Old 07-07-2013, 03:20 PM   #8176
davek181
davek181's Avatar
Oddometer: 912
Christian:
How high do you want to go with your bike? I agree the rear is easy. I think you would do better either changing the shock to a longer one or extending the stock shock attaching point. Around here for a while it was all the rage for KLR owners to lower their bikes for alleged handling and ride height issues. They would just change the dogbone to do it. It was later discovered by the more astute of the bunch that it changes the ratio of the rear suspension and softened it too much. A friend of mine changed his back to stock after riding thousands of miles on a lowered one. (bought it that way) He was amazed at the difference. I have a spare XR shock if you need it, it is about 1/2" longer.
I have put two different sets of forks on my XL, first XR400's and then CR125 USD,s. The 400's are easiest since they use the same bearings and stem size. The wheel is easily adaptable with a custom built axle, or bearing changes. The bearing change also requires a larger axle sized speedo drive and bearing spacer. You might be able to bore the original, but I lack the skill and machinery to do it so I got one for an XRL off eBay. As far as mounting the gauges goes, I discovered an easy way to do it the second time around on my USD conversion. It is pictured a few pages back on this site, reply 8175, page 513 and 512. That was the hardest part of the fork swap I thought, coming up with a way to mount the stock gauges. I pondered many ideas in my mind before I suddenly thought of an easy way to accomplish it. I used XR650L speedo cable and front brake hose to allow for the longer length on the USD,s. I have an XR400 fork brace I am not using now too, Forks also for that matter, I am very happy with the USD's and don't ever see going back to conventionals.
davek181 screwed with this post 07-07-2013 at 03:47 PM
davek181 is online now   Reply With Quote
Old 07-07-2013, 03:50 PM   #8177
joexr
Oddometer: 3,773
How about taller seat foam and handlebar risers?
Old 07-07-2013, 04:05 PM   #8178
crobox
crobox's Avatar
Oddometer: 324
Dave-
I'll totally take the XR shock! THANKS! I'm guessing that 1/2" at the shock equals 2" or so at the rear axle, right?
I will pm you with my shipping address, let me know what I owe you.
As for the front.... I guess I will start poking around looking for some XR400 forks, while I also ponder other no-money options.
If it weren't for the odometer, letting me know how many miles I'm putting on, I would just give up on the speedometer. I'm using a GPS now to know my actual speed, and the stock speedometer is jumpy and noisy and generally annoying.
I welcome other ideas for raising the front...
Once again, thanks Dave!
Current Bikes: 2006 KTM 950 ADV S, 2002 XR650L, 1988 Hondasuki KLNX250R
Previous Bikes: 1986 Honda XL600R,Honda XL250R (2 of them), Honda XL600R, Kawasaki KLR600, Honda Nighthawk, BMW K1100LT, BMW R100GS, BMW R60/6, BMW K75, Husqvarna 430XC
Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com
crobox is offline   Reply With Quote
Old 07-07-2013, 04:06 PM   #8179
crobox
crobox's Avatar
Oddometer: 324
Yeah... except I also really like the way the raised XLs LOOK. I think they look bada$$.
Plus I also already have the vibration dampening ROX risers (which I love)
Old 07-07-2013, 04:40 PM   #8180
joexr
Oddometer: 3,773
Forking by Frank makes all types of fork tubes to any lenghth and they're not that expensive.
Old 07-07-2013, 04:54 PM   #8181
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,513
Got a link Joe .
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 07-07-2013, 04:56 PM   #8182
joexr
Oddometer: 3,773
Originally Posted by therealbigman View Post
Got a link Joe .
No. Google FORKING by FRANK.
Old 07-07-2013, 05:12 PM   #8183
mcma111
mcma111's Avatar
Oddometer: 12,403
How about some XR600 forks? I have a FEW sets laying about.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-07-2013, 05:34 PM   #8184
davek181
davek181's Avatar
Oddometer: 912
XR600 would work well too. I think they are the same diameter as 400 forks. I have a spare set of 400 forks, but I think my 400 fork brace fits 600 forks too.
Dave
Old 07-07-2013, 09:24 PM   #8185
12120
Indenturedx5
12120's Avatar
Oddometer: 441
xr600 forks
XR 600 cartridge forks Steve?
Chris
If you find yourself in a fair fight, your tactics are wrong.
'83 XL 600r
12120 is offline   Reply With Quote
Old 07-07-2013, 10:02 PM   #8186
crobox
crobox's Avatar
Oddometer: 324
Forking by Frank looks interesting... but maybe expensive.
Steve, what are you looking for for a pair of those XR600 forks?
(I'm sure this has been covered before, possibly ad nauseum, but...) what diameter are those forks? What length? and how much work to use my XL front wheel?
Thanks,
Christian
Old 07-08-2013, 04:49 AM   #8187
mcma111
mcma111's Avatar
Oddometer: 12,403
Yes they are the cartridge forks. I will have to measure the diameter and length. How about $100.00 + shipping?
To work with your XL wheel you will need different bearings, seals and hub center collar/spacer. And a later ODO drive which I have a few of. The later wheel uses a 17mm axle. OH, you'll need an axle also. I should have that too.
Too much??
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-08-2013, 06:10 AM   #8188
mcma111
mcma111's Avatar
Oddometer: 12,403
I measured the forks on my son's XR650l. Same forks. With the bike standing upright the forks are 40" overall. Axle to top of fork is 35". Upper tube diameter is 43mm.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-08-2013, 06:59 AM   #8189
davek181
davek181's Avatar
Oddometer: 912
I just measured 400 forks. 43mm tubes, axle to top of fork 36 1/4".
Out of curiosity I measured the CR forks I just installed and they are 36 3/8", though curiously I am running them at 35 1/4" static sag with XR rear shock and the tubes sticking out of the top triple 5/8" About the same overall sag as I ran the XR400 forks, with it's tubes 5mm out the top.
Seat height at static sag 36 1/2"
Xr rear shock from axle to rearmost bolt hole on frame 23 1/2" full extension, 22 1/2 static sag.
compare those to stock heights to get total lift
Old 07-08-2013, 02:52 PM   #8190
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,092
XR650L forks wont work with your front wheel because the axle is different. Old XR600 dampening rod forks are the easiest to swap in, unless you find 91-92 cartridge forks. This way your axle and wheel will work. They're about 2 inches longer so you'll need a longer brake line and speedo cable along with the proper triples.
I have a set of old XR6 forks and since I'm not on this forum to make money I'll save you the Ebay price and pass them off for $25 shipped. Let me warn you though that they may need a rebuild. They came off a bike I never rode but the rear shock was shot on it and I assume these forks may be in similar shape. They don't stick or anything, but they feel pretty soft, might just be fluid, I don't know. They also have some scratches in the bodies, but the tubes are straight and in pretty good shape. I'd be happy to send you some pictures if you'd like.
Carter Pewterschmidt screwed with this post 07-08-2013 at 02:58 PM
Carter Pewterschmidt is offline   Reply With Quote
Times are GMT -7.   It's 06:47 PM.
