Old 05-31-2013, 06:46 AM   #7786
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,798
How much did XL600R's lean over on the kickstank from the factory? Most seem to lean over quite a bit which is safe but looks like crap.
Look at this one. Only 3,000 original miles.
http://houston.craigslist.org/mcy/3837353150.html
Hate gets you nowhere.
Old 05-31-2013, 07:05 AM   #7787
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
Might be a result of kickstarting it while on the sidestand too much. Mine only has 5,000 original miles, and it sits like this...
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 05-31-2013, 07:19 AM   #7788
davek181
davek181's Avatar
Oddometer: 939
I don't remember mine leaning that much when stock, As I added suspension length it definitely got worse. I eventually bought an XR kickstand of ebay which was longer and that helped a lot. I wonder if they changed those over the years a little, mine was a late model and that one is early.
The one you linked to on CL is questionable in my mind anyway as to originality. The more you look at it the worse is looks. I think the speedo may indeed have on 3.000 miles, but the bike appears to have a lot more. either that or they were really hard miles, plus it comes with lots of extra parts which makes me wonder too. As is true with cars too, I would rather have a well cared for higher mile machine than an abused lower mile machine.
davek181 is offline   Reply With Quote
Old 05-31-2013, 07:26 AM   #7789
Reposado1800
Juicy J fan!
Oddometer: 5,798
It looks like it spent most of its life outside. Rusty forks at the top, shredded seat, plastic faded. It would be a fantastic candidate for a rebuild as long as pitting inside the engine is minimal or non existent. Cam, bore, wrist pin, gears all pit from humidity moisture build up.
Old 05-31-2013, 08:05 AM   #7790
davek181
davek181's Avatar
Oddometer: 939
Air filters can rot and dissolve too, and if someone doesn't care enough to do anything else why bother changing oil. It might be a good builder, but I would look long and hard at it live before plunking down cash.
Old 05-31-2013, 08:09 AM   #7791
mcma111
mcma111's Avatar
Oddometer: 12,550
Side Stand
If the bike has a lot of lean there are two ways to achieve this.
First, the bent kick stand from kick starting the bike with the stand down:
Second is again starting the bike on the stand but the stand's mount on the frame gets bent thus giving the bike it's lean. Ever see a bike that is missing it's side stand and where the stand is supposed to mount is torn away? now you know why.
Here is a straight stand
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-31-2013, 09:48 AM   #7792
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 390
And here one that will not bend .
I kick my one always on the stand .
longer then original but rock solid
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Old 05-31-2013, 10:32 AM   #7793
Reposado1800
Juicy J fan!
Oddometer: 5,798
I hate to admit this but... I have to stand on the left peg to kick it over. I have tried one foot on the ground and one on the kicker and it wont work. Legs are too short.
Old 05-31-2013, 01:26 PM   #7794
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,991
I had my bike set up on a bucket one time. The kick stand was out and it fell over landing on the kickstand, it bent it in inwards and now it doesn't lean nearly as much. only downside was the handle bars hit the fender off my car
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 05-31-2013, 02:03 PM   #7795
davek181
davek181's Avatar
Oddometer: 939
I used to feel I had to stand on the peg too, 32" inseam, but out of fear of breaking the kick stand mount or having to start it where I couldn't use the stand I forced myself to learn the technique for starting with the stand up.
Now that is the first thing I do is kick up the stand, I feel now like it will bottom out on the kick and highside me. Getting the jetting dialed helped a lot too.
I used to be afraid of getting stopped on a hill or somewhere and not being able to start it.
Old 05-31-2013, 02:23 PM   #7796
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,991
I've gotten myself is some shitty situations offroad, nothing worse than a failed hill climb and trying to get it started on a wicked soft slope. Like I said before, the XL600 is an acquired taste if you ride it off-road....
I need to get mine fixed. I'm happy it's not nearly as bad as other rebuilds I read about. Some of those rebuilds I wonder how the bike was running before they torn into it. I juss need head work and reassemble!!
How can I tell if my tensioner spring is good?? It gave my finger a good cut when it released, but I don't think thats a good way to judge it.
Old 05-31-2013, 03:47 PM   #7797
mcma111
mcma111's Avatar
Oddometer: 12,550
The cam chain tensioner is what? Like five bucks. Buy a new one.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 05-31-2013, 06:58 PM   #7798
TonyfromOR
TonyfromOR's Avatar
Oddometer: 63
Kickstand lean
My XL had a serious lean on the stand when I got it. At the top of the stand, the forked part was spread out and the shoulder bolt was stripped. Heated up the forked end red hot and beat it back together. Put on a new shoulder bolt. Fixed the lean problem. I think it got deformed from the PO traveling with a few hundred pounds of gear on the bike.
TonyfromOR is offline   Reply With Quote
Old 05-31-2013, 07:53 PM   #7799
Copperhead64
Copperhead64's Avatar
Oddometer: 9
The old hard to start story.
I know I need to upgrade to the Ricky Stator and where to find but what about the Pulse Generator?
Found the bike last fall ....yes in a barn......Rings,Gaskets-Seals,Valves ground and T-Chain guides and a new spiffy paint job later this is what I have.
Bike was hard to start when hot but I got the proper Voodoo down pat and had no worries.....took a dump on me this week and wouldn't start.
looks like the Stat. and the PG are out of spec....Where can I get the PG and anything else I need to change to get this pig back on the road.
I have scanned through this thread for 2 hours....My eyes are bleeding...Thanks for any help I can get, love this old bike !
Copperhead64 is offline   Reply With Quote
Old 05-31-2013, 07:58 PM   #7800
mcma111
mcma111's Avatar
Oddometer: 12,550
Stator
http://www.rickystator.com/catalog/h...bly-p-105.html
Pulse Generator, Cheapcycleparts.com
Generator, Pulse 30300-MK2-010 $47.95
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 02:42 PM.
