Old 05-26-2013, 09:51 PM   #7741
m2h
"Old guys rule"
m2h's Avatar
Oddometer: 130
Originally Posted by Reposado1800 View Post
No not too bad. Take the jug to a machine shop and they put it in a jig and use the mill to drill it out. They can even save the threads most of the time.
Very True! And while its in the shop my advice is to get the guy to recoil all the 6mm and the one 8mm thread in the top of the head as well! I did all my 6mm ones recently and while torqueing up the 8mm one I stripped the bastard Not a huge job but f*#@ing annoying!!! Especially as this rebuild has been going on far far to long! Am just about there tho
Have been wanting to put up some piks but not sure how to go about it, any advice?
m2h is offline   Reply With Quote
Old 05-26-2013, 11:36 PM   #7742
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,670
http://advrider.com/forums/showthread.php?t=919
You want option two.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust, big tube header, 6 Sigma stage 3 carb mods
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is online now   Reply With Quote
Old 05-27-2013, 01:40 AM   #7743
Homerb
Oddometer: 455
I couldnt get the photobucket photos to load, so went with smugsmug and alls ok.
Homerb is offline   Reply With Quote
Old 05-27-2013, 08:59 AM   #7744
TonyfromOR
TonyfromOR's Avatar
Oddometer: 53
Head Bolts
When reinstalling the head bolts don't oil them; use anti-seize compound!
TonyfromOR is offline   Reply With Quote
Old 05-27-2013, 03:30 PM   #7745
m2h
"Old guys rule"
m2h's Avatar
Oddometer: 130
Thanks. Will give it go.
m2h
Old 05-27-2013, 03:53 PM   #7746
davek181
Oddometer: 836
I use photobucket myself, just copy and paste the direct link and it shows full size. I don't know how to do the thumbnail thing though.
davek181 is offline   Reply With Quote
Old 05-27-2013, 05:05 PM   #7747
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
I know this question has been asked a thousand times, but I'm finally able to get back to chasing down the spark issue on my '87 XL600R, and the last link I had to an Arrowhead CDI for an XR600 shows that it is now discontinued. What are the latest options for CDI replacement/repair?
I think I'm also just going to swap in a Ricky Stator while I'm buying parts.
This is how she was last I left her...
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 05-27-2013, 05:08 PM   #7748
Zombie_Stomp
Aspiring human
Zombie_Stomp's Avatar
Oddometer: 2,231
The Honda manual days, for the cylinder bolts I remember at least, to use motor oil on the threads. When they're giving me specific torque values, I'm going to do as the engineers say!
1982 4x4 longbed, a rolling daily driver work-in-progress...
1987 Yamaha XT600 2KF (German)
STOLEN: RED XL600 in Portland
I do heavy-duty textile repair, upholstery, and design/manufacture bags.
Zombie_Stomp is offline   Reply With Quote
Old 05-27-2013, 05:10 PM   #7749
m2h
"Old guys rule"
m2h's Avatar
Oddometer: 130
Been a bit of discussion recently about timing chains etc. Am reassembling my '86 at the moment and found that I too have "stretch" Cash being short am going to live with it. The marks on the top gear aren't majorly out and was wondering what effect on performance it might have. I don't intend to be ringing the poor old thing as I just want it for commuting. The tensioner and guides are in good order. The bottom drive gear is "obsolete" so what is the alternative ? XR one maybe?
Devised a means of holding crankshaft still while fiddling with valve setting etc may be of some use. Only if you have right side case off unfortunately! First time pik insertion from Smugmug, thanks for the help with that guys.
It worked too! You may have to use another hole and make the plate to fit whatever basket slot is closest.
M2H
Old 05-27-2013, 05:26 PM   #7750
joexr
Oddometer: 3,773
M2H
A stretched chain retards the cam timing obviously. I've slotted my cam sprocket to be able to do this . I'm at -6 degrees now. This takes off the bottom end and adds to the top end.
Old 05-27-2013, 07:59 PM   #7751
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,775
Just recently I feplaced the CDI with a unit from regulatorrectifier.com. I also replaced the pulse generator and stator. $65 for cdi, $42 for PG and $150 for Ricky stator.
Hate gets you nowhere.
Old 05-27-2013, 09:44 PM   #7752
Aaron from Texas
Oddometer: 489
Sweet! Thanks man. How did that work out for you? What were the symptoms before?
1987 Honda XL600R
Old 05-28-2013, 03:49 AM   #7753
m2h
"Old guys rule"
m2h's Avatar
Oddometer: 130
Thanks Joe, I figured that but in my case would I even notice!! .
At my age would I care, I just want to save gas (on the bike I mean of course) Have heli-coiled the 8mm thread I stripped and replaced the valve cover so I cant be bothered slotting the cam gear now.
Will put up some more piks soon now I know how!
Thanks for the reply
M2H
OOPS double signature!!
Found out how to do that too!!
M2H
Old 05-28-2013, 06:49 AM   #7754
davek181
Oddometer: 836
Altering cam timing is an old hot rodders trick. I think there is enough flexibility in the engine design and the mild cam that Honda uses to allow for a couple degrees here and there difference.
As far as the timing sprocket availability, you can use all XR stuff if you need to. I wouldn't mix and match the old and new style parts, but the entire assembly is interchangeable.
Old 05-28-2013, 11:31 AM   #7755
Reposado1800
Juicy J fan!
Oddometer: 5,775
I would never use a timing chain where both slashes are not visible from the "deck." I think that is what the manual gives as an indicator of a too stretched chain.
Times are GMT -7.   It's 08:54 PM.
