Old 05-06-2013, 01:22 PM   #7501
mcma111
mcma111's Avatar
Oddometer: 12,385
Unless the seat has failed and come apart you may have dodged the dead piston bullet. Only one way to confirm. Tear down the top end. Black Diamond is the good aftermarket brand of valves and springs.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-06-2013, 01:28 PM   #7502
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,898
the engine has excellent compression, I can still stand on the kick starter. I'm looking for the rebuild receipt from the PO to see what all was repaired last time. I'm hoping I just need head work but I don't know too much about rebuilds and all that. I know I need to yank the engine out but I won't have access to a garage for a couple days. I read all kinds of threads about rebuilding 4-stroke engines and it seems my problem isn't anything compared to some of the crap I've read.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 05-06-2013, 02:03 PM   #7503
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,797
Originally Posted by Dracus124 View Post
So how much do ya'll reckon an XL600 with a dropped seat is worth? $800? $500? 15003 miles a lil rough. Its gonna cost me a pretty penny to fix this issue
I wouldnt get too upset. Used heads are coming up all the time on ebay if you have to go on a shoestring.
On a side note, I cant believe some of the idiots selling obviously broken worthless parts on ebay. Trolling for suckers I guess.
Hate gets you nowhere.
Old 05-06-2013, 02:21 PM   #7504
brokeagain
Oddometer: 450
Originally Posted by mcma111 View Post
When in doubt replace the Pulse Generator
The pulse generator reads about 60 Ohms between the blue/green wires.
Spec from the manual is 510-570 Ohms.
I'm going to go ahead and assume that's bad, then replace it.
Thank you, Steve.
brokeagain is offline   Reply With Quote
Old 05-06-2013, 03:04 PM   #7505
davek181
davek181's Avatar
Oddometer: 901
I hope this isn't too late, there is a rebuilt head for an 84 on ebay right now, last bid I saw was $69.00 reserve not met. Item # 171030961471
davek181 is offline   Reply With Quote
Old 05-06-2013, 03:27 PM   #7506
Slideways#96
scooter trash
Slideways#96's Avatar
Oddometer: 570
parts resource for older xl600's
Needing a clutch kit for my 87 xl600. Any online resources would be greatly appreciated.
Slideways#96 is offline   Reply With Quote
Old 05-06-2013, 04:04 PM   #7507
davek181
davek181's Avatar
Oddometer: 901
I bought an EBC off eBay with heavier springs for mine. I would forgo the heavy springs next time since effort is also higher. Next opportunity I have to pop the clutch cover the stock springs are going back in.
The clutch works well, no complaints, has a linear feel that was lacking in the original one.
Old 05-06-2013, 04:28 PM   #7508
Slideways#96
scooter trash
Oddometer: 570
Thanks, I appreciate the input!
Old 05-06-2013, 04:39 PM   #7509
kmequint
kmequint's Avatar
Oddometer: 57
Is it possible the piston and bore is damaged too? or is it all head damage until it finally gives? I have valve seats and what is black diamond valves? google time
Kibblewhite makes the Black Diamond valves
kmequint is offline   Reply With Quote
Old 05-06-2013, 04:41 PM   #7510
kmequint
kmequint's Avatar
Oddometer: 57
I have had good luck with KG Clutch Factory
Old 05-06-2013, 05:18 PM   #7511
kmequint
kmequint's Avatar
Oddometer: 57
If you got the bike with anticipation of making a profit on it you got the wrong bike. I have been where you are at. I mine to much to give up on it. When you decide to rebuild it, do it right, don't go on the cheap like I did. I have had mine apart three times in the last year. I have almost replaced and or rebuilt the entire engine. Here is a list of the parts: gear shift shaft, Head, 4 kibblewhite valves, all the seals and gaskets, wrist pin, new sleeve (wanted to keep it stock), 2 timing chains, upper and lower timing chain sprockets, both timing chain guides, two sets of rings, 4 head gaskets, 4 valve springs, low speed jet, 2 carburetor kits, clutch plates and fibers, Ricky stator, piston, jug, crankshaft, connecting rod, rockers and cam polished, and the left main bearing. I don't want to jinx myself but she runs pretty damn good now. The only reason I replaced the jug and piston. I wanted a running bike while the new sleeve was being installed. Plus I wanted a spare in case it got screwed up. I was lucky and bought the crankshaft with a never used hotrods connecting rod installed on it for a dollar plus eighteen dollars for shipping of off fleebay.
So the moral of the story do it right the first time and you won't have to worry about it for another thirty years.
The lower timing chain sprocket is no longer available through Honda, if you would like to know what I used just ask and I will tell.
me
Old 05-06-2013, 08:18 PM   #7512
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,898
No profit to be made here! I juss want it fixed
Old 05-06-2013, 08:26 PM   #7513
Reposado1800
Juicy J fan!
Oddometer: 5,797
Thats why everyone needs more than one bike. While one is down, the others keep you company. I took time to fix alot of crap with the engine out waiting for the head rebuild. Clutch lever, rear turn signals, carb cleaning, different oil cooler, swing arm bearings. It has been a fun month.
Old 05-06-2013, 09:09 PM   #7514
kmequint
kmequint's Avatar
Oddometer: 57
In my opinion this is one of the easiest and very forgiving engine to work on. It's not that hard to work on, all it takes is time and money. Unfortunately time is a lot easier to come by. If you haven't already I would start by getting a Honda shop manual.
Old 05-07-2013, 04:00 AM   #7515
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,898
I gots the Honda manual on DVD Lap top will be in the garage with me.
Times are GMT -7.   It's 04:48 AM.
