Old 05-16-2013, 03:36 PM   #7636
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,993
dont you need to modify the connector on the bike??
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is online now   Reply With Quote
Old 05-16-2013, 03:41 PM   #7637
lookfar
from the land of OZ
Oddometer: 653
I think that the connector was changed in '85. I didn't have to change any connector, it was plug and play.
I have it as a spare now, managed to get a NOS XL600 CDI from Honda..
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 05-16-2013, 03:57 PM   #7638
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,993
That's what I thought. Don't mind me, I'm just sponging knowledge
Old 05-16-2013, 04:53 PM   #7639
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,798
I got the new PG in the mail and resistance is 411. Manual says minimum should be 511-585. I guess it doesnt matter as long as it isnt way off the mark. The old one is 112.
Hate gets you nowhere.
Old 05-16-2013, 05:19 PM   #7640
davek181
davek181's Avatar
Oddometer: 940
my official honda genuine XL600 shop manual gives a value of 450-550 ohms for the pulse generator. Still a little low at 411, but closer to the value if that makes you feel any better.
If you didn't zero your leads you might even gain another ohm.
davek181 is offline   Reply With Quote
Old 05-16-2013, 08:43 PM   #7641
Reposado1800
Juicy J fan!
Oddometer: 5,798
I got it running. The PG was fried. This bike runs like a raped ape. Smooth and boatloads of torque.
Here is the list of work done as a recap.
Engine dynamics head with black diamond valves.
New cam a la mcma111
2 rockers
Wiseco .040 over 11:1 piston
New PG and CDI
New swingarm bearings, lower slider rear turn signals.
I got a bunch more work I am going to do but this was a milestone.
Old 05-17-2013, 04:43 AM   #7642
davek181
davek181's Avatar
Oddometer: 940
Glad you got it going. New bore with compression and sealed valves make a world of difference alright. Puts a smile on your face when you twist the throttle.
I don't know what it is about theses bikes, but when they run good they are so endearing they make you want to fix them up and keep riding them forever.
Old 05-17-2013, 10:39 AM   #7643
Reposado1800
Juicy J fan!
Oddometer: 5,798
The way these bikes lay down power is like nothing else.
Old 05-17-2013, 09:01 PM   #7644
12120
Indenturedx5
12120's Avatar
Oddometer: 479
Yippy
Scored a clarke tank for 75 bones plus shipping. Gonna install my clutch Sunday. Hope the tank makes it before my weekend ride in a couple of weeks.
Chris
If you find yourself in a fair fight, your tactics are wrong.
'83 XL 600r
12120 is offline   Reply With Quote
Old 05-18-2013, 06:45 AM   #7645
Reposado1800
Juicy J fan!
Oddometer: 5,798
Where are you guys buying the clear carb vent tubing? The XL600 uses two sizes and the black vacuum tubing from autozone swells when exposed to fuel.
Old 05-18-2013, 09:53 AM   #7646
Carter Pewterschmidt's Avatar
Oddometer: 1,099
Go to an outdoor power equipment shop. I used to work at one and they have a huge selection of small gauge thin walled tubing like that.
Carter Pewterschmidt is offline   Reply With Quote
Old 05-18-2013, 11:42 AM   #7647
ret1614
Oddometer: 23
So, I've been fighting with the carburetors on my '85 for quite some time now. A while back, I posted about an air cut diaphragm... That fixed one of my problems.
I've gone over both carburetors with a fine-toothed comb several times, made sure that all the passages were free and clear, changed all the gaskets and other rubber components... Still, I have an intermittent problem of it leaning out. I'm almost to the point of finding a different primary carburetor. (If anyone might have one collecting dust?)
All of the jetting is stock, and shouldn't be the source of an intermittent problem. The thing that I keep coming back to is a float sticking closed.
ret1614 is offline   Reply With Quote
Old 05-18-2013, 02:27 PM   #7648
Reposado1800
Juicy J fan!
Oddometer: 5,798
Did you clean out the emulsion tubes under the main jets. They collect grit and don't atomize properly.
Old 05-18-2013, 07:23 PM   #7649
ret1614
Oddometer: 23
The emulsion tubes are clean, all holes on all four sides are clear.
Also, the float levels are correct when the bike is up on a stand (flat and level).
For being an intermittent problem, this really vexes me.
Old 05-18-2013, 08:05 PM   #7650
Reposado1800
Juicy J fan!
Oddometer: 5,798
Have you adjusted the timing of the secondary carb? I had a bit of a bog a long time ago and adjusted the secondary tang to let the secondary come in a bit later. Worked good.
Times are GMT -7.   It's 02:01 AM.
