Old 08-02-2007, 06:27 PM   #1
Faribo OP
Oddometer: 134
KLR max weight load
I was wondering if you can carry more weight on a KLR 650 if you change the supension and the sub frame bolts? I am a bigger guy (6'5" 310 lbs) and the max weight(401 lbs) of the bike limits me from taking passangers. Let me know if you have any sugestions. Thanks
Faribo is offline   Reply With Quote
Old 08-02-2007, 07:08 PM   #2
Hurricane Bob
formerly: Bomber1965
Hurricane Bob's Avatar
Oddometer: 2,935
Sure, most every mfg of every product adds in a safety margin so going a
little over would be feasible, beefing items like you mentioned would widen the safety curtain some as well.
Now with that said, I'd never go that far overloaded on a KLR. Because then your getting into whether or not the brakes can handle that load (any klr owner already knows that answer).
Then there's wallowing at road speed in turns that the klr's not good at dealing with when overloaded.
So can you?....Sure, should you?....To each his own!
Hurricane Bob is offline   Reply With Quote
Old 08-02-2007, 07:10 PM   #3
swjohnsey
Oddometer: 3,568
Lose about 100 pounds.
swjohnsey is offline   Reply With Quote
Old 08-02-2007, 07:30 PM   #4
rider33
rider33's Avatar
Oddometer: 1,056
at 6' 5" I can't imagine you have enough room to take a passenger for very long. For short hops, I wouldn't worry about it. If you were thinking of a run up to Thunder Bay, however, I think you might have a problem. The load ratings are conservative then again, the more you push it, the more likely you are to stress something. I doubt tire or even suspension mods would fundamentally change that really.
“many a trip continues long after movement in time and space have ceased”- Steinbeck
rider33 is offline   Reply With Quote
Old 08-02-2007, 07:33 PM   #5
firerigger
Trauma waiting to happen
firerigger's Avatar
Oddometer: 810
Just do it the way they test bridges (except the one in Minnesota): load it until it breaks, then fix it and weigh the last load. There's your carrying capacity...
"The eyes are the groin of the head.."
"I never fail...sometimes I succeed in finding out what doesn't work."
Current rides:
'04 KTM 450 EXC
'07 Triumph Tiger 1050
'07 Triumph Daytona 675
Gone but not forgotten:
'00 KTM LC4-E Sixdays
'06 KLR 650
'06 DL-1000
Save yourself (and me!) money at SmugMug: Coupon code YE2eMDKcBDhGY
firerigger is offline   Reply With Quote
Old 08-02-2007, 07:55 PM   #6
Beezer
Oddometer: 5,791
Yes, change the subframe bolts - several kits out there. If you are going to do rough stuff consider the drilled through version. http://www.angelfire.com/ut/moab/parts_frames.html
Eldon's 6.6kg spring for the rear... or maybe stronger.
http://multisurfacemotorcycling.com/...ts/klrprod.htm
There are other spring/shock builders out there.
Forget the passenger & ride it.
Have fun!!
Beezer is offline   Reply With Quote
Old 08-02-2007, 08:11 PM   #7
R_W
wannabe
R_W's Avatar
Oddometer: 4,126
I have carried WELL over the max payload. I have upgraded subframe bolts, upgraded rear spring, longer spacers in the forks, oversized front rotor, SS braided brakelines.
Backroads, not too bad. It is a handful on the highway. Live weight is usually easier to carry than luggage but still not something I would want to do for more than an hour and not at all with traffic.
If I were setting out to plan on that kind of load I would:
Do the heavy duty drill-through subframe upgrade
Upgrade the rear spring and/or shock--if you just increase the spring rate the shock will be under damped if you aren't careful.
Progressive front springs. You will need something to deal with brake dive when you:
Oversize front brake and SS lines. You need a LOT more stopping power
Re-gear it. A 14 tooth countershaft sprocket will give you a lot better power and gears for low speed and only hurt above 60 or 70.
sounds like a lot of stuff, but they are all pretty simple and basic mods. Keep in mind that the KLR's rated load capacity is more than most bikes out there (more than a Honda ST1300!).
whatever you do, have fun!
Red hair and black leather, my favorite color scheme...
R_W is offline   Reply With Quote
Old 08-03-2007, 04:12 AM   #8
fixer
KLR-riding cheap bastard
fixer's Avatar
Oddometer: 7,439
+1
you'll probably want new fork oil when you upgrade the springs... probably 12.5 or 15wt and play with the oil height and preload. there's also a damping rod mod, or the Race Tech Gold Valve cartridge emulators that should provide additional improvements and with the valves, adjustability for the front end.
Sit tall in the saddle, Hold your head up high
Keep your eyes fixed where the trail meets the sky
And live like you ain't afraid to die
And don't be scared, just enjoy your ride.
"... in my version of Heaven you get all your dogs back." – Mista Vern
"Old dogs don't die, they just wait for you in another place." – Twilight Error
I'll show you a place, high on a desert plain, where the streets have no name.
fixer is offline   Reply With Quote
Old 08-05-2007, 01:55 PM   #9
R_W
wannabe
R_W's Avatar
Oddometer: 4,126
I don't remember that one. Can you explain or post a linky?
Old 08-05-2007, 05:43 PM   #10
swjohnsey
Oddometer: 3,568
The Elden Carl mod? It invoves drillin' one of the damping hole out to 1/8".
Old 02-01-2013, 02:03 PM   #11
globalklr650
globalklr650's Avatar
Oddometer: 161
27,000km on a 1,100lb KLR650 with stock shocks
I have ridden my KLR from Montreal to Alaska and then to La Paz Mexico with two people and alot of gear over the last year. *I have only put the rear shock to the stiffest setting but everything is stock. *I do have a tank bag and side bags on the front that are homemade to keep weight on the front. *
We have riden alot of off road like this and have never really bottomed out (i ride slow off road)
You should be fine just get used to the weight. *It will be a little shaky at low speed. *Make use you tire pressures are high (i use between 30 to 40 psi). *Give youself lots of room to brake (i got ebc HH brake pads for the front which really help).
The KLR is an amazing work horse and does well over loaded. *Oh and the back subframe bolts should be replaced too.
I have alot of movies of our trip on youtube under 2012theperfectworld.
http://www.youtube.com/watch?v=ddTOD...e_gdata_player
Also we have a Ride report on ADV under
KLR650 around the world with passenger
On our facebook page are about 4,000 pictures of the trip
www.Facebook.com/theperfectworld2012
There are 3,000 pictures (from north america more to come) and a diary of our trip on our facebook page at the link below.
http://www.facebook.com/theperfectworld2012
globalklr650 is offline   Reply With Quote
Times are GMT -7.   It's 05:33 PM.
