Go Back   ADVrider > Riding > Regional forums > The Rockies It's all downhill from here...
Old 04-16-2010, 06:51 PM   #91
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,843
We should have an LC8 jetting and carb sync day?
Old 04-16-2010, 06:55 PM   #92
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,926
funny.... I thought a few people had mentioned doing that stuff at the tinker........ yet mine was the only one there
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is offline   Reply With Quote
Old 04-16-2010, 07:04 PM   #93
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,843
I know ... sorry I missed it
Perhaps we should have an LC8 tinker!
Old 04-16-2010, 07:06 PM   #94
mountain eagle
terrorist
Oddometer: 2,926
I'm game......... I still NEED to put the extra tank on and plumb the gas.......
Anyone else?
mountain eagle
KTM 950SE
my smugmug gallery
Old 05-01-2010, 11:38 PM   #95
mountain eagle
terrorist
Oddometer: 2,926
Bump?
I'd like to copy YellowPigs aux fuel routing and add the aux wiring for stuff before too long. As well it would be good to check the valves if anyone has experience with that......
DAG's available of course............
mountain eagle
KTM 950SE
my smugmug gallery
Old 05-02-2010, 09:34 AM   #96
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,843
I'm definitely up for some LC8 learning Mountain... pick a date and let me know.
I'll need time to order/receive a jet kit.
Old 05-02-2010, 04:28 PM   #97
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,984
Me three! Need to change my oil and put a 908 on the rear. But, depending when this day is I will do that stuff by then.
'06 KTM 950S Adventure
'12 Ram 2500, Cummins, 6-speed auto, Laramie Longhorn, RamBox.
DakarNick is offline   Reply With Quote
Old 05-02-2010, 05:49 PM   #98
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,843
I did my oil today. what a pain in the arse
I'm going to hook up some sort of hose with a valve to the bottom of the oil reservoir that hangs down into the skidplate so I don't have to drop the fuel tank.
Old 05-02-2010, 06:08 PM   #99
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,037
I just put a funnel under the oil res. and open it without taking off the tank. But your way sounds cleaner.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 05-02-2010, 06:48 PM   #100
pfb
Riding, not skiing.
pfb's Avatar
Oddometer: 5,515
We definitely need to do an LC8 tech day.
I'm happy to host, or if Mountain wants to offer up the DAG...
950 Adventure 950 Super Enduro 450 XC-W Six Days
pfb is offline   Reply With Quote
Old 05-02-2010, 07:45 PM   #101
pfb
Riding, not skiing.
pfb's Avatar
Oddometer: 5,515
155/160 should be the stock jets in your Adventure, and they work pretty well for most people at our altitude with aftermarket pipes. Biggest change from stock is lifting the needle to middle clip (if you haven't done so yet) and tuning the idle mixture screws.
Performance Cycle also keeps most jets in stock, so you shouldn't need to order anything unless you want to use Head2Winds jetting.
If you do, I have one of those for sale I bought it from YellowPig, but decided not to use it. Includes the Uni pre filter as well and all the Head2Wind recommended main jets, bleeds and idle jets (but they are all tuned for use *with* the pre-filter).
R&D Racings remote fuel screws look like they would be pretty handy, perhaps worth the $100 cost. They allow tuning of the 950 fuel mixture screws without removing anything.
pfb screwed with this post 05-02-2010 at 07:52 PM
Old 05-02-2010, 07:57 PM   #102
mountain eagle
terrorist
Oddometer: 2,926
I'm good with hosting, just need to figure out when is good.......
mountain eagle
KTM 950SE
my smugmug gallery
Old 05-02-2010, 08:08 PM   #103
pfb
Riding, not skiing.
pfb's Avatar
Oddometer: 5,515
I just tweaked the jetting on my SE. It was running great, but I had a huge amount of decel popping & burble, even more noticable when I put on the 2 into 1 collector (running a single FMF). The fuel mixture screws were in too far (1 turn out!).
Current setup on SE:
Stock mains (155 Front /160 Rear), stock low speed (42), stock idle air (68), Fuel screws 1.75 out, needle middle clip (was 2 down).
Opening up the fuel screws cut way down on the decel popping, but I might open them up another 1/8 or 1/4 turn. If I had the R2 remote screws, I'd tweak them to my hearts content, but pulling the carbs (and all that is involved with that) just to give them an 1/8 turn tweek will have to wait until the next time I at least have the tanks off for some other reason.
Old 05-17-2010, 01:05 PM   #104
mountain eagle
terrorist
Oddometer: 2,926
Bump? Any preferences on a DAG 950 date? Maybe the 29/30th, hell I'm fine with next weekend too.... Hell if someone wants to come guide I'm good with any afternoon or evening...
I would like to change the oil and check the valves soon and wouldn't mind guidance from someone who's done it a few times............
Also looking to do the ned tank ala YP, I've got the new facet mounted and it's nice there under the seat....... just need to plumb everything.
Also with BeemerPat's help we're modifying the left side Holan rack to work in conjunction with the Ned Aux tank, should turn out nice.
Bueller?
mountain eagle
KTM 950SE
my smugmug gallery
Old 05-17-2010, 01:14 PM   #105
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,984
Bueller?
I'm off the next two weekends, the 22/23 and 29/30 so I'm fine with whatever suits others.
Guys?
I got my rear 908 on, my front TKC rotated, and oil is done. I'd be interested in doing an oil drain extension. But don't forget, the screen still needs cleaned which means pulling the tank.
Times are GMT -7.   It's 05:40 AM.
