12-15-2012, 06:30 PM
#6556 |
Oddometer: 8,011
I have a mid 80's XR600 shock laying about that has a remote reservoir and a LE Lindeman Engineering ( http://www.le-suspension.com/ ) sticker on the body so I'm guessing that it has been worked on. PM me if your interested.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
12-15-2012, 06:56 PM
#6557 | |
Crazy Diamond
Oddometer: 726
That should raise the back of the bike about 1.25" from my experence and works great with the 1.5" longer XR cartridge forks. Night and day difference in handling. Well worth doing. Since your forks are the early ones with the smaller axle, a fork brace would be a good addition. With the 17" front wheel it will be a riot to blast around town on.
Praise the Lord!!! I have seen the light!!! He has shown me the promised land!!! TT for now...
12-15-2012, 08:17 PM
#6558 |
Oddometer: 642
12-15-2012, 08:20 PM
#6559 | |
Oddometer: 642
12-15-2012, 08:46 PM
#6560 | |
Crazy Diamond
Oddometer: 726
In your case the shorter '86-90? XR250R 14.7" shock would work better. It would raise the seat heght about 1/2" but net 10" of travel. With the longer travel you run more sag so the rear end rides at the same hieght with you on it. It has a larger piston then the 15" XR600 shock. Both rebound and compression are adjustable. The XL600 shock is 14.5"
12-16-2012, 12:48 AM
#6561 | |
SAND EATER!
Oddometer: 489
Back to my issue on hand, I see fork seals and dust seals online, how do I know which ones are bad and need replacing??
'83 Honda XL600R valve seat ![]() RIDE RED! RFVC600R screwed with this post 12-16-2012 at 12:58 AM |
12-16-2012, 03:25 AM
#6562 | |
Oddometer: 553
my rule is to replace fork seals every time I take the fork apart, even if they are not leaking. if one blows/leaks, I replace both sides at the same time. you'll be able to tell if they have blown when you have oil with dirt on the fork legs, assuming there is enough oil in them to start with. it's a good idea to change the oil often. I can always tell a significant improvement with fresh oil in the forks.
12-16-2012, 04:54 AM
#6563 |
Oddometer: 1,627
And Dracus, if your saying fork seals OR dust seals, replace them all. The factory Honda ones have been the best in my experience.
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F |
12-16-2012, 12:32 PM
#6564 |
Oddometer: 196
I don't know anything about Jetting...
Howdy all-
While rebuilding / rejuvenating my XL600 I've decided to open up and rebuild the carbs. I've done it before... no big deal. I've ordered the replacement gasket sets already. I figure this is the right time to look at and possibly replace the jets... but I really don't know too much about it (other than the basics... bigger jets = more fuel = richer mixture = low altitudes, smaller jets = less fuel = leaner mixture = higher altitudes, right??) I live at 7000 feet altitude, and will ride mostly in that range. I would like to learn more about the topic, though, and be able and prepared to swap jets for different altitudes. Can anyone recommend the right jets for my altitude? Or even better yet... is there a chart somewhere to consult? Or a discussion on the topic that anyone can point me to? (I've just used the search function and read a few pages here and there within this thread, but there wasn't really a definitive discussion of jets vs. altitude.) Thanks, Christian
Current Bikes: 1986 Honda XL600R, 1988 Hondasuki KLNX250R, 1988 BMW R100GS (dead) Previous Bikes: Honda XL250 (2 of them), Honda XL600R, Kawasaki KLR600, BMW K1100LT, BMW R60/6, BMW K75, Husqvarna 430XC Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com |
12-16-2012, 02:13 PM
#6565 | |
Oddometer: 642
http://www.thumpertalk.com/topic/172305-xl600r-jetting/ Personally I haven't played with jetting these carbs enough to make a solid determination. The secondary carb throws me off. I've found like everyone else to run a smaller jet in the secondary but I've yet to try tuning it by adjusting needle position. I've just tuned the primary carb and took the stock jet from it and placed it in the secondary, nothing more. It seems to requite a bit of precision to get it right. It's something that I'd like to take the time to figure out though. Might have to make some dirt bike dyno runs this summer.
12-16-2012, 02:24 PM
#6566 | |
Oddometer: 553
one approach to get it right, is to weld on a oxygen sensor bung on the exhaust header after the two ports join up and use a wide ratio oxygen sensor/meter to monitor all jetting adjustments. keep a log. when done, just replace the oxygen sensor with a threated plug. I have been meaning to do this at some point, but there are plenty of other things to fix...
12-17-2012, 08:01 AM
#6567 | |
Oddometer: 642
In the case of a built up turbocharged 4 cylinder making twice it's original horsepower then it's more of a necessity. |
12-17-2012, 01:50 PM
#6568 | |
"Old guys rule"
Oddometer: 39
Thanks Klaus. Will check that out
12-17-2012, 02:13 PM
#6569 | ||
Oddometer: 642
Although it's for car carburetors one could still safely assume this would generally apply to motorcycles as well. |
12-17-2012, 05:14 PM
#6570 | |
Crazy Diamond
Oddometer: 726
Thats good info that kind of explains the progressive twin carb engines. They are kinda like a staged two barrel carb without an accel pump. Most people have no idea how to tune one. Once tuned there's no need for an accel pump either.
