Old 03-21-2011, 05:17 AM   #1561
Bounder
ExternallyDisplaced
Oddometer: 886
There is one in front of the cylinder that attaches to a small metal stay.
On on the side and two on the the headlight surround
Bolts numbers 28 x2, 23 x 1, 24 X 1
There is a kind of plug that fits into a rubber grommet on the tank to hold it in place as well, you can see it on the right side of the diagram.
Bounder is online now   Reply With Quote
Old 03-23-2011, 03:24 AM   #1562
switch
Romanian Trailbiker
switch's Avatar
Oddometer: 678
Has anyone replaced the stock airbox with a bolt-on air filter? If so, what did you use? Any of you test the actual airflow? Any problems with this?
No bikes right now :( Used to own the best dommie in Romania and a damn-good R1100GS. Modded the hell out of both before selling them. Looking to get another bike soon.
switch is offline   Reply With Quote
Old 03-23-2011, 06:29 AM   #1563
Bounder
ExternallyDisplaced
Oddometer: 886
No but I got a BMC filter as a replacement for the stocker which had disintegrated in the 9 years since I last rode the bike.
Very pleased with the materials and construction of the filter.
Not badly priced on Ebay.uk either.
Old 03-23-2011, 06:35 AM   #1564
switch
Romanian Trailbiker
switch's Avatar
Oddometer: 678
Well that fits the airbox that is no longer there. Therefore it's useless.
Old 03-23-2011, 06:37 AM   #1565
Bounder
ExternallyDisplaced
Oddometer: 886
Have a look at the BMC site they list lots of clamp on cones that could fit the NX carb.
They are very well made filters comparable or better than K+N
Old 03-23-2011, 07:12 AM   #1566
wolfy317
Addicted to BMW
wolfy317's Avatar
Oddometer: 3,496
Just put a deposit down on Big_John's NX. Can't wait to get it home. It's gonna look nice sitting next to my wife's nx250 :)
Now it's time to read this thread through.
'71 BMW R75/5 | 09 GSA
FLICKR
wolfy317 is offline   Reply With Quote
Old 03-23-2011, 07:14 AM   #1567
Bounder
ExternallyDisplaced
Oddometer: 886
Congratulations on that bike it looks sweet after the refurb.
I have an '88 US model NX, you are going to enjoy the ride!
Old 03-23-2011, 08:31 AM   #1568
wolfy317
Addicted to BMW
wolfy317's Avatar
Oddometer: 3,496
Thanks, I'm excited!
FLICKR
Old 03-23-2011, 03:26 PM   #1569
Cigar Mike
Too Old and Too Slow
Cigar Mike's Avatar
Oddometer: 1,484
Difference between US and European Models?
Specially the frame difference if any. And was the frame changed in 91?
It has to do with mounting the centerstand to non US models.
Thanks,
Mike
When in doubt, give it Gas!
Cigar Mike is offline   Reply With Quote
Old 03-24-2011, 01:55 AM   #1570
switch
Romanian Trailbiker
switch's Avatar
Oddometer: 678
Thanks,
Mike
No major difference in the underside of 88-94 NX 650 bikes, regardless of UK/US/EU/other country of manufacture.
Old 03-24-2011, 03:34 AM   #1571
Bluesmudge
Bluesmudge's Avatar
Oddometer: 117
Originally Posted by burbansk View Post
Bluesmudge, I Just put my Hagon on this weekend ( Very nice piece ). I tried to do the same adjustment while of the bike and the whole top of the shock wanted to turn. I have my stock air box on but not my SuperTrapp exhaust yet. After hearing of your problem, I think that I better take the air box off and make all adjustments now. Probably going to crank her down a bit, I am around 220 pounds. Please let me know if you figure any tricks out. Thanks, Bruce.
I used adjusting my preload as an excuse to repaint my exhaust. With the exhaust off I could easily adjust the preload from the right side of the bike using the tool included with the shock and a hammer. The ring would not move by hand, so I had to bang on it for awhile. Be sure not to go more than 10mm of additional preload as stated in the limited instructions included with the shock. I think this is about 5 complete turns of the preload adjuster. I did the maximum and it might be a little bit too much for just me at 200 pounds, but it should be perfect when I have my hard bags and full gear on.
The Hagon shock and some bar risers have made this a completely different bike. I rode it aggressively around town and down some stairs and it seems loads better, I can't wait to get it into the dirt.
Bluesmudge is offline   Reply With Quote
Old 03-24-2011, 08:20 AM   #1572
Cigar Mike
Cigar Mike's Avatar
Oddometer: 1,484
I was sure you would have the answer.
Thanks,
Mike
Old 03-24-2011, 09:01 AM   #1573
burbansk
Exit222
burbansk's Avatar
Oddometer: 230
Laugh
Thanks for the info, I tried to turn the ring with the tool by hand ( after loosening the set screw ) and it would not budge. Will try the rubber mallet trick today. Would you mind telling me what brand bar risers you are using? I should get a pair too. Also does anyone know of any bigger foot pegs for the NX? My $1800.00 bike is up to $4000.00 now.... Dont tell the wife!!!
Bruce Urbanski, 2000 BMW GS 1150, 2004 Polaris 330 Magnum 4x4, 2000 Honda 350 Rancher.
burbansk is offline   Reply With Quote
Old 03-24-2011, 09:35 AM   #1574
switch
Romanian Trailbiker
switch's Avatar
Oddometer: 678
My bike investments (including initial purchase) sum up to more than twice the usual resale value around where I live. So yea, I know how you feel. At least I don't have a missus to hold me accountable for my spendings
Old 03-24-2011, 12:27 PM   #1575
Bluesmudge
Bluesmudge's Avatar
Oddometer: 117
Yeah...I have a $1300 NX with $1500 more into it
I put on 2" rox risers. I got the rox instead of standard (cheap) risers because I wanted the extra adjustability. My hand guards had been interfering with my high capacity tank and my fairing. As far as cables go for the 2" risers, you definitely need a longer brake line, so its a good excuse to upgrade to stainless steel. The throttle cables are just long enough, and everything electrical has plenty of slack. The clutch cable has turned out to be too short and I am going to have a to figure out a longer one to use.
Times are GMT -7.   It's 06:47 AM.
