Old 01-13-2013, 07:32 PM   #6721
bnjgriffin
stoked mostly
bnjgriffin's Avatar
Oddometer: 22
Originally Posted by Moparmanpete View Post
Ok so I just got done ajusting alittle more added some SEA FOAM and she starts great and idles smooth and revs pretty good.
I am a happy man and there is peace on earth (that I must disturb with my shananagns)
My foot is sore but managable after all the kicking the past couple of days, can't be good , I must be getting XLed
We'll see how it starts cold.
Thanks for the help guys Much appreciated
Pete
Hey Pete,
If you have a California Carb, there is a couple of great photos back on page 163 from cynicwanderer which show what ports should be open or plugged. Hope that helps.
bnjgriffin screwed with this post 01-13-2013 at 08:37 PM
bnjgriffin is offline   Reply With Quote
Old 01-13-2013, 08:17 PM   #6722
bnjgriffin
stoked mostly
bnjgriffin's Avatar
Oddometer: 22
Thanks buddy I will check it out, Right now I have some 1/4in fuel line pieces with pantyhose glued to the ends on them.
Edit- the ones that he has listed to vent are the ones I have just covered. I worry about just leaving those uncovered because I was running two fuel filters- the petcock one and a right angle one, and my carbs were just freshly rebuilt and the bowls were still dirty.....WTF
I am not sure what condition your tank is in but I found out that mine had some small rust/flaking inside (way down where it was hard to see) so it just kept sending "small" particles through the filters and these carbs are ultra sensitive so it kept causing blockage until I ended up changing out the tank and recleaning the carbs one last time. Maybe you can run a few cups from your petcock directly into a glass container just to make sure there is nothing getting by?
Old 01-13-2013, 08:26 PM   #6723
bnjgriffin
stoked mostly
bnjgriffin's Avatar
Oddometer: 22
Thumb
Ok gents how loose can I run my valves right now they are at spec .002 and .004 and the other day after a 35mile ride I went to restart it an hour later and the kicker was way too soft. I have NO decompressors hand nor kicker.
On another note I belive it is running lean at highway speeds and getting too hot.
Your valves sound like they are perfect and the kicker does get a little softer when the engine is hot which unfortunately makes it harder to figure out when your'e at the right spot to giver her a kick,
According to my manual, the stock jets are: primary #118, secondary #115, & slow #62. I am at sea level and I have an 87' California model which has all of the emission equipment removed and I changed my jets to 120, 118, & 65. Now she starts with 1-2 kicks every time and runs great even after fully warmed up. In my experience, these bikes seem to like lots more fuel than the stock jets allow.
Old 01-13-2013, 09:04 PM   #6724
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 594
Ah, here is a good spot to ask a related question. I've been setting my valves to the newer spec used on the XRL: .004 & .005
I had been using the original spec of .002 & .004
Anybody else here with the older RFVC doing the valve spec upgrade?
Ghost_Mutant is offline   Reply With Quote
Old 01-14-2013, 02:16 AM   #6725
RFVC600R
SAND EATER!
Oddometer: 477
Whats the effect? more engnine noise??
'83 Honda XL600R valve seat
RIDE RED!
RFVC600R is offline   Reply With Quote
Old 01-14-2013, 05:13 AM   #6726
Edouard_Bracame
Oddometer: 69
Cylinder Boring
Here's the boring of my cylinder with a Van Norman Boring Bar.
And another XL600LM that I will start to rebuild the engine next summer.
Edouard_Bracame is offline   Reply With Quote
Old 01-14-2013, 06:10 AM   #6727
brucifer
brucifer's Avatar
Oddometer: 1,623
Hey GM. For what it's worth, my machinest guy who knows these (RFVC) engines very well has always said the stock Honda clearance was too tight. I think mainly because of oiling issues but also .002 doesn't allow much for thermal expansion. And we all know these bikes have their fair share of both.
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 01-14-2013, 06:21 AM   #6728
Edouard_Bracame
Oddometer: 69
A clearance of 0.1mm at the intake and 0.12 at the exhaust is OK
Old 01-14-2013, 01:19 PM   #6729
RFVC600R
SAND EATER!
Oddometer: 477
Is there any hard tuned XL600Rs? I'm sure there is.... I want to know what I can do to increase the power without hindering long term usefulness too much. I'm thinking about getting a second job just to tune this beast. Drooling over XRs only parts but do i have other options??
Don't get me wrong, it still wants to wheelie out of turns and has plenty of power, but I want to make this MY bike.
I got to pull the engine to stop the notorious oil leak from the valve cover, might as well make it worthwhile. I can live with a leak for a few more months while i gather parts.
All I know is the receipt from the PO's last rebuild said "WISECO HI-COMP" as one of the new parts listed but it doesn't say the ratio and the PO didn't know either
RIDE RED!
RFVC600R screwed with this post 01-14-2013 at 01:30 PM
Old 01-14-2013, 05:37 PM   #6730
Ghost_Mutant
looking for bionics
Oddometer: 594
Originally Posted by Dracus124 View Post
Whats the effect? more engine noise??
It might be noisier but I couldn't tell. My thinking is the same as Bruce. Honda must have changed the clearance specs after real world testing on the early RFVC
Right, but I was wondering if its better for longevity with the larger clearances.
0.1/0.12mm are the metric versions of .004/.005in for those of us in the US.
I can't think of a single reason not to use the newer XRL specs, but I was looking for feedback from someone who thought differently.
Old 01-14-2013, 06:56 PM   #6731
Ghost_Mutant
looking for bionics
Oddometer: 594
No, I had to wait until after work before I could even check out the new posts on ADV. No posting on the job, big brother and all of that jazz
Old 01-14-2013, 11:07 PM   #6732
Edouard_Bracame
Oddometer: 69
Connecting Rod
Do you guy's have some advise on the two different brands of aftermarket Connecting rod....Hot rod vs Pro-X ?
Wich one would you recommend?
Ed
Old 01-15-2013, 04:43 AM   #6733
mcma111
mcma111's Avatar
Oddometer: 7,981
Pro X
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-15-2013, 06:35 AM   #6734
Edouard_Bracame
Oddometer: 69
I ordered a Hot rod because there is a copper/bronze bushing at the rod end...Also I just repaired one engine with a Prox connecting rod and the lower end bearing was seized, the cause was probably not the rod itself but when the Honda guy's rebuild the engine sometimes ago, they forgot to install the big washer on the crankshaft left bearing, instead they installed it behind the flywheel outside of the crankcase...not a good idea....
I thinl that the big washer keeps the oil trapped against the left bearing ...but not 100% sure about this.
Old 01-15-2013, 12:29 PM   #6735
Stretchah
Oddometer: 52
Hey guys,
Just a quick update re. the work to fix my sunken valve seats etc. The garage called me today and it turns out the head is cracked between the valve seat and the spark plug
They are going to weld the head (apparently it will be like new) and replace all the valves and guides plus a new cam chain rings etc and gaskets and a few other parts i needed to rebuild it, total cost is expected to be around £800 for everything
On the upside at least the barrel just needed a hone and new rings
It is a lot of cash, but, I'm just thinking that at least I'll know that everything is sorted on it then and fingers crossed once It's fixed it shouldn't need to be done again....
____________________
84 Harris Magnum 2
84 XL600R
85 Vespa PK135
Stretchah is offline   Reply With Quote
Times are GMT -7.   It's 06:07 AM.
