Old 05-09-2013, 06:22 PM   #7561
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,671
Should I paint my engine before I slap it back in there? or should I let it show the years of use? I'm torn!
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust, big tube header, 6 Sigma stage 3 carb mods
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 05-09-2013, 06:31 PM   #7562
mcma111
mcma111's Avatar
Oddometer: 11,878
You should have powder coated it while it was apart. To late now.
Crap, I can't find the pictures of a XR600 I built a year or so ago. Powder Coated gloss black. Looked real sharp with a full set of stainless bolts.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-09-2013, 07:07 PM   #7563
jontow
Oddometer: 84
Originally Posted by Homerb View Post
Nope, triple checked piston and its perfect.
While this doesn't look the same, it reminds me of one of my own jackass moments. I tore apart my TW200 to replace a trashed valve, put it back together and rode it 500 miles or so when it developed a light rattle. Noise never seemed to get worse until another 500 or so miles later, the engine seized at the gas pump.
When I got it home and torn back down, I found some extra punctuation down in the camchain area. Literally, a comma shaped chunk of metal. Turns out I unknowingly dropped one of the cylinder dowel pins and never caught my mistake. Jackass mechanics ;)
Sent from my Nexus 7 using Tapatalk 2
jontow is offline   Reply With Quote
Old 05-09-2013, 07:52 PM   #7564
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,776
It is easy to drop things in there.
I just check the resistance value on the pulse generator and it is 399. Spec is 510-570. Glad I ordered one.
Hate gets you nowhere.
Old 05-09-2013, 08:12 PM   #7565
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,671
Got damn I think I'm a natural at pulling the engine. I thought it was gonna be alot harder to get it out. took me like 15 seconds to wiggle it out.
Here is where I'm at today.
I will begin dis-assembly tomorrow to assess damage. I almost called out of work to keep working on this lol Having more fun than I probably should.
Old 05-09-2013, 08:56 PM   #7566
Homerb
Oddometer: 455
I find it easier to remove the valve cover, head, barrel and piston before removing the engine from the frame. Just my 2c.
Homerb is offline   Reply With Quote
Old 05-10-2013, 12:02 AM   #7567
Argus16
Fake n00b
Argus16's Avatar
Oddometer: 423
Following... should be good.
Have you decided to powder coat or go au natural?
Argus16 is offline   Reply With Quote
Old 05-10-2013, 03:00 AM   #7568
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,671
Au natural! It's my desert toy/commuter, the sand will just eat it up after a year or so. One day I would like to restore this beast though.
I might get the head sand blasted just to show others it may look like shit, but someone put work in it.
You can't pull the top end with out pulling the engine on these old XL600s, everyone knows that
Old 05-10-2013, 04:16 AM   #7569
Homerb
Oddometer: 455
I was waiting for someone to bite.
Old 05-10-2013, 10:09 AM   #7570
davek181
Oddometer: 840
I got the top rocker cover off once without pulling the engine. It was right after I got the bike many years ago, I was replacing the compression release seal.
Tried it again many years later and couldn't repeat the process, had to pull the engine which really only takes about 15 minutes once you really commit to it.
davek181 is offline   Reply With Quote
Old 05-10-2013, 12:07 PM   #7571
Chobro
spinning the wheel
Chobro's Avatar
Oddometer: 781
Was just wondering about this, dang rocker cover is puking. Hopefully get to it this weekend.
-Chobro
Chobro is offline   Reply With Quote
Old 05-10-2013, 12:13 PM   #7572
Reposado1800
Juicy J fan!
Oddometer: 5,776
I reuse the metal shim gasket and spray it down with copper coat gasket spray.
I got the hot foot moto chain slider block today and put it on. Nice work! It makes my heart warm to see somebody stepping up and keeping these discontinued parts available.
Old 05-10-2013, 06:02 PM   #7573
transalper
transalper's Avatar
Oddometer: 295
TCI rack for xl600r fits perfectly on the xl350r.
Pelican mounting in process.
Sent from mobile device. Pardon the brevity.
Jay - 02R1150GSA, 07DRZ400S, 84XL350R (For Sale Soon)
transalper is offline   Reply With Quote
Old 05-10-2013, 07:23 PM   #7574
Homerb
Oddometer: 455
I was wondering if someone was going to ask about this. My bike is the XL600RMG, with the xr600 electric start motor, so it may differ slightly from the XL600R, l don't know for sure.
First, remove carbys and move as far back and down as possible. Remove top engine mounts from valve cover. Ive replaced the 8mm bolt in the middle of the valve cover with a threaded rod and a nut and copper washer, and l enlarged the hole for this bolt slightly.This allows me to remove this bolt completely before removing the cover. With this bolt still in place, it usually fouls the valve gear.
After removing all the 6mm bolts, slide the valve cover towards the carbys and down as far as you can and it will come out with a bit of jiggling. Getting the head and barrel off now is a piece of cake.
I did it this way last week with no problems. Turned out l had to remove and split the cases anyway so it was a wasted exercise, but nice to know it can be done if replacing a camchain or similar.
Old 05-10-2013, 07:24 PM   #7575
Homerb
Oddometer: 455
I used to have an XL350R. Its surprising how many parts are interchangeable between these two bikes.
Times are GMT -7.   It's 04:06 PM.
