Old 01-04-2013, 07:09 PM   #6661
crobox
crobox's Avatar
Oddometer: 196
Originally Posted by Moparmanpete View Post
I meant to say - Has anyone made their own windshield?
I've thought about it... and may yet do it a little further down the road.
I've had good results in the past putting gentle bends into plexiglass using a heat gun.
-Christian
Current Bikes: 1986 Honda XL600R, 1988 Hondasuki KLNX250R, 1988 BMW R100GS (dead)
Previous Bikes: Honda XL250 (2 of them), Honda XL600R, Kawasaki KLR600, BMW K1100LT, BMW R60/6, BMW K75, Husqvarna 430XC
Click HERE for my Cummins 4BT International Scout build thread
www.christianristow.com
crobox is offline   Reply With Quote
Old 01-04-2013, 07:30 PM   #6662
cynicwanderer
cynicwanderer's Avatar
Oddometer: 555
on mine it is, but they have different primary carburetors on some models of the xl600 (i.e. air mixture vs fuel mixture screw), so maybe yours is different. I'll re-verify the next time I have a chance to look at it.
Originally Posted by brucifer View Post
Are you sure "B" is vacuum? On my '84, it's the float chamber vent.
cynicwanderer is offline   Reply With Quote
Old 01-04-2013, 07:37 PM   #6663
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
I like those, not bad priced too! Thanks Mental!
Pete
See this Thread
http://www.advrider.com/forums/showthread.php?t=291581
Praise the Lord!!! I have seen the light!!! He has shown me the promised land!!! TT for now...
MentalGuru is offline   Reply With Quote
Old 01-05-2013, 01:17 AM   #6664
Stretchah
Oddometer: 52
Those GS Dakar Screens look great :)
I've read quite a bit about the XR fork conversions etc, but, just want to get it all clear in my head, so, if someone can confirm if this is correct that would be great :) I am 6ft 5 and am thinking a little extra height to the bike would be nice at some point plus upgrades to the suspension are always handy ;)
XR600 forks 91-92 will take an xl600 wheel and axle without bearing changes etc as axle same size. The forks are longer than XL ones and you'll lose the steering lock. 41 or 43mm? Use an XR650 top clamp so that you can add the ignition barrel.
XR600 rear shock will fit an xl600 swing arm and linkage and is a longer shock with remote reservoir, so, will even up the difference in height once XR600 forks are fitted.
XR400 forks have the most adjustment on them. I'm guessing these are shorter than XR600 ones, maybe closer to the XL600 ones? Do they have the same axle size as an XL?
Cheers Guys
____________________
84 Harris Magnum 2
84 XL600R
85 Vespa PK135
Stretchah screwed with this post 01-05-2013 at 02:02 AM
Stretchah is offline   Reply With Quote
Old 01-05-2013, 05:53 AM   #6665
brucifer
brucifer's Avatar
Oddometer: 1,668
Originally Posted by crobox View Post
Bruce-
It seems to make sense (to me) that it's vacuum... at least on my carbs. You can't really see it in the picture, because of the angle, but "B" is a short bent steel tube which just goes straight into the side of the intake-side of the main bore of the carb. The place it enters is actually visible in the pic as a small hole, or port, in the bore... about one inch to the left of the red oval surrounding "B". So it does stand to reason that it's vacuum. It doesn't go anywhere near the float chamber, at least not on mine.
By the way, thanks for chiming in with the original answer!
-Christian
You're very welcome but a wrong answer is worse than no answer! I'm really starting to doubt my aging brain capacity.
I'll dig my carbs out today and report back with what I find.
See above.
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 01-05-2013, 06:24 AM   #6666
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
A cheap cool DIY battery post from a fellow inmate I found...
It would be perfect for a budget lightweight battery conversion.
Originally Posted by Krono View Post
I see you're all adding some stuff to your bike, when im trying to remove as much weight as i can
She's now 128kg w/o fuel (282 pounds)
Last episode was battery : after seeing Ramz's blog, I inquired about the Shorai batteries.
I've also seen other brands like Antigravity, who advise the 4 cells for a 250cc.
All things considered (cheap way), I decided to make myself a 4 cell A123 battery, like in this video.
http://www.youtube.com/watch?v=UTDctiyUa9E
I bought 4 of these 7.99$ each
http://www.hobbyking.com/hobbyking/s...dproduct=16575
Ended with a 12 ounces unit (instead 88 for stock)
... and the engine cranked up right at first try !
Old 01-05-2013, 08:02 AM   #6667
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 654
Cheers Guys
The 91-92 XR6R are cartridge forks and shares and axle with the XL so the wheel will bolt up. It's a 43mm fork and I think it's something like an inch and a half longer than stock XL. I'm not sure about loosing the steering lock or not, but you'd use the XR6 lower triple or yoke and the XR650L upper because it does have a provision for the ignition barrel. It does not however have the two mount holes on the front that hold the headlight and gauge cluster, also the lower does't have a hole for the horn mount. That and you'll have to replace the brake line and maybe speedometer cable for they'll be too short with the longer fork.
The XR6 rear shock should raise the bike something around and inch.
The XR400 forks is a 43mm fork like the XR6 unit. They're about a half inch shorter than the XR6 forks and they do not share an axle. They use clamps on both sides of the axle instead of a threaded end on one side and I believe it's a larger diameter axle as well. You probably will have to change the brake caliper in addition.
My plan is to run the 98-04 XR250R fork because it seems to be the same length as the XL fork, same axle part number, and it's 41mm so it should fit in any euro market XL600LM yoke set with all the factory mount provisions for headlight and gauges. I already have new brake caliper setup waiting to use with my SM rotor so that's not a problem.
Carter Pewterschmidt is offline   Reply With Quote
Old 01-05-2013, 11:32 AM   #6668
cynicwanderer
Oddometer: 555
I checked. I have the California model, year '85. the B port was connected to the PCV (purge control valve) and controls it when it's running and vacuum is present. The PCV is only on california models. whenever the hose was off, the bike didn't run right. I finally removed the hose and added a rubber cap/plug that I bought at the car part store. I have the mixture/pilot screw in front/bottom. the '83 had an air screw at the rear/side of the carb.. I don't know if the '83 carb or the non-california carb has a different function of the B port.
See above.
Old 01-05-2013, 05:53 PM   #6669
RFVC600R
SAND EATER!
Oddometer: 524
Whoa I just bought a clutch cover for $31.50 on ebay! Bye-bye oil leak!
'83 Honda XL600R valve seat
RIDE RED!
RFVC600R is offline   Reply With Quote
Old 01-05-2013, 06:29 PM   #6670
brucifer
brucifer's Avatar
Oddometer: 1,668
I have the California model too. I actually think I'm smoking crack on this deal. I was unable to find my XL carbs but found a set for an XR600. They don't have anything there, so that tells me there is no float chamber vent on these. You guys are quite right. I'm sure when I find mine I'll see they have the vacuum port there too.
I'm getting the float chamber vent deal confused here with a couple inline four streetbike carbs I've worked on recently. Sorry for the confusion gents.
Old 01-06-2013, 09:54 AM   #6671
Stretchah
Oddometer: 52
Thanks Carter, that's exactly what I was looking for, much appreciated. Definitely a few things to think about there
84 Harris Magnum 2
84 XL600R
85 Vespa PK135
Old 01-06-2013, 10:18 AM   #6672
tractor4play
Oddometer: 83
im not so sure about the 1990ish xr 250 forks fitting in the xl600lm trees.
forks from the xr650r is a great upgrade but a lot more work involved.
tractor4play is offline   Reply With Quote
Old 01-06-2013, 12:43 PM   #6673
mcma111
mcma111's Avatar
Oddometer: 8,145
Sounds like it has an air leak on the carb to head intake. With the engine idling spray some carb cleaner around the intake. If there is an increase of RPM them it's got a leak.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-06-2013, 12:43 PM   #6674
Oddometer: 654
If the LM forks are 41mm like the XR250 forks then it shouldn't be a problem.
Old 01-06-2013, 02:42 PM   #6675
mcma111
mcma111's Avatar
Oddometer: 8,145
Next is to lean a pilot jet
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 09:35 PM.
