Old 06-16-2013, 04:40 AM   #7966
mcma111
mcma111's Avatar
Oddometer: 12,587
dgman,
Isn't your motor the one with intermittent low compression? Better pull the valves to check the seats.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-16-2013, 12:10 PM   #7967
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,798
It all comes down to how much money you have to play with.
You could just hone and rering for $50 but a bore and high compression make it so much better.
Hate gets you nowhere.
Old 06-16-2013, 05:19 PM   #7968
scrubby81
Auto Builder
Oddometer: 138
Originally Posted by mcma111 View Post
Ship it to me and I'll put it together for you.
Might have to do that, What do you do with them? I have two motors complete. One is blown slap up I think just swaped the orginal back in the bike and its got about 16500 on it with a chain slap sound comming out of it, also the sprocket seems to have alot of play in it (new sprocket) on the shaft, I want to do everything all at one time Valves piston thinking big compresson, maby cam up grade and any other improvements that would be good in the long run cam chain bearings ect ect
Depending on the day its a goodin or its a
Thanks Scrubby
scrubby81 is offline   Reply With Quote
Old 06-16-2013, 06:34 PM   #7969
mcma111
mcma111's Avatar
Oddometer: 12,587
Take the best of the two motors, install a Wiseco 101mm or 102mm piston, valve job and a Mega Cycle cam.
Back in the day I had a Venolia piston, a Carrillo rod and the Mega Cycle cam 'n rockers.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-16-2013, 07:59 PM   #7970
Reposado1800
Juicy J fan!
Oddometer: 5,798
Did you have to do the shortened guides and heavier springs with that cam?
Anyway I am not sure if I need anymore power. I could easily dump my wife off the back with a flick of the wrist right now. There is no spool up for power. It hits instantly and pulls hard. I cant see a damn thing behind me because the mirrors blur.
Old 06-16-2013, 08:04 PM   #7971
mcma111
mcma111's Avatar
Oddometer: 12,587
The base cam from Mega Cycle is a drop in cam. No shorting of the guides necessary. I have this cam in my XR600.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-17-2013, 01:10 AM   #7972
Dread_lion
Oddometer: 278
Ok i need your help! Just got an xl600r engine for my xl600rm bike with an engine that needs way too much work for my budget/timeframe.
So, what would be the easiest way to make this engine work, including the lights and everything? I do want to keep the wiring harness as original al possible, because i plan on rebuilding my original rm engine.
Homerb told me about a few differences allready, but i'm still confused.
I also read about swapping over the stators to make things easier? What else, do i really need the cdi from the xl600r too? Wiring changes?
Dread_lion is offline   Reply With Quote
Old 06-17-2013, 04:48 AM   #7973
Homerb
Oddometer: 462
Hi Tom, just had a look at my parts diagrams and I can confirm that the XL/XR600R and XL600RMG share no electrical components, according to their part numbers, anyway. Thats not to say the coils for example wont interchange.
I have confirmed that the kick start XL/XR600R CDI is powered by alternating current (AC) from the stator, generated when kicking.
The electric start bikes, 600RMG, NX650, XR650L CDIs are powered by direct current (DC) I assumed from the battery, until I kick started my RMG with no battery connected. Confusing I know.
As the NX650 and XR650L have no kickstarter, I wonder if they could be clutch started without a battery?
If so, I assume the DC is coming from the stator as AC, through the rectifier and into DC for the CDI. Im just guessing here. The wiring diagram I sent you may explain it. I can never read the bloody things myself.
Short answer is I think the XL600R motor will need a XL/XR CDI and possibly regulator/rectifier as well. Im assuming the XL600R motor has the stator in it.
Good luck.
Brad
Homerb is offline   Reply With Quote
Old 06-17-2013, 05:28 AM   #7974
davek181
davek181's Avatar
Oddometer: 940
Without a wiring diagram to consult, or a parts breakdown I will have to guess. I did look at one for an xr650L however since that is all I have available to me. I think that the main difference between the two is the stator. There is only the stator and pulse coil for electrical on the engine. I did check a parts microfiche and found that the pulse coil is the same on a 650L as on a XR600, as is the ignition coil. The difference in the stator would likely be the ignition AC coil used on the magneto bike.
I suspect you could swap stators and drop it in using your existing wiring harness. That would be the simplest way to swap engines between the two with fewest modifications to the bike.
If the stators don't swap for some reason, I would be inclined to make a temporary harness to utilize the magneto style ignition. That would necessitate a matching A/C CDI unit too. That way there would be no butchering of the original harness.
davek181 screwed with this post 06-17-2013 at 05:36 AM
davek181 is offline   Reply With Quote
Old 06-17-2013, 07:32 AM   #7975
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
Gasket question on these old mules... I replaced my stator this weekend with a Ricky Stator... Spent nearly an hour cleaning up the "painted" gasket surface on the stator cover, and buttoned everything up. After I got it running again, I ran down to the gas station to top the tank off with fresh gas, and rode back home. Maybe 1/2 a mile at the most. Now I'm noticing a dribble of oil on the ground from the stator cover, and I think I've traced it to the rear of the stator, near the countershaft sprocket and chain. It's certainly not chain oil...
So, I'll probably need to remove the cover again, and I'm wondering... Should I use a bead of RTV on the stator cover side of the gasket? The machined side of the cases looks great...
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas screwed with this post 06-17-2013 at 07:53 AM
Aaron from Texas is offline   Reply With Quote
Old 06-17-2013, 08:26 AM   #7976
davek181
davek181's Avatar
Oddometer: 940
Did you use a Honda OE gasket? I have had less than stellar results with anything less. Also, did you put a dab of sealant (Hondabond preferred) around the grommet for the wires?
I had a slight leak on my stator cover after I reused a Honda gasket that looked intact, after a few heating cycles it healed up on it's own as I ordered another gasket. At least now I have a spare.
Old 06-17-2013, 08:40 AM   #7977
mcma111
mcma111's Avatar
Oddometer: 12,587
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-17-2013, 08:46 AM   #7978
Aaron from Texas
Oddometer: 489
Yeah, Honda OEM.
Noted. That's probably EXACTLY where it's coming from... whoops.
1987 Honda XL600R
Old 06-18-2013, 07:54 AM   #7979
Aaron from Texas
Oddometer: 489
Should I put a small film on the cover side of the gasket as well, or just around the wires?
1987 Honda XL600R
Old 06-18-2013, 07:55 AM   #7980
mcma111
mcma111's Avatar
Oddometer: 12,587
Just the grommet and where the gasket goes over the grommet. The gasket goes on dry.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 12:35 PM.
