Old 05-10-2013, 10:52 PM   #7576
Edouard_Bracame
Oddometer: 86
Originally Posted by Carter Pewterschmidt View Post
What's the story on that flat tracker looking bike in the background?
It's a Honda FTR 223, I changed the Exhaust and also installed a K&N air filter, removed the original Air box, and it looks sweet....
I still have to pass a reamer through the main jet though...a bit too lean...Check the exhaust diameter out...
Edouard_Bracame screwed with this post 05-10-2013 at 11:00 PM
Edouard_Bracame is offline   Reply With Quote
Old 05-10-2013, 10:54 PM   #7577
Edouard_Bracame
Oddometer: 86
Originally Posted by Homerb View Post
I was wondering if someone was going to ask about this. My bike is the XL600RMG, with the xr600 electric start motor, so it may differ slightly from the XL600R, l don't know for sure.
First, remove carbys and move as far back and down as possible. Remove top engine mounts from valve cover. Ive replaced the 8mm bolt in the middle of the valve cover with a threaded rod and a nut and copper washer, and l enlarged the hole for this bolt slightly.This allows me to remove this bolt completely before removing the cover. With this bolt still in place, it usually fouls the valve gear.
After removing all the 6mm bolts, slide the valve cover towards the carbys and down as far as you can and it will come out with a bit of jiggling. Getting the head and barrel off now is a piece of cake.
I did it this way last week with no problems. Turned out l had to remove and split the cases anyway so it was a wasted exercise, but nice to know it can be done if replacing a camchain or similar.
Good idea...
Old 05-11-2013, 07:46 AM   #7578
Stretchah
Oddometer: 123
Starting
Hey guys, been out on the trails quite a bit recently and really enjoying the XL, the only downside has been the couple of times I've dropped it
It starts first kick normally, but, if it goes down it just doesn't want to start for a long time. I've tried the full procedure kicking with decomp etc, but, it just doesn't start....last time I was there for about 20 - 30 mins trying and getting knackered before it fired and then was too knackered to really enjoy the ride.
Have you guys got any top tips for starting it after a drop? Apart from not dropping it or getting fitter
I'm planning to ride it to Morocco in October, so, need to try and sort it before I hit that heat and sand. Alternatively may have to try and add electric start too, but, that sounds costly....
____________________
84 Harris Magnum 2
84 XL600R
85 Vespa PK135
Stretchah is offline   Reply With Quote
Old 05-11-2013, 01:54 PM   #7579
crobox
crobox's Avatar
Oddometer: 324
I haven't dropped mine enough to have proven advice on that question... but maybe close the petcock, drain the float bowls, kick it a few times with manual decomp, open the petcock again. Might help...
Current Bikes: 2006 KTM 950 ADV S, 2002 XR650L, 1988 Hondasuki KLNX250R
Previous Bikes: 1986 Honda XL600R,Honda XL250R (2 of them), Honda XL600R, Kawasaki KLR600, Honda Nighthawk, BMW K1100LT, BMW R100GS, BMW R60/6, BMW K75, Husqvarna 430XC
Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com
crobox is offline   Reply With Quote
Old 05-11-2013, 02:05 PM   #7580
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,671
Usually its cuz the bowls overflow into the head when in its down. The engine being hot doesn't help any either.
Let it cool for about ten minutes, turn off the gas, and kick the bad mixture out of the cylinder a few (10-12) times, turn gas back on, kick one more time and you're off!! Don't ask me how I know this I had one dude swear there is something wrong with my bike cuz it would not start after I face planted at the dunes. No, it's just a turd
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust, big tube header, 6 Sigma stage 3 carb mods
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R screwed with this post 05-11-2013 at 04:12 PM
RFVC600R is offline   Reply With Quote
Old 05-11-2013, 03:34 PM   #7581
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,775
Has anybody laced up an 18" wheel to the rear? Any problems? The bike just does not look proportional with a 17" back there.
Hate gets you nowhere.
Old 05-11-2013, 04:12 PM   #7582
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,671
I think I read a few posts back about someone putting an 18'' wheel from an XL250
Old 05-11-2013, 04:26 PM   #7583
Carter Pewterschmidt's Avatar
Oddometer: 1,064
Not a good idea if you like your tire selection. The 17" and 21" combo have many options because lots of small adv and dual sport bikes run those sizes. The 18" and 21" combo is more of a straight dirt bike arrangement so you're down to buying mostly knobbys.
Carter Pewterschmidt is offline   Reply With Quote
Old 05-11-2013, 06:38 PM   #7584
davek181
Oddometer: 837
There was a time when 17" selections were limited, but not now. 21" has grown quite a bit too lately.
davek181 is offline   Reply With Quote
Old 05-11-2013, 08:59 PM   #7585
lamebrain
Oddometer: 38
My procedure when that happens- shut gas off, flip the kill switch to off, pull decomp, hold throttle wide open and kick through a few times (make sure kill switch is off when you kick with the throttle open!) flip kill switch back to on and do normal starting drill. It usually starts first kick for me after that, after it starts I turn the gas back on.
lamebrain is offline   Reply With Quote
Old 05-11-2013, 10:05 PM   #7586
Reposado1800
Juicy J fan!
Oddometer: 5,775
I bought a very nice complete 86 rocker box off of ebay. It looks like somebody wirebrushed the rocker faces and I cant tell for sure if the chrome plating has been compromised. How much is it to get the rockers done and who does it?
Old 05-11-2013, 10:28 PM   #7587
12120
Indenturedx5
12120's Avatar
Oddometer: 386
I have more experience with this then I would like. I just turn the gas off pull the decomp lever and kick leisurely until it starts. It will most times go fairly soon. Turn gas back on and ride away. If you kick for a long time before it starts turn the gas back on.
If you find yourself in a fair fight, your tactics are wrong.
'83 XL 600r
12120 is offline   Reply With Quote
Old 05-12-2013, 01:58 AM   #7588
Stretchah
Oddometer: 123
Cheers guys, hoping I don't drop it anytime soon, but, will give your suggestions a go next time :) may even just lay it down to see if it works for me
84 Harris Magnum 2
84 XL600R
85 Vespa PK135
Old 05-12-2013, 05:34 AM   #7589
mcma111
mcma111's Avatar
Oddometer: 11,863
Mega Cycle Cams does this. It's almost $60.00 for each rocker arm.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-12-2013, 07:36 AM   #7590
Reposado1800
Juicy J fan!
Oddometer: 5,775
My plan is to get these rockers done and get my old cam hardwelded and reground as a mild stage one. Save everything for when I ever get around to doing a timing chain after another 10,000 miles.
Times are GMT -7.   It's 03:42 PM.
