11-18-2012, 01:41 PM
#6376 |
Oddometer: 51
11-18-2012, 01:49 PM
#6377 | |
Oddometer: 51
11-19-2012, 05:29 AM
#6378 |
Oddometer: 52
My XL600
Hi Guys, Finally got my new to me 84 XL600 to run again and here are some pics....
![]() It's a little shabby at the mo, but, love it all the same, not sure what the fenders are off of though, anyone know ? ![]() As far as I'm aware it's a standard 84 PD03 apart from the fenders and the FMF pipe. I have a few plans for it. Managed to pick up a Dakar twin round headlight unit and fairing, it's been painted badly though, so, need to strip the paint off, any suggestions for something that'll strip the paint without damaging the plastic - happy to put elbow grease in :) I also just bought a standard rear rack from Germany, so, from what I've read on the forum, I seem to have been pretty lucky with parts so far |
11-20-2012, 03:14 AM
#6379 |
Lost when found..........
Oddometer: 1,058
hi all
for those looking for a genuine safari tank for the xl600, there is currently one on ebay in australia. search for item number 251182922856 its not mine, my xl600 with dakar tank was stolen a few years ago.
- Charlie 125cc Salt Racer - God of Speed Thread 'Overall happiness is directly proportional to the increasing distance between the front wheel and the ground.' - '85 XL600R-L-M-PDGSAZ |
11-20-2012, 04:48 AM
#6380 |
Oddometer: 51
On my 83 Xl600r. The specs for my Camshaft lobe height reads
Specification 31.023mm and the wear limit is 31.85mm. How can the wear limit be larger should it be smaller? |
11-20-2012, 05:02 AM
#6381 |
Oddometer: 51
Hi Moparmanpete, Actually in the Italian version that you sent me it says something different. It says 30.85mm not 31.85mm which makes more sense. I think its a typo in the American manual.
11-20-2012, 05:37 AM
#6382 | |
Oddometer: 52
Cheers, |
11-20-2012, 12:03 PM
#6383 |
Flange Furtler
Oddometer: 368
The Dakar tanks do have 2 fixings at the rear and the nose of the seat is different as well.
11-20-2012, 02:39 PM
#6384 |
SAND EATER!
Oddometer: 483
Leaking oil like a harley over here. from the stator cover. no time to fix it, and no time to ride either
Don't want to drive my car either. Two wheels or I ain't happy
'83 Honda XL600R valve seat ![]() RIDE RED! |
11-20-2012, 04:13 PM
#6385 |
SAND EATER!
Oddometer: 483
Should I buy a gasket kit? or will that cut yourself stuff work? I got some cork gasket lying around.
11-20-2012, 08:59 PM
#6386 |
Oddometer: 16
Been shopping around for some tires. Anyone ever run a wider tire up front, if so what size? can always use a bit more cushioning on the bike.
11-20-2012, 10:03 PM
#6387 |
Oddometer: 144
I'm riding riding riding POP I'm pushing pushing
Hate when old reliable becomes old damn thing.
Haven't really had a chance to dig into it yet. I am sure I have a ignition problem, but have to get a better multi meter to really check stuff. Got a new coil on the way already just cause I found a deal on one, and the plug wire was arcing to the tank. Woke me up a couple times before I wrapped some old tube around it.![]() Chris
If you find yourself in a fair fight, '83 XL 600r |
11-21-2012, 02:01 AM
#6388 | |
from the land of OZ
Oddometer: 253
That is similar t what happened to me. Turned out to be the cdi died. Replaced it using swapnostics And all was good again.
Stu in FNQ The early bird catches the worm, but the second mouse gets the cheese. Growing old is mandatory... growing up is optional. 1985 XL600R 1988 XR600 |
11-21-2012, 06:46 PM
#6389 |
Oddometer: 144
Check me please
Before I say the stator is bad. Can someone tell me I did this right? Black and red(?) wire from stator. Not in the 4 pin plug, but right next to it and from the stator harness. I should have 40-50v ac when kicking over? Test that wire and I get almost nothing. I think 13 something was the best I got. Do I need a better meter to do this test? I have just a napa special multi meter. Don't know how fast it reacts? I get no voltage at the primary coil wire either. Checked wire from harness to coil and the ground wire for coil and got nothing. I am pretty sold on the stator went south, just double check me would someone please.
Chris
11-21-2012, 07:02 PM
#6390 | |
Oddometer: 144
Where am I again? To bad you aren't right near by I have most all the stuff you need in a box somewhere.
