Old 12-19-2012, 07:54 PM   #6586
blitchfield
blitchfield's Avatar
Oddometer: 236
what do you think??
Saw this and wanted to get some opinions
http://hartford.craigslist.org/mcy/3487645260.html
I have always been and xr/xl guy and would love to add another cheap ride to the stable but not if it's a pain to fix up. I saw some parts are discontinued, but I figure there has to be parts or possibilities out there. Again just wondering if it's worth checking into
blitchfield is offline   Reply With Quote
Old 12-19-2012, 08:10 PM   #6587
Mike the Yank
Oddometer: 389
Thanks Klaus will try that again. Am still having some difficulty starting the beast. Once running it purrs nicely.
Tried the techniques described here for this bike and maybe I am not quite doing it right. Will keep at it while my leg holds out!
Check your stator, should be connections under your seat, some where around 250 ohms is good, too high or too low and it will be hard to start. (Rickys aftermarket stators test around 100 ohms though for some reason.)
I re-wound mine and it is one or two kicks now hot or cold.
Oh yeah, never turn the throttle while kicking, NEVER!
It's a lot easier to apologise than to ask permission
Mike the Yank is offline   Reply With Quote
Old 12-19-2012, 09:33 PM   #6588
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,067
Listing is down you must have bought it already, lol. They go quick if they're cheap like $1500 or less. How much were they asking?
Carter Pewterschmidt is offline   Reply With Quote
Old 12-20-2012, 11:37 AM   #6589
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,678
Went to go ride a few minutes ago and when I started the old beast, I noticed a strange kinda rattling ticking noise coming from the right side case. It it increased in speed with a light rev. and just as I was about to switch it off it, the noise stopped. it only happened for like 20 seconds tops.
What could that noise be??
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust, big tube header, 6 Sigma stage 3 carb mods
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 12-20-2012, 11:53 AM   #6590
blitchfield
Oddometer: 236
Never got a response from the poster. They were asking $300. Sometimes I wonder, I had seen it before and figured it was gone. Again, it was so cheap for a big thumper, I figure I probably couldn't go wrong even if I spent a grand in parts.
Old 12-20-2012, 12:26 PM   #6591
Oddometer: 1,067
Yeah that price is a steal. I would have bought it just for parts.
Old 12-20-2012, 12:37 PM   #6592
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 8,368
It sounds like the compression release lever is contacting the rocker arm. It could be out of adjustment, or just sticking. I disconnected mine for just that reason. I never felt the need for that feature, and consider it more of a risk than help.
High Country Herb is offline   Reply With Quote
Old 12-20-2012, 01:01 PM   #6593
mcma111
mcma111's Avatar
Oddometer: 11,901
Is it cold where you are. Colder than normal?? It's the oil pump by-pass valve ratteling. Normal. Goes away once the oil warms up a bit.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-20-2012, 01:40 PM   #6594
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,678
yeah it was about 40 fahrenheit when it happened.
Old 12-20-2012, 02:13 PM   #6595
mcma111
mcma111's Avatar
Oddometer: 11,901
What weight oil ya running??
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-20-2012, 09:31 PM   #6596
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,678
I am running 10W40 Penzoil. I would of dropped it. but it still gets pretty warm in the daytime. the Haynes manual says 10w40 is good for the ambient temps im running but I'm guessing i should drop to 10W30 or something?? People here are smarter than the book I have discovered...
Old 12-20-2012, 10:15 PM   #6597
mcma111
mcma111's Avatar
Oddometer: 11,901
10/40 is OK. Just let the engine warm up a bit when it's really cold out.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-20-2012, 10:40 PM   #6598
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,678
but that noise is normal? its 33 degrees outside and I just started it and the noise was back. why does the valve rattle?
Old 12-21-2012, 07:57 AM   #6599
mcma111
mcma111's Avatar
Oddometer: 11,901
Ok, Without me going to the garage and getting the OE service manual to look at this is the way I think this works.
The oil pump has two rotors. One rotor takes the oil from the sump or bottom of the engine and sends it up that pipe behind the front down tube to the oil tank under the gas tank. Oil then flows down the down tune and enters the other side of the pump. This side services the engine lubrication side of things. Now since the oil is cold as can be it's really thick and thus has a lot of resistance to get it moving. Now this is where the by-pass valve comes into play. The valve is spring loaded and when the thick oil is pushed through the pump the valve slides over uncovering another passage way to allow the thick oil to have some where to go. The spring slams the valve shut which is what your hearing. This happens over and over until the oil warms up some and becomes thinner taking the load off of the pump.
This is my idea of how this cycle works. If I'm wrong someone can correct my line of reasoning.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-21-2012, 11:31 AM   #6600
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,678
Thank you mcma.
Times are GMT -7.   It's 11:19 AM.
