Old 02-06-2010, 10:47 AM   #76
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,916
So....
mountain eagle /denver was santafe / main jet MJ 155 - 160/ Pilot or low speed jet LJ-42/ Idle air jet IAJ-68 Needle @ 3 / 1.5 turns out / specialty kit no / SAS partial delete / stock exhaust partially drilled / MPG ? / critique - not yet...........?
Question- is the washer under the needle clip a shim or is it stock? If a shim I'm at 2.5 if not I'm at 2
Denver - new to me bike getting baseline notes
MJ - 155/160
LJ - 42
IAJ - 68
Needle - 3
Fuel -1.5
SAS - removed
Stock cans
mpg?
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle screwed with this post 02-10-2010 at 01:49 PM
mountain eagle is offline   Reply With Quote
Old 02-10-2010, 09:49 AM   #77
mountain eagle
terrorist
Oddometer: 2,916
Bump for Geek
mountain eagle
KTM 950SE
my smugmug gallery
Old 02-10-2010, 10:02 AM   #78
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,779
Originally Posted by mountain eagle
Bump for Geek
Mine:
7,000 ft.
MJ - 150/152
LJ - 42
IAJ - 68
Needle - middle (3?)
Fuel -2
All SAS/canister stuff removed
Akrapovich
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 02-10-2010, 10:06 AM   #79
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,096
I don't wanna take it apart yet.
Its like breaking the "beer seal". Once you start you can't stop.
I'm going to have to get colored bins to keep track of what belongs on the 610 and what belongs on the 950... or better yet I should set up another workshop in the 2nd garage and keep them separated
Is there a decent service manual available for the LC8?
All my SAS/canister stuff is removed and the stock cans have been de-catted and put back together.
Old 02-10-2010, 11:59 AM   #80
Yellow Pig OP
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,398
Duke:
Did you re-jet for Baja or just run the jetting you posted above?
Yellow Pig is online now   Reply With Quote
Old 02-10-2010, 12:04 PM   #81
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,779
Originally Posted by Yellow Pig
Duke:
I rejetted. I've run that jetting down to about 700' before- it worked but you could really tell it was lean.
I just changed the mains to 158/162 for Baja and it ran GREAT!
Man, I wish we could keep that sea-level power up here!
Old 02-10-2010, 04:22 PM   #82
Oldwin1
Oldwin1's Avatar
Oddometer: 1,637
Geek
The answer is that every 950 is different. Practice taking the tanks off. It comes in handy when the boots let loose and the carbs start bouncing around inside the air box in the middle of Wyoming. You access the screws to the boots from the right hand side. I of course started from the left side.
Western Dual Sport Motorcycle Adventures
www.wdsma.com
Oldwin1 is offline   Reply With Quote
Old 02-10-2010, 04:57 PM   #83
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,779
Originally Posted by Oldwin1
Geek
I'm sure he'll get plenty of practice when he re-jets.
Old 02-12-2010, 12:48 PM   #84
homerj
742 Evergreen Terrace
homerj's Avatar
Oddometer: 5,242
Or does damn near anything else on that bike. I love that bike, but man, every time I start working on it, I just take the tanks off. I'm considering making a "950 tank rack" in the rafters of the mini-deluxe garage.
09 570 Rallye Beast
"Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba…"-Hunter S. Thompson
homerj is offline   Reply With Quote
Old 02-13-2010, 04:21 PM   #85
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,779
You have obviously never worked on a V4 Honda.
4 carbs wedged between the V, 16 valves to adjust. My ST1100 had dozens of screws and panels to take off just to do an oil change. I don't think the 950 is that bad.
Old 02-13-2010, 05:40 PM   #86
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,096
I hear you Duke.. my K1200LT took over an hour to "de-fair".
... my CBR600F2 was such a pain in the ass to change the center two spark plugs that I would bet money 75% of CBR600's run the same two center spark plugs their entire life
That said... I'm still considering if I wanna figure out how to hold the fuel tanks on with 1/4 turn Dzus fasteners
Old 02-13-2010, 06:11 PM   #87
309
Special Purpose
309's Avatar
Oddometer: 5,464
When has a Honda ever needed a valve adjustment or sparkplug change?
309 is offline   Reply With Quote
Old 02-13-2010, 07:02 PM   #88
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,096
That's true. After riding my F2 for 10 years and 243508234508208 miles I checked the valves and they were still in spec. Then I raced it a year and at the end of the season when I sold it they were still bang on. It still had the original spark plugs too
Old 02-13-2010, 07:28 PM   #89
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,779
My '84 Sabre needed the occasional valve adjustment. Usually it was only one or two of the 16.
Old 04-16-2010, 07:13 PM   #90
mountain eagle
terrorist
Oddometer: 2,916
Bump.....
MJ - 155/160
LJ - 42
IAJ - 68
Needle - 3
Fuel -1.5
SAS - removed
LeoVince - 480mm with spark arrestor
Sucky......... 28-30mpg, it was that way with stock cans too.
mountain eagle
KTM 950SE
my smugmug gallery
Times are GMT -7.   It's 11:14 PM.
