Old 05-14-2013, 07:19 PM   #7606
Edouard_Bracame
Oddometer: 86
Originally Posted by Homerb View Post
now if l can only find it!
As for the balancer gear being out of alignment, lm just going to make a new mark where the old mark would have been and run with that. Nobody lve spoken to has ever successfully removed this gear so l'll just leave it alone and run it about half a tooth out and hope for the best.
No need to remove that gear I just did a 600 Crankshaft 2 weeks ago, see picture.
Edouard_Bracame is offline   Reply With Quote
Old 05-14-2013, 10:41 PM   #7607
Homerb
Oddometer: 462
I dont need to remove the balancer gear to rebuild the crankshaft, my balancer gear got turned about 100 degrees when my engine went bang, and I'd like to put it back where its supposed to be if I can!
Homerb is offline   Reply With Quote
Old 05-14-2013, 10:50 PM   #7608
Edouard_Bracame
Oddometer: 86
Haaa OK....I got it now.
I Got one out of a XR500 a couple years ago, I had to drill through the Right hand side of the crankshaft, and Condemn one crankshaft to get a good Gear, I installed it back buy heating it in a oven very very hot and put it back in place...but it cost me a crankshaft.
Old 05-15-2013, 06:19 AM   #7609
Homerb
Oddometer: 462
Thanks Edouard, thats what I was thinking of doing, but I think I'll just run it as it is and hope for the best!
Old 05-15-2013, 12:03 PM   #7610
Johnny907
Oddometer: 3
New to me XL600R problems
Picked up my first XL600R about 3 weeks ago, it's an '83 I believe! It was all torn apart when I got it, for unknown reasons and yesterday I finally got it all put back together. Didn't touch the motor besides checking valve clearance and compression, went through the carbs and all was well in there, lubricated all the rusty cables etc., and fired it up!! Ran great around the neighborhood but I couldn't get oil to show up on the dipstick!! I kept thinking it would show up like its supposed to after servicing it and then running it for a minute or 2, but NOTHING!! Then, after idling it for about 2 minutes, oil started pouring out of an overflow tube down by the chain, I figured I had just over filled it in my efforts to get it to show.. And then something terrible happened. I'm not sure what, the engine didn't seize, but something happened in the top end and now I can feel a funkiness when the automatic compression release on the kickstart tries to work.. Right at the beginning of the kick there is a horrible crunch/click noise, and it never even tries to start.. I'm hoping I didn't total out the motor on my first day riding it :( what do you guys think??
Johnny907 is offline   Reply With Quote
Old 05-15-2013, 12:08 PM   #7611
mcma111
mcma111's Avatar
Oddometer: 12,563
I think it's time to pull the engine and do an autopsy.
OK, Just to not leave you hanging. The Honda RFVC engine is famous for oil pressure failures which result in top end melt downs. Most likely the oil pump cavitated and never moved the oil to the top end thus leaving you with a bunch of munched up parts. If your cam is shot I do have one for sale.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
mcma111 screwed with this post 05-15-2013 at 12:28 PM
Old 05-15-2013, 01:26 PM   #7612
JimRidesThis
Local celebrity
JimRidesThis's Avatar
Oddometer: 310
I find it easier to remove the valve cover, head, barrel and piston before removing the engine from the frame. Just my 2c.
Didn't think you could in an old XL?
1985 XL600R "Tamworth"
1992 TDM850 "Ivy"
JimRidesThis is offline   Reply With Quote
Old 05-15-2013, 01:27 PM   #7613
JimRidesThis
Local celebrity
Oddometer: 310
I was waiting for someone to bite.
Doh!
1992 TDM850 "Ivy"
Old 05-15-2013, 02:39 PM   #7614
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,991
Jim,
Did you receive your panel?
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 05-15-2013, 03:11 PM   #7615
JimRidesThis
Local celebrity
Oddometer: 310
Originally Posted by Dracus124 View Post
Jim,
Not yet mate. Great to know it's on the way though. Let me know what I owe you.
1992 TDM850 "Ivy"
Old 05-15-2013, 03:14 PM   #7616
m2h
"Old guys rule"
m2h's Avatar
Oddometer: 134
Well I picked up my barrel yesterday after getting the new liner bored. Looks good. Also the new Pro X rod kit arrived from the USA, so dropped it off with the crank to my crankshaft guy. Hoping to get it back this week, and start reassembly.
Still no idea where the shrapnel came from that stuffed my motor. Been suggested to look at the old piston for a piece missing, now if l can only find it!
Hi have a talk to your crankshaft guy he may be able to press it off when he presses apart the crank to fit your new rod. Good luck bro
m2h
m2h is offline   Reply With Quote
Old 05-15-2013, 03:52 PM   #7617
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,991
Nothing!
Originally Posted by meijer's trails View Post
then just a good ol DE-CRUSTING, but there so many nooks and crannies its very difficult. i keep finding surfaces with vintage virgin crust layers.
Thats what is awesome where I live, no rust! but UV damage is a different story.
Old 05-15-2013, 04:01 PM   #7618
Homerb
Oddometer: 462
m2h
Did that, but he's never successfully removed one. The way its designed it was never meant to be removed without destroying the crankshaft.
Old 05-15-2013, 04:06 PM   #7619
Johnny907
Oddometer: 3
I've gathered that the oil pumps had some issues.. I'll pull the motor at the end of the week and let you know whats going on up top, might have to get that cam off you in the end... Sad i only rode it for 10 minutes
Old 05-15-2013, 04:09 PM   #7620
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,991
Not to bust your balls or anything, but I imagine the bike was in pieces for a reason.
Is there a way for the rest of us to prevent such failures??
Times are GMT -7.   It's 05:03 AM.
