Old 10-28-2012, 12:32 AM   #6241
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,064
Originally Posted by nimbus721 View Post
where did you get the filter support mine has mysteriously disappeared during my recent rebuild.
I've always had it, sorry bro.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 10-28-2012, 11:14 AM   #6242
beardothebeardo
Oddometer: 202
No start issue
I have a no start issue on my newly aquired 86 XL6.
Here is what I know.
Brand spankin new Ricky stator (went with the advise here)
Adjusted the valves.
Went through the carb and corrected everything that was assembled wrong from the PO, except for the idle speed....which leads me to one question. Where does it need to be set after initial contact with the screw?
I have spark. Kinda. I have to really kick the hell out of it to produce a spark. This wasn't like that with my old XL6.
So, this leads me to my other question, can this be a pick-up issue?
I'm out of ideas...
***edit***
I forgot to mention, I have tried starting with and without enrichener. Also tried age old starting fluid and nothing.
beardothebeardo screwed with this post 10-28-2012 at 01:37 PM
beardothebeardo is offline   Reply With Quote
Old 10-28-2012, 07:21 PM   #6243
Tirekiller
adventurer
Tirekiller's Avatar
Oddometer: 1
Greetings, 'permission to enter!
Hello! and thanks to all Mods, Admins and Members, for the lurker support. It's been valuable. I humbly offer in return this pic/avatar of my recently acquired '87. It was a gift, and I'm the second owner. Low miles, original knobbies, it'd been parked since '97. it took about a dozen kicks is all, when I got it home last month.
I've been all over this thread, scanning, reading, learning and enjoying. Much more to go... Thanks!
Tirekiller screwed with this post 10-28-2012 at 08:04 PM
Tirekiller is offline   Reply With Quote
Old 10-28-2012, 08:03 PM   #6244
Carter Pewterschmidt's Avatar
Oddometer: 1,105
Does it even pop when you try that? Does it start and die? Or is it just nothing?
Carter Pewterschmidt is offline   Reply With Quote
Old 10-28-2012, 11:06 PM   #6245
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,064
Hey guys I somehow broke my chain gaurd/guide on on the swingarm, I cant 't find one anywhere, what should I do?
Old 10-29-2012, 03:46 AM   #6246
Billtr96sn
Flange Furtler
Oddometer: 393
I'm out of ideas...
***edit***
Lets look at what you changed..The stator, have you still got the old one you can put back in to try it out?
If you see me coming, better step aside. A lot of men didn't, a lot of men died, all because of my shit brakes.
Billtr96sn is offline   Reply With Quote
Old 10-29-2012, 05:28 AM   #6247
beardothebeardo
Oddometer: 202
No pop. No nothing. Nadda!
The old one was doing the same thing. Very weak spark when kicked hard, or no spark when kicked normal.
This is what lead me to believe I was having stator issues. Admittedly, I got ahead of myself without actually testing it.
Old 10-29-2012, 06:11 AM   #6248
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 394
Hi
Do you check your Carbs ?
They are more then 20 years old and many things there can go wrong.
To high gasoline level in the float boal from any reason and a leaking / open choke and the mix goes way to rich to start .
Worn out needle in the primary carb does the same .
Or the little Spring that hold the needle down in the slide is broken /rusty and the neddle stuck with the clip in the Holder in a pos. thats to high .
A hole in the diaphragma of the Air leak valve (very often ) and the mix is to lean to start .
Or simply the slow jet is partly blocked .
The XL had always a weak Spark but even a weak spark can ignite the mix if its the correct ratio .
but on the XL a little to rich or a little to lean and that weak spark does nothing .
And the Window of a good mix is very small . Lamda 0,87-0,95
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Old 10-29-2012, 07:07 AM   #6249
beardothebeardo
Oddometer: 202
Originally Posted by Schrauberklaus View Post
Hi
I did go through the carbs sat or sun (I cant remember), but you would think that it would at least do something off of starting fluid, if not fresh gasoline.
Old 10-29-2012, 07:19 AM   #6250
Schrauberklaus
***ifyer
Oddometer: 394
hi
give it a try .
but if it run already to rich the start pilot spray will not help .
close the gas tap first , kick the float boal dry .
if you lucky the bike will start already depend at on point of kicking with the closed gas tap
the mix gets lean and if it was to rich for starting then the engine will at least pop a few times.
venting the cylinder with full trottle and manual decomp lever will also help to move the to rich mix out
of the combustion chamber .
Klaus
Old 10-29-2012, 07:53 AM   #6251
beardothebeardo
Oddometer: 202
hi
give it a try .
I don't think I was clear in my previous post. I tried starting with fresh gas, tap on and off. I tried starting with ether (starting fluid), again, tap on and off. I have even left the air box disconnected (from when i took the carbs out to clean and sort) to get a direct shot of ether. Nothing.
***No doubt this is a spark problem***
I can leave the plug hang and if I kick the hell out of it, I can see a spark jump across the electrode. Does the same thing if I ground it on a screw on the engine.
So again, if I kick normal, no spark. Kick the hell out of it, got weak spark.
Upon a closer look, the ignition coil is an aftermarket unit. Can coils be tested? Can pick-ups be tested?
beardothebeardo screwed with this post 10-29-2012 at 08:11 AM
Old 10-29-2012, 09:08 AM   #6252
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,390
xrsonly.com has some for the XR600, and if you find the right one it may fit the XL. They seem to be 3-hole, though, and it looks like you need a 2-hole. Maybe call them to see if they know?
For a used one, ebay has you covered.
High Country Herb is offline   Reply With Quote
Old 10-29-2012, 10:00 AM   #6253
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,236
Those things are just a little fin that keeps something, I don't know what, from touching the chain. It's not even mounted on very sturdy tabs. I remember being able to bend the tabs like tinfoil when I would move the guard back and forth. Very unlike the XR guard which is mounted on a thick bracket and the chain passes through it. I don't know what the fin is supposed to deflect, but nothing very serious. You could take it off!
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 10-29-2012, 10:12 AM   #6254
High Country Herb
Oddometer: 9,390
I think it is supposed to prevent the chain from coming off the rear sprocket, in the event that the chain is too loose. Or it could be said that the chain is supposed to be a bit loose, and the guide keeps it aligned.
Yup, it's pretty flimsy. If you aren't doing the Baja 1000, you might not need it.
Old 10-29-2012, 01:16 PM   #6255
Oddometer: 1,105
That piece is a deflector. It's placed in front of the rear sprocket where the chain meets it so nothing gets in between and gets stuck in there or pops your chain off. Stuff like a branch or stick or weeds or tall grass or anything else sitting that high that could find it's way in there. If you ride on the street I'd say you don't need it, but if you ride through the woods or through fields or where ever those said items may lurk I wouldn't go without it.
I think you can still get one from Honda.
GUARD, CHAIN
52156-KB7-000
$27 plus shipping from these guys.
http://www.mrcycles.com/fiche_sectio...4#.UI7jM2_A9rc
Otherwise there are aftermarket ones on Ebay. It looks like the XR one but that may not be the actual picture of the part. It's being sold as a set, but seller has a bunch of similar parts listed so if you ask they may sell that guide separately.
http://www.ebay.com/itm/1983-1987-Ho...edf87d&vxp=mtr
Times are GMT -7.   It's 11:04 PM.
