Old 06-12-2013, 11:17 AM   #7906
Dread_lion
Oddometer: 279
Originally Posted by mcma111 View Post
Thrust washer
that sucks
is it possible to replace those without replacing the big end? i'm guessing no, but then again, what do i know . i guess i will be looking for a replacement engine to get me through the summer and fix this one when i have the time for it. I need it to be running soon!
Dread_lion is offline   Reply With Quote
Old 06-12-2013, 11:32 AM   #7907
mcma111
mcma111's Avatar
Oddometer: 12,922
The thrust washers keep the rod from rubbing against the crank weights. Once the washers go the big end is already toast. The only way to correct this is to replace the rod assembly.
PM sent.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-12-2013, 11:52 AM   #7908
Dread_lion
Oddometer: 279
PM sent.
k so how weird is that the engine is still running then? i bought it running, shouldnt this seize the engine in no time?
Old 06-12-2013, 11:55 AM   #7909
mcma111
mcma111's Avatar
Oddometer: 12,922
Unless the material is left over from a prior failure. Who knows. It may stop running shortly.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-12-2013, 12:05 PM   #7910
Dread_lion
Oddometer: 279
well, i'm afraid i'm fairly certain the engine hasn't been opened so far. guess i'll be looking for parts and going for complete disassembly then!
Old 06-12-2013, 12:11 PM   #7911
davek181
davek181's Avatar
Oddometer: 965
You might get by with an eBay crank. Although you would want to replace the bearings while you are in there to, so it might be better to just redo your crank if you can find someone to do it.
I am sure Steve knows someone and will likely chime in soon, if he hasn't already PM'd you.
davek181 is offline   Reply With Quote
Old 06-12-2013, 12:13 PM   #7912
mcma111
mcma111's Avatar
Oddometer: 12,922
He's in Belgium. Just a bit to far to be of help.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-12-2013, 12:20 PM   #7913
Dread_lion
Oddometer: 279
yeah this might take some time. thankfully its an XL600RM, and i CAN find parts RATHER easy, funds however, are another problem ;). I'll probably replace it with an XR600 engine for now, and do the rest during the winter or when i have time.
Does suck that i'm going to have to dump a lot of money into this engine. oh well...
Old 06-12-2013, 01:47 PM   #7914
lookfar
from the land of OZ
Oddometer: 679
Originally Posted by Homerb View Post
Nope, apparently not! Redfitted the CDI and still wont start. Just had a play, and moving the wiring going into the CDI while cranking the starter creates a spark sometimes. Looks like lm going to have a thorough check of the wiring and the connectors.
CDI's are no longer available from Honda ( I think I got the last one, the Honda guy said don't ask for another), but I ran a CDI from a '94 XR600 for a while and all seemed good. Same connectors, just plug and play.
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL250R
1985 XL600R 1988 XR600
lookfar is offline   Reply With Quote
Old 06-12-2013, 02:19 PM   #7915
davek181
davek181's Avatar
Oddometer: 965
You think I woulda caught on by the accent, I am not the sharpest crayon in the box for sure.
Old 06-12-2013, 02:27 PM   #7916
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,803
Can the case be split from the flywheel side and leave clutch and tranny intact?
Hate gets you nowhere.
Old 06-12-2013, 02:41 PM   #7917
mcma111
mcma111's Avatar
Oddometer: 12,922
You'll get it apart but I don't think it will go back together due to the spring loaded counter-balancer.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-12-2013, 02:49 PM   #7918
Reposado1800
Juicy J fan!
Oddometer: 5,803
Just wondering if there was an easy way to do center case gasket.
Old 06-12-2013, 03:25 PM   #7919
davek181
davek181's Avatar
Oddometer: 965
There is no easy way, If I remember correctly you stack the tranny and shift spindle and everything in the left case, then drop the right case on. I can just envision disaster trying to keep it all together in the right sidecase, opposed to the small amount of time it would take to just strip the right side down and do it as designed.
Old 06-12-2013, 03:51 PM   #7920
dgman1991
dgman1991's Avatar
Oddometer: 20
hey, sorry about the picture size, I tried to decrease the size on imageshack, but it apparently didn't work as planned. So, I finished cleaning the carburetors in Pine-Sol, then washed with soap and water, and finally blew out with compressed air. The carburetors are like new again, and after re-installing. I discovered that I sometimes have normal feeling compression and other times I can just kick it through without pulling in the decompression cable. This is concerning to me. I followed the manual on how to put everything back together. Thanks Schrauberklaus for the input and dave. Unfortunately I don't have a compression tester, but before my fatal ride, it was hard to kick or better as they say, and started perfectly every time. now it is either hard to kick, or freely kicks through which is worrisome. I adjusted the idle screw so that it is closed. I fear that I might have to do a valve job. I just checked my adjustment and it is .05mm for intakes and .1mm for exhaust as per manual. Any input would be appreciated, thanks
-Dan
dgman1991 is offline   Reply With Quote
Times are GMT -7.   It's 05:02 AM.
