Old 01-07-2013, 06:56 PM   #6691
Homerb
Oddometer: 201
Just a thought, does your fuel have ethanol in it? The metal used in some honda carbs from the eighties doesn't like ethanol, which can cause rapid deposits to form in the carb, as the ethanol reacts with the metal. Doesn't happen with all honda carbys just to confuse matters.
Homerb is offline   Reply With Quote
Old 01-07-2013, 08:45 PM   #6692
crobox
crobox's Avatar
Oddometer: 196
Originally Posted by Schrauberklaus View Post
my Tank is selfmade with the original bottom part of the XL Tank
Klaus- I read this post a few weeks ago and it stuck in my head. I had to search to find it again....
I'm interested in this tank that you made with the bottom of a stock XL tank. (That's a really good idea!)
Do you have pictures of it? I would love to see.
Thanks,
Christian
Current Bikes: 1986 Honda XL600R, 1988 Hondasuki KLNX250R, 1988 BMW R100GS (dead)
Previous Bikes: Honda XL250 (2 of them), Honda XL600R, Kawasaki KLR600, BMW K1100LT, BMW R60/6, BMW K75, Husqvarna 430XC
Click HERE for my Cummins 4BT International Scout build thread
www.christianristow.com
crobox is offline   Reply With Quote
Old 01-07-2013, 09:09 PM   #6693
12120
12120's Avatar
Oddometer: 143
Got parts
RIcky stator is here, coil is her, new gasket for stator cover, now I just need some time. I would be nice if it wasn't raining sideways to. Anybody know if CR pegs will fit on the XL? I believe they are wider.
Chris
Sorry about your luck Pete. I think you outta just pull the carbs off and totally take apart and clean. Same goes for the fuel line/tank screen and tank. I you had that much crap in the carbs the need complete tear down. I would think. I hate the little mystery problems.
If you find yourself in a fair fight, your tatics are wrong.
'83 XL 600r
12120 screwed with this post 01-07-2013 at 09:42 PM
12120 is offline   Reply With Quote
Old 01-08-2013, 02:03 PM   #6694
Stretchah
Oddometer: 52
After my post regarding the fork upgrades, I just want to clarify a few things i've noticed that seem a little strange, Firstly am I right in thinking that standard xl600 forks are 39mm to 1985 and 41mm after?.
I was in the garage earlier and thought I'd have a closer look at mine and I noticed the tops are about 1 inch above the top yoke - is this normal for them to be set that way or are they normally flush with the top of the yoke?
I then noticed that they look like they've been machined from half way between the 2 yokes to the tops
So, I measured them and they are 43mm all the way up to where it looks machined and then 41mm. And from what Carter said the other day I am guessing a european top yoke has been used as its 41mm and has the ignition holder and screen/light holder brackets in the normal place.
Found a part no. KA4-831 on a little blue sticker on the right slider and have done a quick search and they seem to be coming up as from a CR250R or CR500R from 85-87 intrigued as to whether the machining is original or an alteration - most forks I've seen are normally the same diameter all the way up...
Heres a pic of the whole forks in case it helps... At the moment I'm thinking someone has done me a massive favour and may have already upgraded my forks
Let me know what you think? it may just be that I've misinterpreted what you guys have said and I've read and this is all normal
____________________
84 Harris Magnum 2
84 XL600R
85 Vespa PK135
Stretchah screwed with this post 01-08-2013 at 02:27 PM
Stretchah is offline   Reply With Quote
Old 01-08-2013, 02:50 PM   #6695
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Originally Posted by Moparmanpete View Post
Manual states they are to be flush with the top of the yoke.
My XL is an 87 and has 39mm forks
His bike is a Euro model so it's probably way cooler....
Praise the Lord!!! I have seen the light!!! He has shown me the promised land!!! TT for now...
MentalGuru is offline   Reply With Quote
Old 01-08-2013, 03:49 PM   #6696
mcma111
mcma111's Avatar
Oddometer: 7,965
[QUOTE=Stretchah;20429659]
[QUOTE]
You see that line on the right fork tube about 1/4" from the top of the tube? THAT is what you line up to the top of the triple clamp.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-08-2013, 04:34 PM   #6697
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
I suspect a fork swap has been done. Maybe CR forks and lower with them machined to fit the stock upper. Measure the tubes at both clamps (some cartidge forks neck down between the triple clamps). Measure the axle size to see if it is 15 or 17mm in size.
Just curious...
Old 01-08-2013, 11:29 PM   #6698
Stretchah
Oddometer: 52
Cheers Guys and mental guru hopefully one day it'll be cooler, but, not in it's current state
I was thinking the tops should be pretty much flush. I'm guessing they may be a little longer and a previous owner did it like that to even the ride height as seems to be a standard rear shock. That seems to be good news though as wanted to raise the ride height, just got to get an XR rear shock now
It does drop from 43mm to 41mm on the yokes...if they are like that as standard it may be another upgrade option for us :) I'll measure the axle too especially as just bought a spare front wheel Hopefully I can get it to fit without issues...
Moparmanpete, Glad to hear that you've sorted your carb problem, enjoy
Andy
84 Harris Magnum 2
84 XL600R
85 Vespa PK135
Stretchah screwed with this post 01-08-2013 at 11:39 PM
Old 01-09-2013, 05:05 PM   #6699
12120
12120's Avatar
Oddometer: 143
Ditto its alive
Yay Mine is also alive. Glad you got your's sorted Pete! I did not get to go for a ride. My tags are expired, and the plate is from OR. I have the bike in my name, just did not get a WA plate on it cause the tags where still good on the old one. I know bend the rules. It was also raining cats and dogs and about 40 degrees. New coil new ricky see what brakes next.
Chris
'83 XL 600r
Old 01-09-2013, 08:52 PM   #6700
Dracus124
SAND EATER!
Oddometer: 472
I got a problem, I bought a new Volar o-ring chain. I guess you gotta use a special tool to the press the rivets on the masterlink and I can't afford the tool
What should I do? the damn tool is more than the chain!!
Can i use a master link from a regular o-ring chain??
'83 Honda XL600R valve seat
RIDE RED!
Dracus124 is online now   Reply With Quote
Old 01-09-2013, 09:02 PM   #6701
Homerb
Oddometer: 201
Im assuming the link is a rivet type master link? Id just peen the riverts over with a hammer. Or you could use a normal master link. I did on my last bike which was dynoed at 73rwhp and the link held fine.
Old 01-10-2013, 12:49 PM   #6702
Dracus124
SAND EATER!
Oddometer: 472
The bike shop cut me some slack, they installed the chain for free even though I didn't purchase it from them. The mechanic told me my chain is a cheap POS and should replace it soon. And then he told me that the XL isn't worth owning and I should sell it for a 650L. "once this thing blows, that's it! it'll be the same as having no bike" Sorry bro, this thing eats XRLs . But according to him, the engines of the XL and the XRL have NOTHING in common.
I understand my bike looks like a junker, but it's not worthless, kinda pissed me off a little, but I kept my mouth shut since he was installing it for free.
RIDE RED!
Old 01-10-2013, 01:26 PM   #6703
brucifer
brucifer's Avatar
Oddometer: 1,619
That mechanic sounds like a real winner...
2006 KLR650 2002 Yamaha FZ1-2002 Husaberg FC550E w/2008 FE550E engine-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 01-10-2013, 01:38 PM   #6704
Mike the Yank
Oddometer: 87
Talking
I think that is WHINER
It's a lot easier to apologise than to ask permission
My Stator rebuild pics http://advrider.com/forums/showthread.php?t=835339
Mike the Yank is offline   Reply With Quote
Old 01-10-2013, 02:59 PM   #6705
mcma111
mcma111's Avatar
Oddometer: 7,965
Opinions are like, well you know.
To each their own.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 02:01 AM.
