photos coming for you ht.i think you asked me nearly 2 years ago.better late than never eh.probably the only ratty xl i have seen on any of the forums.watch this space you might like it.
Old 07-04-2012, 12:45 AM   #5876
tractor4play
Oddometer: 108
cdi
yea got an eightie three cdi with the round plug so need to work out what wire goes where as the pin position seems to differ from 85,86 cdi with the square dual plug layout.
Old 07-04-2012, 09:52 AM   #5877
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
I was merely poking fun at what I thought was a typo. R and T are next to each other on a QWERTY keyboard, after all. And I do like Yamahas, actually...and Suzukis. I tolerate Kawasakis.
As far as using the XT CDI, if possible, I would compare pulse generator and stator winding resistance between XT and XL600s and see if the ignition timing specs are fairly similar.
Old 07-04-2012, 12:31 PM   #5878
Dessert Storm
Dances With Drunks
Oddometer: 793
Hoped the damaged thread of one of the 6mm head cover bolt holes that stopped thebolt from being torqued down properly wouldn't cause an oil leak.
I can hear the guffaws from here.
At least on my RM I can pull the cover without dropping the engine. But, of course, the damaged hole is too close to the frame to be able get a drill at it to install a helicoil. And in any case, the idea of producing swarf in that area around assembled valvegear doesn't rest too easily.
So unless someone has a better idea, it looks like a head-off job.
Less than 50 miles since the engine went together with new head and head cover gaskets, both OE. What do people think about reusing them?
Old 07-04-2012, 12:48 PM   #5879
mcma111
mcma111's Avatar
Oddometer: 12,285
The rocker cover can be reused with the help of a sealant like Hondabond on both sides of the gasket. No go for the head gasket.
A couple of weeks ago I worked on a fellas XR650 for broken rocker cover bolts. Of course they were the ones right by the spark plug. At least the head came off without having to pull the engine. Heli coils to the rescue.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-04-2012, 01:23 PM   #5880
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
If the head gasket doesn't lose the black coating in disassembly(or never had any), I would consider reusing it...
Times are GMT -7.   It's 05:47 PM.
