Old 03-20-2013, 10:40 AM   #7156
joexr
Oddometer: 3,773
For a start you need to find out it the threads are the same as 1 of the 2 sizes there are of banjo bolts. If it is then that would be ok. I dont remember who , but I do know that somebody makes lines to go straight into the caliper in place of ones using a banjo bolt so im thinking the threads are probably the same. I like Galfer lines and pads and theyre easy enough to find. At one time I bought MSR lines and the package said Galfer.
Old 03-20-2013, 11:46 AM   #7157
davek181
davek181's Avatar
Oddometer: 886
10x1.25 threads on the master I checked.
davek181 is offline   Reply With Quote
Old 03-20-2013, 06:46 PM   #7158
MAXNX
Oddometer: 52
Originally Posted by Carter Pewterschmidt View Post
Bringing this back now that the Acerbis tank is done steeling the show. lol
I know people out there has been running different brake lines. What have you used?
I am using the Galfer stainless line for xr400. I just used a banjo bolt that was the same length/threads etc as the caliper for the master,maybe a bit shorter.
Seems like it should work fine, didn't have any dot 4 to test out with.
When I installed the caliper the lower bolt hit the rotor, it seems as though the mount for it is a bit thinner than the stock forks, top is fine.
At first, I kept thinking my spacing was off, but it was the bolt rubbing. I have a washer on it now, but need to pick up one 5mm shorter.
MAXNX is offline   Reply With Quote
Old 03-20-2013, 09:21 PM   #7159
cam14
Oddometer: 181
There is typically a copper washer on both side of the line with the banjo bolt going through them, therefore the banjo bolt is suppose to be 2 coppers washes longer. Hope this makes sense. Have any pics?
cam14 is offline   Reply With Quote
Old 03-20-2013, 09:24 PM   #7160
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,850
Got the gas tank done. That seal all worked great and cured in 8 hours I plan on doing a write up and I have lots of pics.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is online now   Reply With Quote
Old 03-20-2013, 09:26 PM   #7161
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,850
Originally Posted by JimRidesThis View Post
Has anyone go a spare RHS side panel for my XL600 that I could buy? Colour unimportant.
You're in luck! pm me i g2g work. free if you pay shipping buddy
Old 03-21-2013, 02:15 AM   #7162
m2h
"Old guys rule"
m2h's Avatar
Oddometer: 131
LED lights
Just bought some flexible rear indicators for the '86 as im sick of the plastic ones breaking off when some dumb ass climbs aboard. Thought I would try some LED ones. After I got them online I noticed an ad next to them for an "LED FLASHER" Any electrical guru tell me is this mandatory with led's or will the standard one do? Front indicators are originals. Also the tail light brightens in time with the indicators which is a bit annoying. Any clues?
MRH
PS Still waiting for dam crank case gaskets and a very expensive crank brg.
m2h is offline   Reply With Quote
Old 03-21-2013, 03:09 AM   #7163
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,850
You need LED flashers
Old 03-21-2013, 05:39 AM   #7164
davek181
davek181's Avatar
Oddometer: 886
I used a flasher that I got from NAPA parts store. It is universal, two pin, and capable of figuring out out to keep it's cool and flash with any light combo. I have 20 watt standard front signals for visibility and LED for rear and it works great with them. The package claims one to ten light capable 300 watt, non thermal type. It is cheap too, $10.00. Their part number is EL-12.
Old 03-21-2013, 01:59 PM   #7165
JimRidesThis
Local celebrity
JimRidesThis's Avatar
Oddometer: 293
PM'd you
1985 XL600R "Tamworth"
1992 TDM850 "Ivy" A work in progress
JimRidesThis is offline   Reply With Quote
Old 03-21-2013, 03:19 PM   #7166
Carter Pewterschmidt's Avatar
Oddometer: 1,086
No fork springs for the XL600R. Race Tech finally told me that they can't get them. So kids, if you want to change the springs on the front of your XL600R you need to swap your forks.
Carter Pewterschmidt is offline   Reply With Quote
Old 03-21-2013, 03:39 PM   #7167
lookfar
from the land of OZ
Oddometer: 627
What about getting a spring works to make them?
If someone had the specifications of the springs, diameter of the wire, free length, etc, it should be a simple matter to get them made.
If a group got together, they should be a bit cheaper...no good for me, I am on the other side of the planet, but should be easier for those in the CONUS.
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 03-21-2013, 03:57 PM   #7168
davek181
davek181's Avatar
Oddometer: 886
You can do the Ghetto fork spring stiffening trick like me. Cut them 10% shorter to stiffen them 10% and add spacers to make up the length.
Old 03-21-2013, 04:09 PM   #7169
joexr
Oddometer: 3,773
You could also make aircaps out of your fork caps. Also gives progression and adjustability.
Old 03-21-2013, 04:22 PM   #7170
JimRidesThis
Local celebrity
Oddometer: 293
You could try Hagon for fork springs - http://www.hagon-shocks.co.uk/ - they'll ship worldwide.
Times are GMT -7.   It's 05:32 PM.
