Old 11-11-2012, 10:20 PM   #6346
12120
12120's Avatar
Oddometer: 143
Originally Posted by Sierra Thumper View Post
Is your jetting all stock? The xl600's, like all street legal bikes, came abit lean from the factory stock, and cold-blooded is a lean symptom. If its running great besides that, and has always done it, you might want to go up abit in size on your pilot jet. If it just started doing it then there's something else going on.
Always been that way. Have a supertrapp and up 1 size on primary and secondary carb jets. I was thinking I might go up a size on the pilot also, but it has only been real bad the cold days. Mid 30's. I just have taken to leaving the choke on until I get through the first couple of lights.
If you find yourself in a fair fight, your tatics are wrong.
'83 XL 600r
12120 is offline   Reply With Quote
Old 11-12-2012, 03:14 AM   #6347
Sierra Thumper
Oddometer: 641
You'd be truly amazed what going up a size or 2 will do for your starting and off idle throttle response.....its WELL worth the effort, I'm talking from experience
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 11-12-2012, 03:41 AM   #6348
beardothebeardo
Oddometer: 152
Speaking of jetting, I can't remember which way the mixture screw affects things.
In=richer? Or do I have that backwards on these carbs?
Too many blows to the skull over the years!!
beardothebeardo is offline   Reply With Quote
Old 11-12-2012, 07:00 AM   #6349
beardothebeardo
Oddometer: 152
Originally Posted by Moparmanpete View Post
Hope this helps
That's what I needed. Thank you.
Old 11-12-2012, 07:01 AM   #6350
beardothebeardo
Oddometer: 152
Speaking of having to kick these bikes, a multitude of times...I would start with the stator!
If it ain't getting the spark it needs, then no amount of jetting is going to make that bugger start properly.
***edit***
Also, these buggers are very easy to kick over when the decompressor cables are adjusted to spec and the proper technique for kicking is used.
beardothebeardo screwed with this post 11-12-2012 at 08:01 AM
Old 11-12-2012, 03:10 PM   #6351
kmequint
kmequint's Avatar
Oddometer: 51
16010-MG2-791
GASKET SET (Honda Motorcycle Code 2151660)
16010-MG2-305
GASKET SE
16010-MG2-305
GASKET SET (Honda Motorcycle Code 3973773
16010-MG2-791
GASKET SET
Hope you can see it
What is with the different betwen part numbers and and which set do I need for a full carb rebuild
I know I need two sets but not sure which ones
The first and last are the same item, as-is the middle two are the same. 16010-MG2-305 looks like the correct part. 16010-MG2-791 cannot locate what it is.
kmequint is offline   Reply With Quote
Old 11-12-2012, 03:11 PM   #6352
kmequint
kmequint's Avatar
Oddometer: 51
Go here: http://www.cheapcycleparts.com/model...rburetor-86-87
Old 11-12-2012, 08:05 PM   #6353
snake89
Oddometer: 17
Skid plate for 83 XR 500
Anybody have a spare skid plate to fit my 83 XR500 ? Mine was missing when i bought the bike. Its the last thing i need to finish my barely street legal dualsport. You can contact me at snakezrx@hotmail.com Thanks
WORK SUCKS-LETS RIDE !!!
snake89 is offline   Reply With Quote
Old 11-12-2012, 08:15 PM   #6354
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 594
XR5 skid plate
There are three skid plates on eBay right now for the 83/4 XR5:
www.ebay.com/itm/VINTAGE-1984-HONDA-XR500-SKID-PLATE-AHRMA-/230868228031
www.ebay.com/itm/SKID-PLATE-XR500R-83-84-HONDA-ENGINE-MOTOR-BELLY-GUARD-ROCK-1983-1984-/140877745462
www.ebay.com/itm/84-HONDA-XR-500-SKIDPLATE-SKID-PLATE-/160906983123
Ghost_Mutant is offline   Reply With Quote
Old 11-12-2012, 09:05 PM   #6355
mcma111
mcma111's Avatar
Oddometer: 7,985
You pay your money and you take your chances.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-12-2012, 11:56 PM   #6356
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,132
Any one tried this stator?
http://www.ebay.com/itm/NEW-HONDA-XL...be400a&vxp=mtr
I know Rickys' is the way to go, But......
If I can't afford it I can't afford it.
Does it come with a "Whenever it's broken, send it in for a free replacement" warranty that the Ricky Stator has? I'm wanting them to make an XT600 stator since I have one of those now. Worth every penny, them Ricky Stators are.
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 11-13-2012, 02:27 AM   #6357
Homerb
Oddometer: 204
Im hopefully picking up my new xl600rmg on thursday, and was wondering what manual everyone recommends, Clymer or Haynes? Any obvious omissions in either?
I had a Haynes for my xl350r as well as a genuine honda manual, and found the haynes ok if a bit vague sometimes.
Homerb is offline   Reply With Quote
Old 11-13-2012, 03:43 AM   #6358
beardothebeardo
Oddometer: 152
At $65, you are more than a third of the way to having the Ricky unit. I saw those myself when I went through this process a few weeks ago and am very glad I got the Ricky.
Let's put it this way, seeing as you don't want to be spending a lot of money on this build, does it make sense to spend $215 in the end, when you could have just bought it right the first time for $150, after the turd piece takes a crap? And to further put it into perspective, the OEM unit is around $340, so for the $150, you are going the cheap route, and getting quality. My .02
Old 11-13-2012, 03:45 AM   #6359
beardothebeardo
Oddometer: 152
If you can find the Honda version, go for that.
BTW, I want to see pictures of that bad boy!!!
Old 11-13-2012, 11:28 AM   #6360
Zombie_Stomp
Aspiring human
Oddometer: 2,132
I remember you saying that you liked the copper gasket coating, Have you used it on the head gasket too?
The can says its for head gaskets too but, I'm unsure wether I should.
Yeaah I've used it for head gaskets. Says it right on the can I like it for it's tackiness on the rocker box, and for the head gasket you can reuse it with silver spraypaint too,even. That's the other trick. Doesn't say that on the can but it works!
Times are GMT -7.   It's 10:56 PM.
