Old 06-25-2013, 02:48 AM   #2941
drmracni
Montenegro
drmracni's Avatar
Oddometer: 285
- Hey people, don't eat yellow snow
Honda Dominator
- https://www.facebook.com/niksicadventure
-Montenegro ride http://www.advrider.com/forums/showthread.php?t=481614
drmracni is offline   Reply With Quote
Old 06-26-2013, 02:35 AM   #2942
Skapegoat
Oddometer: 96
Great pic Drmracni!
What Tyres is the dominator wearing there?
Saharas?
Skapegoat is offline   Reply With Quote
Old 06-26-2013, 04:51 AM   #2943
drmracni
Montenegro
drmracni's Avatar
Oddometer: 285
Originally Posted by Skapegoat View Post
Great pic Drmracni!
Saharas?
Thank you Skapegoat, those are Mitas E09
Honda Dominator
drmracni screwed with this post 06-26-2013 at 05:23 AM
Old 06-26-2013, 05:36 AM   #2944
drmracni
Montenegro
drmracni's Avatar
Oddometer: 285
what do you recommend for engine guard and side case?
Honda Dominator
Old 06-26-2013, 12:42 PM   #2945
MartiniUp
Oddometer: 1,924
Take that lock nut off the valve stem or back it up to the cap.
MartiniUp is offline   Reply With Quote
Old 06-27-2013, 01:45 AM   #2946
Pasoren
Oddometer: 13
Why? Will it cause a leak at the stem?
Pasoren is offline   Reply With Quote
Old 06-27-2013, 02:29 AM   #2947
panhead_pete
Oddometer: 1,139
If the tube moves at all it will rip the valve stem out of the tube, backing it off allows a little movement in the stem.
More gear and still no idea.
panhead_pete is offline   Reply With Quote
Old 07-03-2013, 10:21 AM   #2948
Skapegoat
Oddometer: 96
Well it finally happened, I got to cockey, bit off more than I could chew and crashed!
After 3hours on my own in the bog I decided the big had won!
I called for back up and got out but I learned my lesson!
Old 07-03-2013, 02:35 PM   #2949
Bounder
ExternallyDisplaced
Oddometer: 877
You'd have made that if you had proper knobbies.
Its always going to be hard going on a heavy bike with semi-trail tyres on that kind of wet ground.
Was there any damage to the bike or you?
Why is that bank there anyways, is it to stop joyriders driving cars down there and burning then out?
Bounder is offline   Reply With Quote
Old 07-03-2013, 03:23 PM   #2950
Skapegoat
Oddometer: 96
I got off with a few sore muscles and some pride hurt.
The bike faired out perfect to be honest!
Not a scratch.
Yep need a new set of Tyres on her, can't decide between Metzler saharas or something like Mitas like the fellow above.
Looks like it was dug out recently to stop people stealing turf.
It's was very wet at the lowest section.
We may have to meet up Bounder and give the bikes a run.
You doing the Paddy Dakar this year? Still entries left as far as I know.
Old 07-04-2013, 02:09 AM   #2951
drmracni
Montenegro
drmracni's Avatar
Oddometer: 285
Hey, can you please talk slowly, I didn't understood all
and it seems important, valve, rip, steam :)
Honda Dominator
Old 07-04-2013, 03:42 AM   #2952
Bounder
ExternallyDisplaced
Oddometer: 877
If your valve lock nut is tight and the tyre slips around the rim, the force will rip/pull the valve out of the tube.
This is a big problem if you don't have a spare tube as you cannot fix it.
So leave the lock nut loose so if the tyre slips the valve will tilt giving you warning to let the pressure down and reposition the tyre.
Old 07-04-2013, 03:46 AM   #2953
Bounder
ExternallyDisplaced
Oddometer: 877
Not a scratch.
Great result, I haven't thought about doing anything but getting mine back on the road.
I just got the forks back yesterday from the engineer who has made a bracket to fit my Brembo caliper to the 320mm disc.
I needed to mount them up to see if the setup needs any adjustment but haven't had time with work ...
Old 07-04-2013, 06:20 AM   #2954
drmracni
Montenegro
drmracni's Avatar
Oddometer: 285
ou that, yea thanks for advice. I will have to buy a I dont know the correct pronounce, its a piece rubber that goes in the rim, on opposite side of the valve and don't allow tube to rip the valve. there is a hole for it.
Honda Dominator
Old 07-04-2013, 06:45 AM   #2955
drmracni
Montenegro
drmracni's Avatar
Oddometer: 285
Honda Dominator
Times are GMT -7.   It's 12:21 PM.
