Old 06-13-2013, 09:58 PM   #7936
bobbed06
Cavalera Conspirator
Oddometer: 1,236
Originally Posted by Reposado1800 View Post
Pics? I love whoring pics.
Now after all these years.
Looks great!
bobbed06 is offline   Reply With Quote
Old 06-14-2013, 02:42 AM   #7937
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,816
Since March 1997 bought with 3800 original miles. Sold it in 2011 and bought it back in 2013. Now has 14,800 miles.
1 good refresh in 07 at 7,000 miles and now a pretty thorough rebuild in May.
Bored 1mm over with the Wiseco 11:1. Engine Dynamics head, new cam and two fresh rockers for the exhaust.
The bike runs great and hauls ass. It has 14:40 sprockets so it does road use very well.
Nice! my engine was rebuilt thoroughly at PO's cost. Just my luck a valve seat came loose. I keep looking at my top-end parts and It reminds me I'm lucky that a valve seat is my only problem. Should get many more miles after it's fixed. Only gotta save up for another month or so...... Then I swear I will never drive another car again!!
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 06-14-2013, 06:59 AM   #7938
meijer's trails
meijer's trails's Avatar
Oddometer: 483
anyone have original dimesions seat mount collar height of 1987 xl600r?
The original part number is 80102-mg2-000 but its unavailable.
I think the fender mount is the same
I forgot to tighten my seat collars and I lost them. Honda lists them as unavailable....but its just a standard Honda collar.
I called Honda for dimensions and a cross reference, but the analyst sent me dimensions for the rubber part, not the metal collar.
After frogging around eBay for quite a while it seems like the xl600r fender mount is the same?
61104-444-000
But I'm not sure.
I'm trying to develop a cross reference. So I need the height of the original collar. Does it insert flush to the top of the seat rubber mount? I was thinking it must be a little lower for clamp force to develop.
I measured witness marks, but I'm not sure if I even Had the correct part in the first place. One was already missing when I got it.
The cheapest alternative might be these 2005 cbr600f4 radiator mounts for $1.85 par no. 19052-mgh-640 super ceded by 19052-mn8-000
I wound up paying $5.99 each but I just wanted to hurry and order something that would work I had a washer and another 6mm bushing in its place but I couldn't stand knowing it was the wrong thing.
I also tried searching standard hardware for a washer bushing but hose didn't seem like the right piece either.
Anyone else have a good substitute part of the original dimensions
meijer's trails is offline   Reply With Quote
Old 06-14-2013, 07:16 AM   #7939
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,794
61104-444-000
But I'm not sure.
I dont think my bike ever had that metal collar bushing. On one side I have a fat flat washer and nut. The other side is a couple of thin washers to replace one missing from years ago.
Hate gets you nowhere.
Old 06-14-2013, 01:29 PM   #7940
davek181
davek181's Avatar
Oddometer: 881
I just popped off my seat to measure my bushing, and I don't have one, apparently not too big of an issue. Take your best guess at length and you will be better off than at least two bikes I know.
davek181 is offline   Reply With Quote
Old 06-14-2013, 04:01 PM   #7941
dgman1991
dgman1991's Avatar
Oddometer: 20
So I took my engine out, and pulled off the rocker cover, and discovered that one of my rocker arms has a large chunk worn off of it. It is the exhaust valve on the left side, so not controlled by the decomp lever. I also discovered that I do not need a new timing chain , should I take the head off and check in there for a loose valve seat, or should I get new rockers?
I'll try to post (smaller) pictures after work
-Dan
dgman1991 is offline   Reply With Quote
Old 06-14-2013, 04:09 PM   #7942
mcma111
mcma111's Avatar
Oddometer: 12,268
Better safe than sorry. It's only the cost of the head gasket.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-14-2013, 07:16 PM   #7943
m2h
"Old guys rule"
m2h's Avatar
Oddometer: 131
61104-444-000
But I'm not sure.
I haven't put my seat on permanently yet and did a measure up for you:-
large dia is 25mm, small dia is 10mm, length of small dia is 16mm
bore size 7mm
Hope that's clear?
My bike is an '86 so it should be the same
Cheers
M2H
m2h is offline   Reply With Quote
Old 06-14-2013, 07:31 PM   #7944
Carter Pewterschmidt's Avatar
Oddometer: 1,086
That thing looks pretty serious with those knobbies. Nice pic
Carter Pewterschmidt is offline   Reply With Quote
Old 06-14-2013, 07:33 PM   #7945
Oddometer: 1,086
61104-444-000
But I'm not sure.
www.mcmaster.com
Once you have the dimensions you should be able find something that works from them.
Old 06-14-2013, 08:07 PM   #7946
Reposado1800
Juicy J fan!
Oddometer: 5,794
That rear was a Dunlop D903 before the 606 came out and the front Kenda Trackmaster 2. They worked really good off road.
Old 06-14-2013, 11:31 PM   #7947
dgman1991
dgman1991's Avatar
Oddometer: 20
rocker picture
wooooo Got the size right
Old 06-15-2013, 04:17 AM   #7948
Edouard_Bracame
Oddometer: 86
Ouuuuch....last picture hurts
Edouard_Bracame is offline   Reply With Quote
Old 06-15-2013, 07:21 AM   #7949
Edouard_Bracame
Oddometer: 86
Okay it's a Yam....but look at this beauty...
Clement Desalle RMZ 450 factory...;-)...Berylium Bronze seat, before machining!!!
Edouard_Bracame screwed with this post 06-15-2013 at 07:32 AM
Old 06-15-2013, 07:40 AM   #7950
mcma111
mcma111's Avatar
Oddometer: 12,268
How does the cam lobe look?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 03:42 AM.
