09-27-2012, 03:42 AM
#6136 |
SAND EATER!
Oddometer: 524
Meh, I heard it was charcoal, I never opened one up. Might just be the California bikes too though, we got horrible emissions laws
'83 Honda XL600R valve seat ![]() RIDE RED! |
09-27-2012, 04:49 AM
#6137 |
Oddometer: 8,167
It's a vapor (oil mist) recovery container. Not a charcoal canister.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
09-27-2012, 05:15 PM
#6138 |
SAND EATER!
Oddometer: 524
Well i guess i stand corrected, now I know what it is. It's still useless unless you're a tree hugger eco-hippy.
Anyway, I've realized I crash, A lot. I keep spilling my bike like a newb. For instance, today I was taking a a left turn at about 25mph in some really soft sand and next thing I know I'm picking myself up off the ground saying "How the hell...." Picked the porker up. Upon inspection broke my left fender, and both turn signals. And then I had to get it started in the hot desert sun ![]() Think it might be my tires? Can anyone tell me what I should run for 25/75 dirt/street use? I ride only on sand only terrain unless you go to Big Bear. It ranges from the hard packed stuff to the nasty soft sand you hate to get in your boots and the trails aren't anywhere close to consistent terrain either.. I'm running Kendas right now.
09-28-2012, 12:18 AM
#6139 |
¯\_(ツ)_/¯
Oddometer: 1,250
No tire is going to do well in really soft sand, but tightening the nut behind the bars can help.
Or don't like having oil spewed on the back half of the bike....where one of the two tires and brakes reside.
1995 XR628R -Lots of goodies...room for more. "Another breakdown, suicidal shakedown, Feels like I'm livin' on a chain gang." |
09-29-2012, 10:33 PM
#6140 |
XL600R
Oddometer: 2
"New" 87 XL600R
Just bought a 87 XL600R I have been dreaming about since I sold my XL500s (actually traded for a CM400t). I am pretty excited to get it out riding. Got a few kinks worked out and have started riding it. Having a carb problem. Runs well up to about 1/2 throttle, above that it boggs out pretty bad. I think the 2nd carb has an issue. Going to have to pull it and clean it. Any ideas on common issues that cause this? Also looking to put on some decent 50.50 tires. Thinking Kenda 270 or Shinko 244 or 700. Any Thoughts? Looking forward to tearing up the mountains!!!!
09-30-2012, 06:50 PM
#6141 |
Oddometer: 17
Ok,
My plug boot is loose. I might as well replace the wire while I'm in there. Can the plug wire be removed from the coil? Anyone have a link to a replacement that worked well for them? |
09-30-2012, 07:12 PM
#6142 |
***ifyer
Oddometer: 231
Yes , its screwed in like usual .
Klaus ___________________________ Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87 Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98 Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13 |
10-01-2012, 12:21 PM
#6143 |
SAND EATER!
Oddometer: 524
Dusty old boots?
Seal them up with Shoe Goo! Seriously, no pun intended
![]() Not the prettiest, but sure did seal up those leaks!
10-03-2012, 08:43 AM
#6144 |
Oddometer: 17
Trying to basically replicate a stock tool kit. Was wondering what came in the factory set? Thanks
10-03-2012, 12:17 PM
#6145 |
Oddometer: 654
Engine oil leak
The XL sprung a nasty leak from the top of the motor. At first I thought it was the headgasket, but after looking at the motor I can see that oil is bubbling up from the front head bolt right by the spark plug. I tightened it up some but it was hardly loose. Is this still a headgasket leak and that's just where it decided to boil out of or should I be looking for something else?
10-03-2012, 05:23 PM
#6146 | |
Aspiring human
Oddometer: 2,180
1987 Yamaha XT600 2KF (German) STOLEN: RED XL600 in Portland I do heavy-duty textile repair, upholstery, and design/manufacture bags. |
10-03-2012, 09:20 PM
#6147 |
XL600R
Oddometer: 2
Head bolt Oil Leak
My XL500 I had in the past had the same problem. Mine was a head gasket. Fix the Problem, don't try to tighten that bolt too much. I tried that on mine and stripped the block where the headbolt attached. Then it became a major repair, not just a head gasket!!! (Learned a little bit on that one. "the correct torque is exactly 1/8 turn before it strips or breaks!".)
10-03-2012, 09:30 PM
#6148 |
Oddometer: 94
I have some spare parts for 1986 XL600R's I would like to sell......They also fit the other year models.....photos upon request......
Front and rear gold DID factory wheel set in great shape...complete with hubs, disc brake (front), drum brake (rear), axles.....cush drive....etc.....all assembled and ready to ride. Front wheel has a knobby tire in like new condition. Rear silver DID factory wheel.....complete with hubs, drum brake, axles....etc.... TCI Products Borrego Rack.......Silver ***SoLD*** Rear Fender, tailight and license plate holder.....Red (fender) ***SoLD*** bikejones screwed with this post 12-21-2012 at 09:26 PM |
10-05-2012, 07:38 AM
#6149 |
Oddometer: 152
Question about AM stators
What is the difference between Ricky and Rick's stator? These guys the same? If not, which is better?
10-05-2012, 12:01 PM
#6150 | |
SAND EATER!
Oddometer: 524
Anyone ever scare the shit out yourself? My bike was smoking all the sudden. Turned out when I sealed my boots, the airflow was corrected and sucking oil out my air filter. I thought I ran my shit with no oil or something. Cleaned the filter and used a lil less oil and no more smoke. I feel like a moron!
'83 Honda XL600R valve seat ![]() RIDE RED! RFVC600R screwed with this post 10-05-2012 at 12:22 PM |
