Old 06-18-2013, 08:57 AM   #7981
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
Originally Posted by mcma111 View Post
Just the grommet and where the gasket goes over the grommet. The gasket goes on dry.
Cool, that's what I figured. Thanks man, you've always been a big help.
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 06-18-2013, 09:13 AM   #7982
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,785
I ordered a new seat cover with the XL and honda emblem. When I take the seat to the upholstery shop is there any special kind of foam I should ask for? Definitely not stock KTM 2 x 4 seat foam.
Hate gets you nowhere.
Old 06-18-2013, 09:18 AM   #7983
mcma111
mcma111's Avatar
Oddometer: 12,068
A 1/2" of that snazzy memory foam. That way your ass will know where to go...
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-19-2013, 08:41 AM   #7984
Reposado1800
Juicy J fan!
Oddometer: 5,785
My speedometer needle is hunting quite a bit going down the highway. The drive and cable were replaced 2 years ago. Is there a way to open the speedo and lube it up?
Old 06-19-2013, 08:51 AM   #7985
mcma111
mcma111's Avatar
Oddometer: 12,068
Not really. Pull the ODO drive off of the front wheel, disconnect the cable (phillips screw) pull cable and clean/lube. Reinstall. Check the gear drive in the ODO unit.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-19-2013, 10:23 AM   #7986
Reposado1800
Juicy J fan!
Oddometer: 5,785
Ok. Thanks.
Old 06-19-2013, 06:31 PM   #7987
dgman1991
dgman1991's Avatar
Oddometer: 20
the head cont'd
So, I took the head and bore to Santa Cruz to visit my father. We disassembled the head and discovered that I indeed (you were right Steve) need to replace my valves. So I have ordered new valves, and a new set of exhaust guides, as well as a new chain, a new Wiseco piston, and so on. So, once everything comes in.... I should be on the road again
dgman1991 is offline   Reply With Quote
Old 06-19-2013, 09:19 PM   #7988
mcma111
mcma111's Avatar
Oddometer: 12,068
Clarke Tank
Anybody looking for a Clarke tank for their XL600?
I really should take it out of the box to take a picture but there are so many other things to do.
Like drinking BEER.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-19-2013, 10:20 PM   #7989
Reposado1800
Juicy J fan!
Oddometer: 5,785
Check and see if the valve seats are loose.
Old 06-20-2013, 06:26 AM   #7990
brucifer
brucifer's Avatar
Oddometer: 2,427
Like drinking BEER.
What color is it, Steve? I'd be interested if it matches the red of the '83-'84 models.
2014.5 Kawasaki KLR650 NE-2008 Yamaha TTR110-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 06-20-2013, 06:32 AM   #7991
Homerb
Oddometer: 458
At last, l finally picked my new CDI today. Decided to move it from under the tank to under the seat to keep it cooler, so had to splice some longer wires into the harness to reach the seat. Hooked it all up, hit the starter and bingo, spark is back.
Going for a nice long ride tomorrow, no matter what!
Homerb is offline   Reply With Quote
Old 06-20-2013, 10:16 PM   #7992
Aaron from Texas
Oddometer: 489
Alright, XL Experts... I just got the bike running again, and I know these bikes are plagued by the non-pumper carb stumble, but my bike seems to be struggling for fuel. I had the carbs out and completely rebuilt them a couple years ago, but the bike sat since.
I know this bike isn't going to come close to my KTM 690, but I do remember it being quite powerful. It's got the stock jetting and I'm at around 600 ft elevation, what would be a suggested starting point on jetting?
This is a California bike... do I need to service the evap system?
Should I run any carb cleaner through the system? Seafoam perhaps?
I have heard about bending the tang back on the carb linkage to delay the secondary cutting in, and I'm about to try that first...
Any other ideas?
1987 Honda XL600R
Old 06-20-2013, 11:16 PM   #7993
mcma111
mcma111's Avatar
Oddometer: 12,068
Leave the linkage alone. Go up one size each on the pilot and main jet of the primary carb. I actually made my secondary carb hit sooner than later.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-20-2013, 11:27 PM   #7994
Aaron from Texas
Oddometer: 489
Thanks. Should I mess with the clips at all? Everything is currently in the stock setup except for the pilot screw...
1987 Honda XL600R
Old 06-21-2013, 12:09 AM   #7995
mcma111
mcma111's Avatar
Oddometer: 12,068
If you have a needle jet with slots leave the clip in the center position. Usually #3.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 03:02 PM.
