Old 04-27-2013, 02:52 PM   #7411
mcma111
mcma111's Avatar
Oddometer: 12,066
No
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-27-2013, 02:53 PM   #7412
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,731
I don't know what to do! Ya'll prolly think I was hallucinating or something lmao. Damn fast response!
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust, big tube header, 6 Sigma stage 3 carb mods
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is online now   Reply With Quote
Old 04-27-2013, 03:13 PM   #7413
MartiniUp
Oddometer: 1,858
That green color comes from seafoam. The fuel system treatment of the idiot.
Have used Seafoam for 15 yrs plus with zero discoloration to anything. And in my 2stk with powervalves I no longer have to clean them between top ends. And bike has sat for up to nine months due to illness or injury and starts and runs fine. I will continue to use it with every batch of premix.
MartiniUp is offline   Reply With Quote
Old 04-27-2013, 03:16 PM   #7414
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,785
If the engine gets really hot the valve seat may come loose. When it cools down it will stick on the hole again. Eventually it will get so loose that it will fall or break up into pieces.
Hate gets you nowhere.
Old 04-27-2013, 05:43 PM   #7415
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,731
thats scary So tear it down!
Old 04-27-2013, 05:47 PM   #7416
Reposado1800
Juicy J fan!
Oddometer: 5,785
I am in the middle of something similiar. Engine Dynamics is rebuilding my head right now and doing it up right.
Old 04-28-2013, 09:57 PM   #7417
Homerb
Oddometer: 458
I got a bit bored on saturday night and decided to put the new stickers on my xl600rmg. Tank stickers, a sticker on the front guard, and pro-link stickers on the swingarm.
What could go wrong???
Well, now when l turn on the ignition, the main 20amp fuse blows immediately. From putting on new stickers? WTF?
Obviously a short somewhere, but no idea where to start looking. Might unplug everything, and start connecting things one at a time until fuse blows again. Gotta love old bike electrics, not.
Homerb is offline   Reply With Quote
Old 04-28-2013, 10:02 PM   #7418
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,731
I was blowing fuses when I had a short in a crap ass ebay turn signal.
Old 04-28-2013, 11:52 PM   #7419
Homerb
Oddometer: 458
Interesting. Did fuse blow only when blinkers were used, or as soon as ignition was turned on? I ask this because l bodged up a blinker that was missing a bit. Seemed to work ok at the time.
That'll be the first thing l disconnect.
Homerb screwed with this post 04-29-2013 at 01:00 AM
Old 04-29-2013, 04:29 AM   #7420
Homerb
Oddometer: 458
Well l just walked out into the garage, and had a good look at the bike. All switches were in the off position, except for the kill switch. Mmmm, I wonder. Turn kill switch to on, put in new fuse and bingo! Ignition on, fuse doesnt blow, lights work, engine starts. Turn kill switch off and engine dies and fuse blows. Prior to this, the kill switch didnt work at all, and now its blowing the main fuse. What is going on????
Old 04-29-2013, 06:52 AM   #7421
brucifer
brucifer's Avatar
Oddometer: 2,427
It sounds like you somehow have the kill switch wired into the battery power. It should only be wired to the ignition circuit.
2014.5 Kawasaki KLR650 NE-2008 Yamaha TTR110-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 04-29-2013, 08:02 AM   #7422
davek181
Oddometer: 856
I would need to see a wiring diagram to see if it is different than the XL's over here, but on the XL here the ignition is run from the stator independent from the battery/fused circuits. The kill switch merely grounds the ignition wire to shut off the bike, so it is a ground circuit. All I can imagine is it got crossed with the fused D/C circuit.
davek181 is offline   Reply With Quote
Old 04-29-2013, 02:33 PM   #7423
Reposado1800
Juicy J fan!
Oddometer: 5,785
I got my swingarm bearings in with the help of the motion pro tool. I had to tap them in as the threaded device was too short but the bearing installer does a great job of holding them properly and they tap in pretty smoothly.
Old 04-29-2013, 05:48 PM   #7424
Reposado1800
Juicy J fan!
Oddometer: 5,785
What are you guys doing for a lower chain slider when the original falls apart? Can a roller be bolted into the same place?
Old 04-29-2013, 06:12 PM   #7425
davek181
Oddometer: 856
I put a roller on mine once on the front and hated the noise of it, so went back to a slider. Rear slider near the sprocket was still available from Honda last I needed one. There is always eBay too.
Times are GMT -7.   It's 04:37 PM.
