Old 10-29-2012, 03:27 PM   #6256
beardothebeardo
Oddometer: 202
Originally Posted by beardothebeardo View Post
Upon a closer look, the ignition coil is an aftermarket unit. Can coils be tested? Can pick-ups be tested?
Anyone? I honestly don't remember having to kick this hard on my old one.
beardothebeardo is offline   Reply With Quote
Old 10-29-2012, 03:45 PM   #6257
Billtr96sn
Flange Furtler
Oddometer: 393
Coils can be tested, not sure how because I always swap them out for a known good one, pick ups can if you have a moving coil meter or scope. I have never had one go bad on me though. (That doesnt mean it cannot happen)
If you see me coming, better step aside. A lot of men didn't, a lot of men died, all because of my shit brakes.
Billtr96sn is offline   Reply With Quote
Old 10-29-2012, 04:39 PM   #6258
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,105
Usually when a coil is bad it stops working completely, or stop working when they get hot. Unless the wire is bad. Most other ignition components follow the same rule. CDI, key switch, etc. If they're bad typically you get no spark at all.
The spark on my bike used to look pretty weak before I replaced the stator. After that you could tell the difference just by watching the spark plug when kicking the engine over.
I'd test your compression before you buy anything else. You should be at 120 psi. If that's really low it won't start for shit.
Carter Pewterschmidt is offline   Reply With Quote
Old 10-29-2012, 09:53 PM   #6259
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 395
Yes you can .
Ignition Coil black/red - green (Ground) 230-320 Ohm , 285 Ohm at 20 Degreas Celsius
Pick up blue/yellow- green 340-440 Ohm
Ignition Coil prim./sek. 0,1-0,3 / 3,7-4,5 k-Ohm without the Plug
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Old 10-30-2012, 12:55 AM   #6260
Billtr96sn
Flange Furtler
Oddometer: 393
Originally Posted by Schrauberklaus View Post
Yes you can .
Can we have this info made into a sticky??
Old 10-30-2012, 03:23 AM   #6261
Schrauberklaus
***ifyer
Oddometer: 395
You want it Sticky?
Print it , use Google to translate the Words you don't know and Stick it on your Toolbox.
Klaus
Old 10-30-2012, 03:38 AM   #6262
Sierra Thumper
Oddometer: 641
Wicked Magic button.....tada!
E-start means never having to kick and say $%^& that hurt, you no-good *&^%$&#&^%$#
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 10-30-2012, 03:55 AM   #6263
beardothebeardo
Oddometer: 202
I ended up replacing the stator with one from Ricky because of the problem I am experiencing now. Makes me wonder if I got a bad new stator.
Yes you can .
Thank you for the specs. I'll be checking those over later.
Are there specs for the stator, as well?
Old 10-30-2012, 05:35 AM   #6264
Billtr96sn
Flange Furtler
Oddometer: 393
You want it Sticky?
Thank you Klaus, very much.
Old 10-30-2012, 06:19 AM   #6265
Schrauberklaus
***ifyer
Oddometer: 395
Look above on Page 2 under Elektrik> Lichtmaschine
Klaus
Old 10-30-2012, 06:34 AM   #6266
beardothebeardo
Oddometer: 202
Thank you very much for all your help. I have some work to do. Will report back later.
Old 10-30-2012, 11:19 AM   #6267
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,391
I rather have to kickstart, than have to push start on single track gravel. We don't need no stinking battery!
High Country Herb is offline   Reply With Quote
Old 10-30-2012, 12:56 PM   #6268
Billtr96sn
Flange Furtler
Oddometer: 393
Or you could have my XL, kick AND electric!
Old 10-30-2012, 01:48 PM   #6269
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,071
Still don'tneed no battery!
I ran over a fucking HUGE staple at the lake bed, nothing like limping home 15 miles with a flat in the middle of nowhere. Now I can't ride for a couple days til that damned tube comes in I have no life.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 10-30-2012, 02:30 PM   #6270
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,236
Was it a lake bed of boxes from your work? Wait, that'd be fun.
Shoot, I should get a couple of spares together before it happens to me!
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Times are GMT -7.   It's 07:34 PM.
