Old 04-12-2010, 02:29 PM   #826
McVick
McVick's Avatar
Oddometer: 233
Brad,
Does your rack mount to the inside like this?
I'm wondering if it should be run to the outside?
Brian McVickers
'88 Honda NX650, '05 KTM 950Adventure, '01 Land Rover DII
www.overlandjournal.com, www.expeditionportal.com, www.overlandrally.com
McVick screwed with this post 04-12-2010 at 02:35 PM
McVick is offline   Reply With Quote
Old 04-12-2010, 03:49 PM   #827
Chromejr
Oddometer: 64
Originally Posted by Brad Felmey
I would verify that proper fuel flow is coming from the petcock.
I believe this was the problem! very poor flow, I have it soaking now, will give it a shot in the morning! Thanks a ton
Chromejr is offline   Reply With Quote
Old 04-12-2010, 07:10 PM   #828
Carlossal
Professional dreamer
Oddometer: 14
Laugh Oil Change
Originally Posted by mikejohn
Time has come for me to drain the awl out of my NX, i have not done this with a bike that hold the awl in the frame, so if this unworthty one might ask what is the proper way to do this? drain from the motor and the frame both? and also what would be the correct amount to fill it back up? Thanks
Hi MikeJohn;
IF you're draining the oil, I reckon you're doing a change. In this case, you need to run the engine till it's warm then switch it off, remove the dipstick then remove the oil drain plug in the frame (near the top of your bashplate on the downtube). THere should be a good quantity of fairly dark oil in there! ONce that's drained, the engine plug is over near your gear selector and that should also be drained. The three bolts on the right hand case just below the cylinder hide your oil filter. Someone else mentioned oil screens, I've checked these out on my bike and never had any gunk in them, plus you have to remove the right crankcase ($30 gasket) so it's up to you.
MY manual recommends kicking the kick starter a couple of times to remove all excess oil - make sure your kill switch is off! I did it with my wife's NX but she has no kick starter, I used the electric starter and oil came flying out of the drain hole onto the floor!
My manual reckons 1.8 litres or something to go back in, but you should put a bit over 1 litre (or quart, or whatever!) in first, run the bike a little and then top it up to the proper level on the dipstick.
Hope this helps and enjoy your NX
Carlossal is offline   Reply With Quote
Old 04-12-2010, 08:10 PM   #829
mikejohn
mikejohn's Avatar
Oddometer: 821
Originally Posted by Carlossal
Hi MikeJohn;
i bought the bike off of eBay. i don't think the guy took care of it so i am going to go thru it and give it a good going over, the cases seems to have a lot of oxidizing, any good way to clean that off?
mikejohn is offline   Reply With Quote
Old 04-12-2010, 08:19 PM   #830
HeadTrauma
¯\_(ツ)_/¯
HeadTrauma's Avatar
Oddometer: 1,246
What manual is that?
1995 XR628R -Lots of goodies...room for more.
Drinking: Funky Cold Medina.
HeadTrauma is offline   Reply With Quote
Old 04-13-2010, 07:07 AM   #831
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,445
The problem with this is you will be pumping the oil out of the oil pump. This is not good because sometimes these pumps have problems refilling.
Pablo83 is online now   Reply With Quote
Old 04-14-2010, 04:55 PM   #832
Carlossal
Oddometer: 14
Question Too many manuals
Pablo83 - I can see how that would be a problem! You'd hope that if your oil pump was working well it wouldn't be an issue, but...
Now I feel like a dick: it says that in my Clymer 85 XL250R manual , not the 88-89 NX650 shop manual I've got ! They're both old RFVC engines though, so I wouldn't have thought they'd be that different...
MikeJohn, I've seen a thread recently where a guy did up an old army xt600, and he cleaned up his bike using wire brushes, degreaser, steel wool, whatever did the job. I think he may have used alubrite on his cases. He doesn't really say but I'm sure you could ask him.
http://advrider.com/forums/showpost....6&postcount=29
Also, call me a weirdo, but I have used toothpaste to clean cases before, with a fine steel wool. It needs to be rinsed well after but it's very slightly abrasive and I think it did a reasonable job on my '74 KS125! Also has the advantage of being cheap.
Carlossal screwed with this post 04-14-2010 at 05:06 PM
Old 04-14-2010, 06:34 PM   #833
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,445
There's a good chance the issue has to do with the check valve in the oil pump. Maybe the 250 does not have the check valve.
Honda has published some instructions for priming the oil pump which requires removing the clutch and oil pump. This is a lot of work for an already assembled engine. I'd suggest cracking open one of the oil bolts on the external line to the head to make sure you are getting oil flow.
Old 04-14-2010, 10:08 PM   #834
petros600
Oddometer: 36
Turn signal choices
I need to replace both sets of my turn signals(88 NX650)? Any alternatives to the OEM's?
petros600 is offline   Reply With Quote
Old 04-14-2010, 10:44 PM   #835
HeadTrauma
¯\_(ツ)_/¯
HeadTrauma's Avatar
Oddometer: 1,246
Aren't the RFVC 250s a wet sump design?
Old 04-15-2010, 08:51 AM   #836
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 594
I think the XL250s and XL350s were all wet sumps.
I also think the early XR250s and XR350s RFVC were wet sumps.
The 85 XR350 was dry sump and I tend to agree that Honda made a royal mistake by only offering this bike for one year.
I don't know when the XR250s became dry sumps. Was it also in 85?
Ghost_Mutant is offline   Reply With Quote
Old 04-15-2010, 09:33 AM   #837
HeadTrauma
¯\_(ツ)_/¯
HeadTrauma's Avatar
Oddometer: 1,246
I think if the XR250 went dry sump, it wasn't before the 1996 revamp. I had a '94 XR250L for a while and it had a dipstick on the engine.
Old 04-16-2010, 07:25 AM   #838
nxdirtbag
Commuter Adventurer
nxdirtbag's Avatar
Oddometer: 185
I skipped from an 84 XL350 to some other bikes and then the 96 XR400. Did Honda change the XR250 in 1996 with the intro of the XR400?
NXDirtBag
Buell 06 Uly, Hon 96 XR400, 73 CL450,
05 CRF230 - wife, XR100, XR70 & PW60 for kids
My friend Pilo's adventure book
nxdirtbag is offline   Reply With Quote
Old 04-16-2010, 04:38 PM   #839
Mark5PA
Mark5PA's Avatar
Oddometer: 1,694
Mark, if you have a set of calipers, plug the specs on each spring into this site and tell me what you get:
http://www.racingsuspensionproducts....ing%20rate.htm
There's a definition of Active Coils here if you aren't familiar with it. Search for "Active" on the page.
So much for the 'poke & hope' method. Should have known the 1/2" shorter shock would make a difference, didn't think this much. Got NX#2 off the lift today. With bike sag, seat height 30.5, compared to 35.5 on stock NX#1. Unladen seat height only 32". So on to plan B, e bay shopping for a longer shock.
Here are the numbers I got plugging springs into the rate formula site.
SPRING WINDS COIL OD WIRE OD RATE
NX650 5.67 3.21" .519" 943.96#/in
XR200R 7.33 3.15" .479" 541.78#/in
XR600R 6.33 3.38" .524" 738.44#/in
After messing around with that formula site a while, the 'active coil' article made a bunch more sense. Thanks Paul.
I'll post up some more info when I get more parts.
M
Mark
F800GS
Endless Mountains,PA
Mark5PA is offline   Reply With Quote
Old 04-17-2010, 10:40 PM   #840
blauth
Oddometer: 7
1991 Dominator - South Africa
Thought this post needed some new blood so here are some pics of my bike.
We never brought these into South Africa so this was what we call a grey import.
Pro-taper bars, hand guards, Custom screen(I built the screen from perspex)
blauth is offline   Reply With Quote
Times are GMT -7.   It's 04:38 PM.
