Old 08-04-2011, 01:43 PM   #46
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,475
Originally Posted by ADV8 View Post
I thought the RM250 had the same Twin piston Showa fork as RMZ 450 (maybe not)
nice conversion! no, the 1983 to 1988 rm250 forks werent upside down. these slot straight into the DR triple clamps, and the DR front wheel, axle, speedo drive and spacers work perfectly. BUT you need to make a caliper adapter plate to suit the DR front disc. same conversion works on the older RM125 and RMX250 forks (e.g. 43mm fork stancheons like the DR650). before they went upside down.
edit: correction, the rmx250 fork stancheons are 45mm so you will need the triple clamps as well. but front axle and spacers etc identical to the RM so the DR650 wheel will slot in easily, just make a caliper adapter plate to suit. rmx forks have the added advantage of adjustable rebound damping.
B1 screwed with this post 09-15-2011 at 11:44 PM
B1 is offline   Reply With Quote
Old 08-20-2011, 09:08 PM   #47
chipwich
chipwich's Avatar
Oddometer: 114
Nicely done ADV8. That certainly solves the rotor issue.
I finished my conversion to white today...
1971 Honda Z50A K2 Mini Trail
2006 Suzuki DR650SM
chipwich screwed with this post 08-22-2011 at 11:53 AM
chipwich is offline   Reply With Quote
Old 09-15-2011, 05:01 PM   #48
greener556
Oddometer: 115
I installed a set of RM250/125 forks on my Dr650. I'm running a 120 front tire, I've got minor tire rub on the left fork when braking heavy. Are the wheel spacers the same??
Does anyone have any pics of a Vapor speedo pickup mounted to a 320mm front rotor. I'm thinking it's gonna have to be mounted off the back wheel.
greener556 is offline   Reply With Quote
Old 09-15-2011, 06:00 PM   #49
Navaho
Navaho's Avatar
Oddometer: 1,043
Wow! That is sharp!
I miss my DR. I was thinking about tardin' it but I didn't. I'm thinking about buying it back from the current owner. Even with it's weakness, it was still the most enjoyable bike I've owned. I just got bored with it in dirt trim. I bet the sumo conversion is a blast.
'07 450EXC, '06 950 Supermoto, '09 YZ450F
Navaho is offline   Reply With Quote
Old 09-15-2011, 11:47 PM   #50
B1
B1's Avatar
Oddometer: 3,475
you didn't mention year model of your forks. far as i can make out, the 1983 to 1988 rm250 and rm125 forks are all the same (slightly softer springs in the 125). 43mm stancheons slot straight into the DR650 triple clamps. axle, and wheel spacer on the non-speedo drive side are identical. even the brake line mount gets screwed on at the same spot on the fork.
i didn't get an RM front wheel with mine, but assume they have a spacer in place of the speedo drive. tyre goes nowhere near the fork leg on mine under braking.
if anyone is thinking of doing this, i used 10w fork oil, put the damping on the maximum setting, and preloaded the springs by an inch. seems to work a treat for my 95kg, havent hit any big jumps yet but doesnt feel anywhere near bottoming out on smaller jumps and hitting woops fairly hard. forks were only $150 on ebay, $20 for heavier fork oil, so very happy with the result.
dodgy brothers way is just superglue a magnet to the front disc. done it before when the vapor setup wouldnt work, got the "rare earth magnets" on ebay for a few bucks.
Old 09-15-2011, 11:55 PM   #51
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,385
You need to check the tyre/tire is centred in the forks.
When I mentioned RM250 forks some time back I meant the USD fork RM250's,that's all.
Are they the same as the Showa RMZ fork or a Kayaba USD.
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 09-15-2011, 11:58 PM   #52
B1
B1's Avatar
Oddometer: 3,475
Concerning the RM250 fork conversion, that works well unless you want a 320 rotor, then I'm not sure what you would do. A DRZ400SM fork would be better IMO, although pricier and most likely harder to come by. Regardless, the stock fork works well enough with the right spring rate and fresh oil. Then there is Race Tech valving.
very late reply, but a bit of useful info if anyone else is thinking of this. if you can get the RM front wheel included, from what i've seen all the RM models share the same front disc bolt hole pattern as the DRZ400 and DRZ400SM (check specs for any particular year on metalgear.com.au). you can get a drz400sm 310mm disc new on ebay posted for around $130. then buy the 310mm caliper adapter plate for $30 from here and just machine the spacers specified. a 310mm rotor makes it a lot easier to change wheels over, there's very little room to squeeze the caliper on with the 320mm disc.
Old 09-16-2011, 02:08 PM   #53
greener556
Oddometer: 115
I'll try and get some pictures posted of my bike. I just got it wrapped up yesterday.
How can the tire be moved to the right?? (if it's not centered)
Old 09-16-2011, 05:10 PM   #54
B1
B1's Avatar
Oddometer: 3,475
machine new wheel spacers to get it centred. easy way to do this is buy a pile of big washers that will fit on your front axle, try to get different widths (e.g. 2 and 3mm widths) so you can use combinations to make up any size.
when you've got the right number on each side to get the front wheel centred, tighten up the axle to make sure it all works nicely. you'll now find your disc is out of alignment probably, so loosen the caliper bolts off so you can get the wheel properly centred. next you'll need a bunch of washers to work out what caliper spacers you'll need to get the disc aligned correctly. tighten the caliper bolts to make sure the disc is centred in the caliper.
when it all works, just get the wheel and caliper spacers machined to suit from alloy round bar.
Old 09-17-2011, 06:09 AM   #55
chipwich
chipwich's Avatar
Oddometer: 114
For the Warp 9 320 rotor I just used some JB Weld to place the magnet on the rotor, but for the EBC 320 on my stock hubs, I had to use one of the replacement rotor bolts with built in magnet. Even then I had to remove a slight bit of the lower inside of the left fork slider to clear the bolt. The EBC rotor on the stock hub is a very tight fit. For both I used two large nylon ties to attach the sensor.
2006 Suzuki DR650SM
Old 09-17-2011, 07:43 AM   #56
greener556
Oddometer: 115
Do you know if anyone of these with fit the EBC rotor??
http://www.trailtech.net/R011-XR.html
http://www.trailtech.net/R011-KTM.html
Old 01-31-2012, 12:35 PM   #57
FloridaSteve
FloridaSteve's Avatar
Oddometer: 2,082
Is this thread dead?
FloridaSteve is offline   Reply With Quote
Old 01-31-2012, 03:33 PM   #58
Speedo66
Transient
Oddometer: 6,930
Hi, have some DR650 parts, including a pipe, for sale here http://www.advrider.com/forums/showt...8#post17879488
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is online now   Reply With Quote
Old 02-01-2012, 08:12 AM   #59
chipwich
chipwich's Avatar
Oddometer: 114
Well done FloridaSteve. Good looking DR tard!
2006 Suzuki DR650SM
Old 02-16-2012, 10:50 AM   #60
Burnt Toast
Slingshot: engaged.
Oddometer: 227
To cush or not to cush...
Ok all, looking to add some moto rims to the bike. Seen a lot about cush drive, but no definitive good or bad to not having it. For those who have cushless or have ridden cushless, what say ye?
Burnt Toast is offline   Reply With Quote
Times are GMT -7.   It's 09:49 AM.
