Old 05-15-2013, 04:15 PM   #7621
joexr
Oddometer: 3,773
Is there a way for the rest of us to prevent such failures??[/QUOTE]
Put oil in it BEFORE you run it.
Old 05-15-2013, 04:43 PM   #7622
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,074
Good as gold here then!
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 05-15-2013, 04:44 PM   #7623
mcma111
mcma111's Avatar
Oddometer: 12,917
The thing to do is when the engine is started after having been apart or even after doing an oil change is to loosen the oil feed line banjo bolt on the clutch cover. Start the engine and if you don't have flow in a few seconds shut the engine down. There are a few ways to prime the oil pump.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-15-2013, 04:50 PM   #7624
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,074
I seen in your RFVC rebuild thread that you put the oil pump in a bowl of oil. Say if you just did an oil change, and you have no oil pressure, do you have take the oil pump out to prime it?? I done quite a few oil changes and never checked for flow
Old 05-15-2013, 07:57 PM   #7625
mcma111
mcma111's Avatar
Oddometer: 12,917
No you don't or should have to. I did lose my cam years ago after an oil change. Did the change and parked the bike for a while. The next time the bike was used (by my son) the cam and piston ate it due to no oil flow. For some unknown reason the pump will cavitate and not move the oil. So the results after just a few minutes is a cooked top end. I have taken to putting a air gun in the dip stick hole (sealed with a rag) and with the lower banjo bolt loose blast some air in the oil tank. This pushes the oil through the pump thus priming it.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-16-2013, 12:19 AM   #7626
Johnny907
Oddometer: 3
Cry
[QUOTE=Dracus124;21416914]Not to bust your balls or anything, but I imagine the bike was in pieces for a reason.
I'm thinking you're right, definitely should've done more research before just trying to ride it around! Just bought a stupid airplane and now I'm finding a lack of time for my motorcycles!!!
Johnny907 is offline   Reply With Quote
Old 05-16-2013, 05:39 AM   #7627
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,803
Awesome idea!
I used to prime the car engines I built with a drill and extension to the pump shaft through the distributor hole.
Hate gets you nowhere.
Old 05-16-2013, 06:30 AM   #7628
Reposado1800
Juicy J fan!
Oddometer: 5,803
Anybody know where to get the bright blue fork gaiters?
Old 05-16-2013, 06:46 AM   #7629
mcma111
mcma111's Avatar
Oddometer: 12,917
Daystar "83" Series $19.95
http://www.powersportrider.com/CGI-B...catpage=791.00
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-16-2013, 07:33 AM   #7630
Reposado1800
Juicy J fan!
Oddometer: 5,803
Thanks.
My pulse generator arrives today so my bike should be on the road this evening.
Old 05-16-2013, 08:22 AM   #7631
mcma111
mcma111's Avatar
Oddometer: 12,917
Don't forget to put some sealant on the PG grommet.
http://s479.photobucket.com/user/mcm...6ef18.jpg.html
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-16-2013, 01:17 PM   #7632
Carter Pewterschmidt's Avatar
Oddometer: 1,105
Off Topic but how about a pic or two of that FXR in your sig?
Carter Pewterschmidt is offline   Reply With Quote
Old 05-16-2013, 01:37 PM   #7633
mcma111
mcma111's Avatar
Oddometer: 12,917
Currently buried behind other projects
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-16-2013, 02:47 PM   #7634
lookfar
from the land of OZ
Oddometer: 679
Just wondering if anybody knows which model year CDI units are swappable betweent XL600R and XR600R?
My '85 XL had a '94 XR CDI in it for a while..couldn't pick the difference
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 05-16-2013, 03:27 PM   #7635
Reposado1800
Juicy J fan!
Oddometer: 5,803
That is really cool. The new CDI says it has a higher redline and more timing advance. I think God of Speed got the same one a while back.
Times are GMT -7.   It's 02:34 PM.
