Old 04-03-2013, 04:44 PM   #7261
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,991
Got to learn how to use my multimeter thanks to youtube and I found my book so I could finally jump in.
My ignition coil is dead
Primary 0.2 spec is 0.8
Secondary 14.29K spec is 4.1K
Ebay, here I come!
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 04-03-2013, 09:44 PM   #7262
12120
Indenturedx5
12120's Avatar
Oddometer: 479
Gas cap
Anyone got a cap for the stock XL tank? One without a lock. I don't know why I have a locking cap on my bike, and it for some reason just bugs me. So if someone has a spare non-locking cap around let me know so I can talk you out of it.
Chris
PS- I want one of your braces to Crobox
If you find yourself in a fair fight, your tactics are wrong.
'83 XL 600r
12120 is offline   Reply With Quote
Old 04-03-2013, 09:59 PM   #7263
lookfar
from the land of OZ
Oddometer: 653
Chris
Here is one
http://www.ebay.com.au/itm/1983-HOND...item35c24891c7
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 04-04-2013, 08:18 AM   #7264
Plc_qc
Hondadventure Rider!
Plc_qc's Avatar
Oddometer: 1
My new baby ! :D
here's my new '83 xl 600R :) , just traded it for my snowmobile , just one problem... battery won't charge .. any solutions guys ??
Plc_qc is offline   Reply With Quote
Old 04-04-2013, 08:30 AM   #7265
crobox
crobox's Avatar
Oddometer: 324
Thanks for the compliments about the brace, guys.
Unfortunately it doesn't make much sense for me to make stuff like this for other people because I am just one guy with some older manual machine tools, so it takes me most of a full day to make something like that brace and it wouldn't be cost-effective to start making them for sale. In other words they'd be too expensive, especially when you take into account that a brace can be purchased on the web for around $100.00. If I could get my CNC machine working, then it would be a different story. But I've had that machine for 8 years, not running, and I'm not smart enough to bring it back to life. I did make an exhaust adapter for my Cummins 4BT swap into my Scout a few years back (post # 70 on this page), and that adapter was something that simply could not be found anywhere else. For that reason I was able to sell a few of those to other Cummins geeks for about $300.
Anyway, I rode the XL last night for the first time with the brace, and also for the first time at night, and also for the first time with a 16 tooth front sprocket (16/41). The brace worked great... no more front end wobbles. The dual headlights are AWESOME. The whole damn road is lit up, in a very wide angle. On bright setting the illumination rivals any car I've driven. And the 16 tooth front sprocket makes the bike very "leggy" .... too much so in fact. I'll go back to 15/41 today, and then maybe experiment with 15/40 or 15/39, if I can find those sprockets. By the way, a 16 tooth sprocket is, I believe, the biggest one you can stuff in the front.
Cheers,
C
Current Bikes: 2006 KTM 950 ADV S, 2002 XR650L, 1988 Hondasuki KLNX250R
Previous Bikes: 1986 Honda XL600R,Honda XL250R (2 of them), Honda XL600R, Kawasaki KLR600, Honda Nighthawk, BMW K1100LT, BMW R100GS, BMW R60/6, BMW K75, Husqvarna 430XC
Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com
crobox is offline   Reply With Quote
Old 04-04-2013, 10:34 AM   #7266
davek181
davek181's Avatar
Oddometer: 940
16T is the largest sprocket you can physically run up front, in fact it kinda scrapes on the front cover a bit too. I ran 16/45 on mine for many many miles, the only drawback I found was 1st gear was a little high for some offroad adventures. When my crankshaft broke last year and I had to split the cases I put in an NX 5th gear which enables me to run a 15T front and have an overall ratio in fifth that is close to stock fifth and a 16T.
I am running a 14/45 now and kind if like it, it gives me a lower first and approximately the same fifth as a stock box with the stock gearing 15/45.
davek181 is online now   Reply With Quote
Old 04-04-2013, 05:46 PM   #7267
brokeagain
Oddometer: 515
Ebay, here I come!
I purchased a new one off bike bandit for not too much money, around $40 I believe (unlike the coils for my Shadow .... like $100 a piece!)
I think it'd be worth getting a Honda part for that, but that's just my opinion. Good luck!
brokeagain is offline   Reply With Quote
Old 04-04-2013, 07:40 PM   #7268
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,991
I bought a Caltric, seems like a decent company
Old 04-04-2013, 07:54 PM   #7269
davek181
davek181's Avatar
Oddometer: 940
The charging system is a separate set of coils on the stator from the ignition and lights. The bike can run and not charge if those burn out, happened to me.
You need to do some tests on the stator first, then there is a rectifier and a regulator after that. There should be 14 volts or so coming out of two leads on the stator for lights, and charging. The ignition will put out quite a bit more, like 60 or more volts at idle..
Old 04-05-2013, 04:09 AM   #7270
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,991
Cheers,
C
That sucks that you can't make some of those braces I've been wanting to get fork braces for a while, and I thought it'd be cool to have something made by a fellow advrider
I just read your threads on the Scout, there's some good reading there! I hope I eventually acquire skills to do cool projects.
Old 04-05-2013, 04:20 AM   #7271
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 390
Look here
http://www.fastfromthepast.com/servl...-XL600R/Detail
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Old 04-05-2013, 01:33 PM   #7272
crobox
crobox's Avatar
Oddometer: 324
Thanks man.
I guess what I was trying to say was that I could make those, theoretically, but they'd cost about three times as much as the "Fast from the Past" brace, and I doubt anyone would really want to pay that much. One guy, working by himself.... it just takes a long time to make stuff like that.
PM me if you REALLY want one, and we'll talk.
Thanks again about the Scout. I re-read some of my threads recently, and I'm not even sure about some of what I was talking about. It's funny... you get so deep into a project and you start using all this lingo that makes sense to all the dudes who are "in" it with you, but probably doesn't make much sense to anyone else. Anyway, it was fun. And I still drive the Scout.
Cheers,
Christian
Old 04-05-2013, 01:42 PM   #7273
crobox
crobox's Avatar
Oddometer: 324
I took the 16 tooth front sprocket off, mostly because with the 16/41 I was running I could not get any slack in the chain. Even on the "slackest" setting at the rear axle, the chain was taught. Of course it's also true that the gearing was a little too tall, even though I do sorta like to go fast on the highway and I'm not really trail-riding the bike right now.
I'm currently looking around for a 14 tooth front and a 39 tooth rear. I would run a 15 front with the 39 rear for regular street duty (2.6:1 ratio), and carry a 14 front with me if I go on a dual-sport trip, so I could swap it out (2.786:1 ratio). These two ratios nicely bracket the ratio I've been riding lately, which is 2.733:1 from a 15/41 setup, which I feel is slightly low for the highway and slightly high for the dirt. That's what I'm thinking at the moment, anyway.
-C
Old 04-05-2013, 01:51 PM   #7274
crobox
crobox's Avatar
Oddometer: 324
Originally Posted by TonyfromOR View Post
crobox: You might try running it without the guts of the supertrap (straight pipe) that should lean it out a bit to further test your theorey. Should only take a few minutes to do.
I've been thinking about this comment since I read it about a week ago. I am just now grasping the fundamentals of carburetion and jetting, but the role of the exhaust is frankly still a bit of a mystery to me.
Like I said, I've been pondering the comment, and I'm confused. To my way of thinking, a stopped-up muffler would keep more air in the cylinder during the exhaust stroke, thereby increasing the total amount of air in the mixture and making the mix lean.
Conversely, it seems to me that a free-flowing pipe would move air out of the cylinder more efficiently, reducing the total amount of air, thereby making the mix rich.
But all this hypothesizing is actually opposite of what you are saying. I totally believe that I am wrong... I just don't really understand why....
Can anyone explain?
Cheers,
Christian
Old 04-05-2013, 03:08 PM   #7275
davek181
davek181's Avatar
Oddometer: 940
More airflow for a fixed amount of fuel causes leanness regardless of what causes the increased airflow.
Times are GMT -7.   It's 07:15 AM.
