Old 06-08-2013, 06:44 AM   #7861
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,797
Originally Posted by m2h View Post
Its finally happenedThe beast breathes!! Its been a long time coming, a nearly 9 month rebuild from the ground up. Re bore out to 101 hi comp Wiseco,
new rod kit, valve grind, bearings etc. Here's a few photos
The before shot.
The after
Did couple of mods
This is bloody handy!
A variation of Crobox's great idea
Hope to do an oil cooler mod soon as I feel the bikes run in a bit.
Like to say thanks to all you guys for the advise and the laughs. This thread gets to be a bit addictive.
Cheers
M2H
Nice rebuild. I wonder if we can get the red seat cover here in the US?
Hate gets you nowhere.
Old 06-08-2013, 12:54 PM   #7862
Reposado1800
Juicy J fan!
Oddometer: 5,797
What are you guys running for fork oil level? I am running 120mm but may take some out. Factory settting is 5.9 inches which I think is waaaay too soft.
Old 06-08-2013, 02:52 PM   #7863
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,898
What weight are you running?? I filled both tubes with a bottle of 15w
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 06-08-2013, 02:53 PM   #7864
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,898
Suspension is the XL600's weakness
Old 06-08-2013, 03:19 PM   #7865
davek181
davek181's Avatar
Oddometer: 901
With the stock XL forks I used to run ATF at about 120mm also.
davek181 is offline   Reply With Quote
Old 06-08-2013, 04:30 PM   #7866
Reposado1800
Juicy J fan!
Oddometer: 5,797
The race tech emulators require 15W. Im just hoping 120mm air gap does not hydralock.
Old 06-08-2013, 04:53 PM   #7867
davek181
davek181's Avatar
Oddometer: 901
ATF is about 7.5 wt usually. I was told by a man that used to build XL/XR race bikes in the day that 5 inches is a good starting point. Or about 125mm if you prefer.
I think you would be fine at 120. You can always add your springs and look at where the level ends up with forks extended to be sure.
I run 90-100 in my CR USD conversion and they are bigger forks with more capacity and travel with no issues.
I ran 85-90 in my XR 400 forks when I was running them on the XL, Also larger forks 43mm, and more travel and capacity.
Old 06-08-2013, 05:03 PM   #7868
Dread_lion
Oddometer: 268
hey guys, been reading up on this forum for the last few weeks since i bought an XL600 myself. I simply love this forum, full of usefull stuff! Anyway, before i get to questions, here are some pics. i'm sorry if i offend anyone by posting this bike, i bought it allready modified, so no sacriledge was done by myself ;). i do plan on keeping it this way. I got it for 425 euro running but with engine noise (most likely cam chain worn out)
Pics of how i got it:
pics of what it is going to look like (sort of)
done so far:
new front disk
tightening all spokes (front wheel was loose as hell!)
new brake contacts on front brake (not original anymore)
new headset bearings
strip plastics from paint, tank will follow soon!
a lot of other small problems.
new LM front light, because i got it cheap and it looks quite nice!
acerbis handguards, still need cleaning up!
changed rear fender to old cr500?
still to follow:
led light for the rear
supermoto front fender
Anyway, right now i'm working on replacing the timing chain. Problem is, i dont have the clutch removal tool. Can anyone tell me how to pull this off without buying the tool? I really dont want to order it, as getting most of my other parts is costing me a lot allready, since i need to get everything shipped to Belgium. pictures would be great too! i do have acces to a lot of other tools, so i could make something myself, just need to know what is required.
Dread_lion is offline   Reply With Quote
Old 06-08-2013, 05:27 PM   #7869
m2h
"Old guys rule"
m2h's Avatar
Oddometer: 133
I just sent it to an upholsterer. PM Zombie Stomp I think he does all that stuff.
M2H
m2h is offline   Reply With Quote
Old 06-09-2013, 02:49 AM   #7870
lookfar
from the land of OZ
Oddometer: 631
Try this mob, they are in New Zealand, but should
Ship to the US.
They do replica seat covers including stencils and exhausts
Among other things,
www.smebike.com
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 06-09-2013, 03:25 AM   #7871
Dread_lion
Oddometer: 268
Hey guys,
anyone know if the torque specs on bolts are the same for the XL600RM and the normal XL600 or the XR600? i have a xl600rm but no manual for it. Same question for valve clearances.
i also tried posting a message before this one with some pics and questions but it didnt come through?
Old 06-09-2013, 04:33 AM   #7872
mcma111
mcma111's Avatar
Oddometer: 12,385
Originally Posted by Dread_lion View Post
Hey guys,
Should be the same. Any reason for it not to be?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-09-2013, 08:37 AM   #7873
Dread_lion
Oddometer: 268
Just wondering, because i seem to remember reading something about older xl600 specs being a bit different from more recent ones, figured maybe there where differences between rm/lm/r models. But its all good then!
Right now next problem i have is that one of the bolts on the cam sprocket is completely f***ed. Need to get that out first!
Old 06-09-2013, 08:40 AM   #7874
davek181
davek181's Avatar
Oddometer: 901
They changed bolt diameter from 8 to 9mm somewhere along the line, but I think that was after XL's. At least on this side of the pond.
Old 06-09-2013, 09:05 AM   #7875
mcma111
mcma111's Avatar
Oddometer: 12,385
Honda changed to 9mm head bolts in 1988.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 05:04 AM.
