Old 07-29-2013, 01:21 PM   #8416
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,094
Gah crap.
So do I have disassemble again to in the pocket? I don't think I got it in
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 07-29-2013, 01:28 PM   #8417
davek181
davek181's Avatar
Oddometer: 965
Originally Posted by mcma111 View Post
Tools will never be obsolete. Their owners will be some day but someone will always be able to use them.
I can't even remember the last time I used my Snap-on dwell meter or our Sun 1015 oscilloscope. Even our Fluke scopemeters see very limited usage. I can remember the days when all three were used several times daily, especially the Fluke.
davek181 is offline   Reply With Quote
Old 07-29-2013, 01:31 PM   #8418
davek181
davek181's Avatar
Oddometer: 965
Originally Posted by RFVC600R View Post
Gah crap.
You can pop off the clutch cover and visually inspect the lower part of the chain and guides to be sure.
Old 07-29-2013, 01:32 PM   #8419
mcma111
mcma111's Avatar
Oddometer: 12,928
Gah crap.
Better safe than sorry.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-29-2013, 01:34 PM   #8420
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,094
Gah I wish I had money, I'm no mechanic
Imma try again tonight, it's too hot to be in the garage right now.
Old 07-29-2013, 01:39 PM   #8421
mcma111
mcma111's Avatar
Oddometer: 12,928
Hopefully by the time it's all said and done with your motor you will have learned something.
What, I don't know...
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-29-2013, 02:29 PM   #8422
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,094
I can do it and have been learning alot. It's just bonding with the bike I can do regular maintenance type and replacing wear items no problem but taking the engine apart and back together, bleh! I'm sure it will be easier next time. Only spent about $250 for everything so far, alot cheaper than getting everything done the way I would have liked but this is only a temporary fix till i can afford get the original head repaired. It has been 'fun' but I'd rather be riding the old bike.
Thanks alot for your help MCMA111 and Davek181
I definitely learned four things.
1. don't get a 30yo bike on credit
2. I Learned how to use various tools to do maintenance on the bike.
3. Piston rings are sharp
4. Oil the damn bolts
RFVC600R screwed with this post 07-29-2013 at 02:37 PM
Old 07-29-2013, 03:51 PM   #8423
crobox
crobox's Avatar
Oddometer: 324
RFVC600R, are you still struggling with the camchain tensioner?
I came up with a very good way to deal with it last time I had my engine apart. It would take a little remembering, and jogging the memory with a picture of a tensioner, to remember how I did it. But if you are stuck there, I will try.
CR
Current Bikes: 2006 KTM 950 ADV S, 2002 XR650L, 1988 Hondasuki KLNX250R
Previous Bikes: 1986 Honda XL600R,Honda XL250R (2 of them), Honda XL600R, Kawasaki KLR600, Honda Nighthawk, BMW K1100LT, BMW R100GS, BMW R60/6, BMW K75, Husqvarna 430XC
Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com
crobox is offline   Reply With Quote
Old 07-29-2013, 09:56 PM   #8424
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,803
I was bored today and pulled my engine to replace the timing chain. Put the valve cover on and 2 of the 6mm threaded holes took a crap. Anybody know if it is a standard 6mm by 10mm helicoil for those little screws?
The cam timing is going to be different with the new Pro-X chain. Slashes are lined up just a hair before T1 and the old chain was lining up at F1. I took a look at where F1 would be with the new chain and it is quite a bit different than the old one. I should have done this when I did the head.
Hate gets you nowhere.
Old 07-30-2013, 04:28 AM   #8425
mcma111
mcma111's Avatar
Oddometer: 12,928
Those rocker cover bolts are 6 x 1.0 mm
You want to set the cam timing to the T mark on the stator NOT the F
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-30-2013, 06:08 AM   #8426
Reposado1800
Juicy J fan!
Oddometer: 5,803
How long is the thread in those holes?
Will a standard 10 mm length helicoil work or do the need to be longer?
Old 07-30-2013, 06:34 AM   #8427
davek181
davek181's Avatar
Oddometer: 965
I just checked a spare head I have laying around. The shallowest rocker cover holes were 19mm. You could easily put in a coil of 15mm without a bottoming tap, if you can find one.
10mm will work if you are careful since the threads are now steel. Cleanliness of thread and tap and straightness of process is very important. I use the drill press for a tap holder, operated manually of course.
On 6mm holes I prefer Timesert inserts usually, they seem to hold a little better. I put a drop of red loctite on them also for good measure, but only if you have time to let it sit and cure out and run a tap through the hole and spray cleaner rinse. If you have to assemble it all at once you will glue the whole thing together, not recommended.
Old 07-30-2013, 08:06 AM   #8428
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
Well, I pulled the carbs... again....
I put the new diaphram back in, with proper o-ring, and have the air cut-off running like stock. I then cleaned all the jets and everything again, drilled out the seized screw on the throttle stop bracket and replaced it using anti-seize, and threw the carbs back on.
The vacuum hole for the air cut-off just goes through to the throttle body of the carburetor on the engine side, correct? There are no other passages? When I had it apart, I made damn sure that line was clean as a whistle, but couldn't see if there was any other corridor that intersected it...
I can find no leaks anywhere, exhaust or intake... and I seem to still be getting the occasional decel pop. It's not the loud, afterburn "POP!", but more of the occasional "putt-putt...putt" on decel. Sound good? I can take a video if it would help.
I'm running stock on Pilot (which I believe is #62) and #120 Primary and #118 Secondary with 2.5 turns on the Pilot Screw.
My idle seems to be working like it should. It only increases slightly as the engine warms up... I guess this is normal?
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 07-30-2013, 08:13 AM   #8429
mcma111
mcma111's Avatar
Oddometer: 12,928
Stick a fork in it. Your DONE!
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 07-30-2013, 09:46 AM   #8430
davek181
davek181's Avatar
Oddometer: 965
Occasional decel pop is normal. I am glad you decided to fix it right, rather than eliminate the system altogether.
The dual carbs work well when everything is right.
Times are GMT -7.   It's 07:47 PM.
