Old 02-15-2013, 12:56 PM   #2731
mas335
xendurist
Oddometer: 1,974
No, If yours is original then like all electrical components they don't last forever, in this case we are talking about a 25 year old electrical component.
First I would check all your electrical connections, especially the coil and kill switch before buying a CDI. I never leave home without a spare CDI on board. Did you bump ( shut off) the kill switch while riding??
I assume you have the lights, horn, turn signals, starter working but no spark?
Transalps
mas335 is offline   Reply With Quote
Old 02-15-2013, 01:04 PM   #2732
Pasoren
Oddometer: 13
Have you checked the ground/earth for the CDI? I also think that if the rev counter gives a slight jump when you turn on the ignition it is ok. Don't quote me on that though.
Pasoren is offline   Reply With Quote
Old 02-15-2013, 01:40 PM   #2733
mas335
xendurist
Oddometer: 1,974
Good thinking and although the wiring harness schematic shows the CDI as being grounded there is no independent or separate grounding of the CDI. The CDI ground is within the main harness wiring. Cleaning all the associated ignition connections should include the CDI connection which does have a ground pin.
You could also have a bad coil or just a loose ignition wire to the coil, I think it is the black/yellow wire found in the left side of the frame near the front of the fuel tank area, check that connection.
I would spend a little time making sure the kill switch is functioning right.
Most CDI's that go bad usually start to work intermitently or cut in and out but it is possible for one to just die instantly.
Transalps
Old 02-15-2013, 01:55 PM   #2734
Bounder
ExternallyDisplaced
Oddometer: 847
Originally Posted by dstriffler View Post
I was tapping it, smacking it, and cursing at it but it doesn't want to work. I thought they used to be really expensive, but I found one at partzilla for $96. I've had dozens of bikes and never had one fail on me. Do they fail often?
Seems to be common on these bikes now, Shindengen CDI failures be seem to be mainly dry solder joints cracking.
I have one in the drawer with half the potting compound peeled off that I was intending on cleaning and resoldering.
Just be careful the plugs on the replacement CDI are the same with sidestand cutouts etc.
MIne felt like a new bike with the new CDI in it.
Bounder is offline   Reply With Quote
Old 02-15-2013, 02:26 PM   #2735
dstriffler
Oddometer: 378
I had just put new turn signals on so I originally thought I botched wiring somewhere, but I've gone over everything. Kill switch, ignition coil, all seem to be fine. No loose connections, nothing grounding out. It is strange when the bike died it just flat stopped running, it didn't sputter and die. And before this I have never had a problem with the bike starting or running. EVER. Its an old air cooled Honda, they don't die. But I'm really lucky it happened a few miles from my house and I was able to put the bike in the truck and get it home. If this had happened on a long trip I'd be screwed. So I'll either buy a second CDI, or just open up mine and fix it. Here is the link to the CDI:
http://www.partzilla.com/parts/searc...ESS/parts.html
dstriffler is online now   Reply With Quote
Old 02-15-2013, 03:01 PM   #2736
mas335
xendurist
Oddometer: 1,974
good luck, hope that solves your problem. Great source for parts, been using them for several years.
Transalps
Old 02-15-2013, 03:27 PM   #2737
Bounder
ExternallyDisplaced
Oddometer: 847
Get a new one and repair the old one as a spare.
Peace of mind is worth it.
The old one has lasted two decades so they aren't that fragile.
Old 02-15-2013, 04:03 PM   #2738
dstriffler
Oddometer: 378
I don't want to run the risk of any of this happening again, so I went for the trifecta: Ignition coil, CDI, kill switch.
Old 02-15-2013, 05:15 PM   #2739
Skapegoat
Oddometer: 96
First off road experience today on the dommie today.
Had great fun!
So here goes,
A pic of her with a fancy backround still looking clean!
Then hit some mountain roads and this motox playground!
I headed for some tails , this one ended before the water fall.
After this pic I tried to get closer and the trail got ALOT more difficult, I did fall over but he crash bars saved the day!
Not to self giant rocks are hard to drive on!
First impressions are the bikes a guddun!
400kms and no probs so far, it can off road very well if a bit heavy!
I am not the most talented off roader but how the hell do you drive on just rocks! Big ones!
Now tommorow I will wash the bike and tighten the saggy chain!
Skapegoat is offline   Reply With Quote
Old 02-16-2013, 04:43 AM   #2740
Honda Scoot
My First Gold Chain
Honda Scoot's Avatar
Oddometer: 364
I started riding dual sports after 25 years of only street bikes, so I'm no expert. This page was a good source for me:
http://www.flamesonmytank.co.za/offRoad.htm
Slowing down and then gently accelerating through an obstical works best for this old rider.
Good to know your guards work!
Honda Scoot is offline   Reply With Quote
Old 02-16-2013, 05:37 AM   #2741
CNRED
It'll be OK
Oddometer: 602
+1, I have a spare for each of my bikes.
2011 WR250r
2007 BMW f650GS
1988 Honda NX650 - X2
1982 Honda GL1100 - X2
CNRED is offline   Reply With Quote
Old 02-16-2013, 08:43 AM   #2742
dstriffler
Oddometer: 378
I'll keep the old parts, and use them as spares I guess. But now she has to sit apart until the new parts arrive.
Old 02-17-2013, 04:28 AM   #2743
Pasoren
Oddometer: 13
Keep us posted! :-) Lots of useful info available on this thread for other Domi owners...
Old 02-17-2013, 09:20 PM   #2744
Honda Scoot
My First Gold Chain
Oddometer: 364
Rothmans NX650
dstriffler
We have both mentioned a Rothmans style paint job. I found this version on a NX650.
This is different than I had envisioned, but it is nicely done!
Link to the site: http://www.scodellamelo.it/foto/garage/dom/10/10.php
Old 02-18-2013, 12:34 AM   #2745
Bounder
ExternallyDisplaced
Oddometer: 847
That looks cool, I like the NXR750 version as well.
Times are GMT -7.   It's 04:02 PM.
