Old 11-30-2012, 02:21 PM   #6421
mcma111
mcma111's Avatar
Oddometer: 12,068
Originally Posted by High Country Herb View Post
...a small amount. You don't want chunks of the stuff plugging an oil passage way somewhere.
It may look like a lot but it's as thin as I can spread it. I coat both the head and rocker cover along with both sides of the gasket. NO leaks. Use a non hardening sealant like Hondabond.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-30-2012, 02:33 PM   #6422
crobox
crobox's Avatar
Oddometer: 324
OK, thank you fellas-
I noticed that the head cover gasket is steel, and was planning on re-using it. Will probably cut my own stator cover gasket. If anyone has the thickness spec on that cover, I'd appreciate it. Will perform checks on stator, as outlined in Clymer manual, to try to get an idea whether Ricky Stator is in order.
But now... a question:
Is a fully charged and healthy battery necessary for spark?
Current Bikes: 2006 KTM 950 ADV S, 2002 XR650L, 1988 Hondasuki KLNX250R
Previous Bikes: 1986 Honda XL600R,Honda XL250R (2 of them), Honda XL600R, Kawasaki KLR600, Honda Nighthawk, BMW K1100LT, BMW R100GS, BMW R60/6, BMW K75, Husqvarna 430XC
Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com
crobox is offline   Reply With Quote
Old 11-30-2012, 02:35 PM   #6423
mcma111
mcma111's Avatar
Oddometer: 12,068
Nope. Battery has nothing to do with ignition.
One thing with the stator is that you may get spark when first started/cold and then lose spark as the stator comes up to temp.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-30-2012, 05:58 PM   #6424
crobox
crobox's Avatar
Oddometer: 324
OK, thanks. That's what I thought.
I am confused about the role of the stator in spark generation. I suppose that I should infer from everybody's insistence that the stator is a likely culprit that it IS in fact important to spark. But I thought spark was the job of the pulse generator and the coil, and I thought the stator was just for charging.
Sorry to ask these questions that I am sure are answered elsewhere... but I have read the electrical chapter in the manual, and this issue is NOT clear... at least not to me.
Old 12-01-2012, 07:35 AM   #6425
mcma111
mcma111's Avatar
Oddometer: 12,068
Originally Posted by Moparmanpete View Post
From this
To finaly this
Still need some odds and ends for the left side cover and a guinea pig experiment stator and back in goes the Cracken's heart
Swell. Ya got the motor together. Now about cleaning the garage.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-01-2012, 11:46 AM   #6426
cynicwanderer
cynicwanderer's Avatar
Oddometer: 555
one these bikes, there are three (3) separate circuits from the stator. One AC circuit for the headlight with an AC regulator, one circuit with a rectifier/regulator that charges the battery and all the little lights (instrument, turnsignals, etc...). the third circuit is the ignition circuit, it provides AC (like 70volts) to the CDI, which boosts the voltage even more to drive the ignition coil, which then generates the HV for the plug.. the timing of the CDI is controlled by the pulse generator coil on the right side of the crankshaft.
for the bike to run, all it needs is the ignition circuit on the stator, the CDI, the pulse generator, ignition coil and plug and the kill wire on both the kill switch and ignition switch _not_ to be connected to frame ground. you can check, the sparkplug cap, the ignition coil, stator coil and pulse generator coil with an ohmmeter. however, this won't tell you if there is an intermittent in the wiring or HV break down somewhere. most common issues are:
1. stator coil (the epoxy breaks down over time in the hot oil and then vibration will short out windings)
2. cracked spark plug (easy to do on these deep well motors if you don't have a good fitting socket)
2. water/moisture getting in the HV wiring/coil/plugcap, hard to find.
3. wiring problems (e.g. kill wire shorted to ground somewhere)
it's rare that the CDI breaks or the pulse generator dies, but not unheard of.
cynicwanderer is offline   Reply With Quote
Old 12-01-2012, 02:04 PM   #6427
lamebrain
Oddometer: 38
it's rare that the CDI breaks or the pulse generator dies, but not unheard of.[/QUOTE]
Not rare for me, I've had to repair two CDI's for my XL600.
lamebrain screwed with this post 12-01-2012 at 02:24 PM Reason: misspelling
lamebrain is offline   Reply With Quote
Old 12-01-2012, 02:09 PM   #6428
lamebrain
Oddometer: 38
And a pic just because
Old 12-01-2012, 02:44 PM   #6429
lookfar
from the land of OZ
Oddometer: 618
Not rare for me, I've had to repair two CDI's for my XL600.[/QUOTE]
Not rare for me either...had to replace one of mine..went cactus.
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 12-01-2012, 02:44 PM   #6430
lookfar
from the land of OZ
Oddometer: 618
Very nice...
Stu in FNQ
1985 XL250R
Old 12-02-2012, 12:45 AM   #6431
crobox
crobox's Avatar
Oddometer: 324
Originally Posted by cynicwanderer View Post
one these bikes, there are three (3) separate circuits from the stator. ETC...
What a great explanation.
Thanks so much, cynicwanderer!
Old 12-02-2012, 05:27 PM   #6432
cynicwanderer
Oddometer: 555
what did you repair on them ? I know sometimes the connector pins come lose from the PCB and need to be re-soldered.
Old 12-02-2012, 11:28 PM   #6433
lamebrain
Oddometer: 38
On the first one there were 7 connections on the PCB where the solder had cracked, I re-soldered them and have been running that CDI for about a year with no problems. The second CDI I De-soldered the entire PCB and re-soldered. I ran this one to make sure it worked and have it as a backup just in case.
Old 12-03-2012, 06:32 PM   #6434
ricnepalm
Gittin' Along
ricnepalm's Avatar
Oddometer: 85
cdi repair
Do you, or anyone for that matter, have a diagram of the cdi? After a summer of troubleshooting the ignition, stator, no start situation I've been having, I'm thinking it's the CDI.
02 DRZ400E - slightly totalled
96 VFR 750
97 BMW F650
78 BMW r60/5
ricnepalm is offline   Reply With Quote
Old 12-03-2012, 07:34 PM   #6435
lamebrain
Oddometer: 38
Not a diagram, but this is what I used.
http://www.thumpertalk.com/topic/881...lp-cdi-repair/
There's also this one.
http://www.advrider.com/forums/showthread.php?t=684756
Times are GMT -7.   It's 08:40 AM.
