Old 11-15-2012, 04:21 AM   #6361
lookfar
from the land of OZ
Oddometer: 655
Originally Posted by Zombie_Stomp View Post
Does it come with a "Whenever it's broken, send it in for a free replacement" warranty that the Ricky Stator has? I'm wanting them to make an XT600 stator since I have one of those now. Worth every penny, them Ricky Stators are.
Hey Zombie, maybe if you send them your old stator, they will rewind it for you.......
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 11-15-2012, 02:46 PM   #6362
lookfar
from the land of OZ
Oddometer: 655
Originally Posted by Moparmanpete View Post
Lookfar, How is your XL doing?
Hey Pete,
I have done as much as I am going to do on the XL for now...time to enjoy riding it before the wet season..
This is how it looks currently
Stu in FNQ
1985 XL250R
Old 11-15-2012, 07:46 PM   #6363
lookfar
from the land of OZ
Oddometer: 655
My coil wire says "Hitachi 1986" That wouldn't be the year by any chance would it?
I have been trying to check the ohms on everything and am not sure if I'm reading it right, but I have a feeling everything is original (cloth covered wires) and shot.
Can't help you with the coil question, I thought that I kept my old one when I went through and replaced stuff.
I have replaced the whole ignition/generating system on my XL, with the exception of the pickup in the RHS casing. Must have flung the old coil in the shed purge between bikes...
Nothing wrong with cloth covered wires, so long as you haven't got a short going to earth where there shouldn't be, it's all good.
I think that Ricky is still using cloth covered wires on their new stators......
Stu in FNQ
1985 XL250R
Old 11-16-2012, 04:39 AM   #6364
Dessert Storm
Dances With Drunks
Dessert Storm's Avatar
Oddometer: 803
Needle Jet Holder Sought
Don't suppose anyone has got a dead left-side carb lying about, that might contain a needle jet holder (number 29 in this diagram) http://www.cmsnl.com/honda-xl600r-19...2.html#results and that they may be willing to part with?
The one in my carb is scored and slightly deformed - presumably by a POs attempts to remove it or a reluctant jet.
'You like motorcycles, beer, and ladies. I'm afraid I have the same illness' - Thierry.
Dessert Storm is offline   Reply With Quote
Old 11-16-2012, 06:38 AM   #6365
Billtr96sn
Flange Furtler
Oddometer: 393
I am in the UK and have a spare pair of carbs, what are the specs for yours so we can make sure they are the same.
If you see me coming, better step aside. A lot of men didn't, a lot of men died, all because of my shit brakes.
Billtr96sn is offline   Reply With Quote
Old 11-16-2012, 09:16 PM   #6366
Homerb
Oddometer: 462
Well I got home last night after a 1800km (1200 mile) round trip to sell one bike and buy the XL600RMG. Got a chance to do about 40kms of dirt riding yesterday and it goes well. Only worry is a knocking noise coming from the top end, particularly at idle. Seems to go away as revs increase,(or maybe you just can't hear it.) Pulled the valve cover off this morning, then the head and then the barrel. Small end bearing is quite loose. Some movement when rocking the pin from side to side. Looks like a rod kit is in order. Was planning to rebuild top end eventually with a 11.5:1 piston, Kibblewhite valves and springs, and a stainless exhaust and maybe flatslide carbs. Looks like I'll be doing it sooner rather than later!
Homerb is online now   Reply With Quote
Old 11-17-2012, 04:18 AM   #6367
lookfar
from the land of OZ
Oddometer: 655
Hey All,
I have a problem with my XR.
I am attempting to line up everything on TDC so that I can replace the timing chain, and the markings on the flywheel are nowhere near the inspection hole when on TDC. With the flywheel marks lined up in the inspection hole, the piston appears to be on BDC prior to the compression stroke. Needless to say, the markings on the cam sprocket are way out.
The engine was running before I removed it from the frame..
The marks are on the flywheel are: | | |F |T
got me stumped....any ideas???
Stu in FNQ
1985 XL250R
Old 11-17-2012, 07:01 AM   #6368
mcma111
mcma111's Avatar
Oddometer: 12,593
Lookfar,
I just answered this on the XR600 thread.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-18-2012, 03:04 AM   #6369
Dessert Storm
Dances With Drunks
Oddometer: 803
My RMG has become extremely difficult to start, even with the electric foot. Good fuel; good compression; recently overhauled carb (and prior to this problem it has run well since carb overhaul); fuel flowing to carbs; valve clearances OK; spark although not massive is fairly strong.
'Stator?' I wondered. But the thing is, when it does start, it runs smoothly and well, ticks over sweetly, and pulls strongly. Would this be the case if the stator was dead/dying? Anything glaringly obvious I may have overlooked?
Bit flummoxed chaps.
Old 11-18-2012, 03:20 AM   #6370
lookfar
from the land of OZ
Oddometer: 655
Check the pick-up ion the RHS casing. This tells the CDI when to fire the spark plug.
Should generate 0.7-1.0 volt when triggered.
Measure resistances in the coil and spark plug cap...
Try a different CDI box...it could be the problem
Or failing everything else, send it to me
Stu in FNQ
1985 XL250R
Old 11-18-2012, 01:07 PM   #6371
amf4399
amf4399's Avatar
Oddometer: 63
A little help
I had a Friend of mine drop my cam off at a Cam shop and I was asked a question that I wasn't sure own. Are the intake and exhaust lobes the same? I have a 83Xl600r
amf4399 is offline   Reply With Quote
Old 11-18-2012, 01:20 PM   #6372
mcma111
mcma111's Avatar
Oddometer: 12,593
Nope
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-18-2012, 01:21 PM   #6373
mcma111
mcma111's Avatar
Oddometer: 12,593
Do you need a cam? I have one available.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-18-2012, 01:40 PM   #6374
amf4399
amf4399's Avatar
Oddometer: 63
Originally Posted by mcma111 View Post
Nope
Thanks, I found my manual and looked it up. In other words I got off my lazy ass.
Old 11-18-2012, 01:41 PM   #6375
amf4399
amf4399's Avatar
Oddometer: 63
I don't think so but I will get back to you if I get bad news. thanks
Times are GMT -7.   It's 03:43 AM.
