Old 05-03-2013, 05:01 PM   #7471
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,915
At this moment I'm not sure, I got gas, spark, and plenty of compression. I'm taking a break from it for a few days,its to damn hot outside.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 05-03-2013, 05:12 PM   #7472
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,915
I said screw the break and I got it fired, the noise has returned!! steve pm sent, I love this bike too damn much
Old 05-03-2013, 05:35 PM   #7473
mcma111
mcma111's Avatar
Oddometer: 12,403
Since there has been a recent rash of valve seats trying to jump ship I suggest you stop running the engine and preform some exploratory surgery before you hear the BIG BANG $$$$$$$$$$$$$$
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-03-2013, 05:49 PM   #7474
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,915
Yeah Im about to give it a good bath and rip it out the frame. Such an awesome bike I dont want a different one
Old 05-03-2013, 05:52 PM   #7475
mcma111
mcma111's Avatar
Oddometer: 12,403
I wish I still had a XL in the stable. My favorite is the 1987 RWB. I had an 83 back when with a seriously pumped motor.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-03-2013, 07:45 PM   #7476
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,797
These bikes need a certain minimum investment to be done right. Everthing needs to be torn down and looked at at nearly 30 years old.
The upside is tearing them down and putting them together is more fun than riding them.
As lond as it wasnt run out of oil or.exploded the cases, it wont be much of a problem.
Hate gets you nowhere.
Old 05-04-2013, 12:29 AM   #7477
Homerb
Oddometer: 462
Originally Posted by mcma111 View Post
Well if I had the engine in front of me I might be able to say where that piece came from but from where I'm sitting I can't see it.
I can fix that! Just got my smugsmug account sorted, and as soon as the camera battery is charged lm going to take about a thousand photos. Stand by.
Homerb is offline   Reply With Quote
Old 05-04-2013, 12:31 AM   #7478
Homerb
Oddometer: 462
Originally Posted by Reposado1800 View Post
It looks like a piece of the clutch basket, or something was dropped inside during assembly. Not many aluminum parts inside to do that.
Ther clutch basket was the first thing l thought of too. It all looks fine to me though. Stand by for pics.
Old 05-04-2013, 02:59 AM   #7479
Homerb
Oddometer: 462
Originally Posted by lookfar View Post
Is the piston complete?
Hasn't got a bit missing from the skirt?
Nope, triple checked piston and its perfect.
Old 05-04-2013, 03:04 AM   #7480
Homerb
Oddometer: 462
Clutch basket and rest of clutch all there, if a bit grubby.
Old 05-04-2013, 03:11 AM   #7481
Homerb
Oddometer: 462
Originally Posted by davek181 View Post
Interesting shrapnel indeed. There appears to be no paint on it and as I remember all the internal cases are painted. I took a look at my spare cases and see nothing that looks similar to that and unpainted. If I had the parts to rotate around in my hand and study I might get a better idea too.
I am curious what broke the cylinder without hurting the piston. If something big enough to do that got around the crank area to do that there should be other signs too. If the same piece did both then it had to travel a rather circuitous path to get there.
The broken pieces look to have a polished/finished surface on it, possible former snap ring groove? did you look real close at the clutch hub and basket? Is there any signs of former threads? Did you account for all the broken cylinder pieces too?
Not trying to insult intelligence or anything, just rambling on and guessing myself from clues present.
I had a tiny piece of something get loose in my engine after many thousands of miles of running and it got between the crank gears out at the oil pump gears. It bent the end of the crank a little and I was able to bend it back to true. Curiously a few miles after repairing that the crank web broke on the flywheel side. (possibly unrelated to that incident) It wasn't till actual reassembly with a different crank that I found the broken piece, it was stuck to the pulse coil.
Ive had a real close look at the shrapnel and by the look of one piece in particular, Im starting to think it may have been left in the engine by the knob who rebuilt it. (me) It looks less and less like a piece of the engine and more like a foreign object.
Particularly in the next photo, see there's a hollow rectangular section in the middle.
I can't think what part of the engine it could be, any ideas???
Yes, I bite my nails!!!
Old 05-04-2013, 05:50 AM   #7482
mcma111
mcma111's Avatar
Oddometer: 12,403
Did the PO have to replace anything else besides the piston?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-04-2013, 06:32 AM   #7483
Homerb
Oddometer: 462
No PO was mechanically challenged, and did nothing to the bike while he owned it. Had it professionally serviced though. Rode the bike for years with knackered steering head bearings.
I rebuilt the motor. New piston & rebore, Pro X conrod kit, all new bearings, seals and gaskets & camchain. New valve guides, Kibblewhite valves and springs. I also fitted an oil cooler off a DR200 Suzuki. Can't see how oil the cooler could have produced the shrapnel, though.
Old 05-04-2013, 08:11 AM   #7484
mcma111
mcma111's Avatar
Oddometer: 12,403
So that rules out the PO. Only thing I can come up with is perhaps something around the kick start shaft let go.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-04-2013, 09:11 AM   #7485
Carter Pewterschmidt's Avatar
Oddometer: 1,092
Werd, check the inside of the clutch cover.
Carter Pewterschmidt is offline   Reply With Quote
Times are GMT -7.   It's 09:51 PM.
