Old 08-06-2007, 04:15 PM   #1
intr1gue OP
intr1gue's Avatar
Oddometer: 211
tire balancing?
OK, so I'm signed up for the PNWGS Rally in Menlo WA (disclaimer, I'm a board member, but you should go too) this coming weekend, and I'm taking a advanced off-road clinic from acclaimed instructor Jimmy Lewis (more shameless pluggage).
So I changed my tires, and being tapped out after buying my beeyootiful R1200GS, I changed out my Deathwings for a pair of TKC 80's...all by myself! [except for when I had to take the front to a tire place across the street for some hi-pressure air...but that was free, therefore it didn't happen...those are the BMW rules).
'cept I didn't balance them. I don't have a balancer, and after all the wrasslin' with the beads and the tire irons and the lube and the yadda yadda, I just plain wasn't interested in any more work. it was 2am and i was urgently needed elsewhere.
But now, in the light of day and several hundred miles later, I'm thinking balancing might be a good idea.
What should I look for to see if I'm in need of balancing? I ride on the road to work 3 days a week (90mi days), as well as offroad on the weekends. on road I keep it under 80, off road around 20-40 tops.
How do i keep rolling happily along?
Ranjan
One little Indian
Seattle, WA
intr1gue is offline   Reply With Quote
Old 08-06-2007, 04:59 PM   #2
MsftMan
MsftMan's Avatar
Oddometer: 57
Take a gander at this link... it might just be of help: http://www.xs11.com/faq/tirefaq.shtml
Hope this helps,
Banks
MsftMan is offline   Reply With Quote
Old 08-06-2007, 05:01 PM   #3
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
For years and years motorcycle tires weren’t balanced. If you are not feeling any unusual vibrations I would not worry about it.
I've got to be cool
Relax
Take a long long ride on my motor bike
Untill I'm ready
Mudcat is offline   Reply With Quote
Old 08-06-2007, 05:03 PM   #4
tooofast
tooofast's Avatar
Oddometer: 232
Nice artical.. i like it and on that note has anyone used one of these to ballance wheels?
http://www.harborfreight.com/cpi/cta...emnumber=39741
'03 GS Adventure
tooofast screwed with this post 08-06-2007 at 05:08 PM
tooofast is offline   Reply With Quote
Old 08-07-2007, 04:27 AM   #5
bykemike
"ready to navigate"
Oddometer: 357
I stopped at Woodys to have my tires changed out on a cross country trip last year and they found that my rear rim was bent..and had been for over 20,000 miles..I remember what did it. I was going to have it changed or fixed but we were both out of time so I stuck on a new tire and hit the road. It is now 18,000 miles later and the rear is still bent and the bike feels great and the tire doesn't seem to wear too fast so maybe balancing is not the biggest issue if the bike seems good.
Mike
"ready to navigate"
about as funny as a guy with a squirt can of FD fluid at a BMW rally
bykemike is offline   Reply With Quote
Old 08-07-2007, 05:30 AM   #6
Ron Ray
Senior Adventurer
Ron Ray's Avatar
Oddometer: 131
Thumb Tire changing and balancing
I decided about a year ago to start changing my own tires. the savings are obvious at $75-100 per tire ( if you order your tires off the internet). Anyway, I proceeded to educate myself by reading all the forum writeups. I ended up purchasing the Harbor frieght setup with moto adapter ( $100). I found i didn't like the change bar that came with it ( didn't want to scratch my rims) so Marc Parnes recommended the "Mojo Lever" ($80). I also order the Marc Parnes Balancer ( around $ 200 once I bought the adapters I need for my new "07 GSA). I also bought some "Ruglide" lubricant from NAPA parts ($20 gal) and a couple "tire spoons" ( $13) from MotoPro. And finally some wheel weights and stems ( $20). So I end up with a $450 investment.
Over this past year I have had to replace 2 tires due to nails and one because of wear ( 3 tires= $300 savings). I have changed 4 tires out for my buddies and they each threw $20 in the "Tire Fund Kitty" ( $80). In another 6 months my entire investment will be reclaimed! It's really easy to change and balance your tires! Try it. You'll save loads of money! Ron Ray
By the way, at low speeds you won't notice it very much if your tire isn't balanced correctly but if you get up to high speeds it can bounce and wabble just like a car does. If you feel excessive vibration....slow down. If it persists. Have the tires balanced.
Ron Ray
Lexington,
South Carolina
USA
2007 GS Adventure
Ron Ray is offline   Reply With Quote
Old 08-07-2007, 07:01 AM   #7
kenaiboy
kenaiboy
Oddometer: 9
Cool2 Ceramic balance beads
Look at the ceramic tire beads they offer online. The theory behind them seems logical. I also like the mention that they do not require the old lead weights on the outside.
kenaiboy is offline   Reply With Quote
Old 08-07-2007, 07:54 AM   #8
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,039
I don't want to put anything inside my tire that isn't air. YMMV.
Old 08-07-2007, 07:58 AM   #9
rideLD
The further the better!
rideLD's Avatar
Oddometer: 5,401
The beads have been debunked my many reputable sources which does not include Motorcycle Consumer News (who also debunked them).\
I use the Marc Parnes setup for balancing my tires on my GS.
http://www.marcparnes.com/BMW_Motorc...l_Balancer.htm
Karl | 2014 BMW R1200GSW Adventure | 2009 BMW G450x
Originally Posted by SchizzMan View Post
We pay Motorrad to design weight off the bike then pay TouraTech to bolt it right back on.
rideLD is offline   Reply With Quote
Old 08-07-2007, 11:15 AM   #10
impi
impi's Avatar
Oddometer: 1,247
Ranjan
If you lined up the heavy spots on the tire when mounting you should be ok. I've had new bikes from BMW come without any weights on the wheels (and no - they were'nt perfectly balanced). If it really bothers you take them off and take them to the MC accesory store off 38th Street (Cycle-something) across from Borders and Costco and ask them to balance them for you - they're cheaper than the dealer.
Impi
_____________________
2007 R1200GSA
impi is offline   Reply With Quote
Old 08-07-2007, 02:30 PM   #11
Jim Moore
Jim Moore's Avatar
Oddometer: 13,681
I've changed probably 50 tires. Never balanced one. Just ride brother, ride like the wind.
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is offline   Reply With Quote
Old 08-07-2007, 06:46 PM   #12
SQD8R
Eat squids and be merry
SQD8R's Avatar
Oddometer: 7,382
Thx for the info guys/gals. I was wondering about the same thing recently.
2006 BMW HP2E, 2011 Husqvarna TE630, 2015 Triumph Rocket III Roadster
Married men don't live longer, it just seems longer.
SQD8R is offline   Reply With Quote
Old 08-07-2007, 07:34 PM   #13
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,062
One more option to consider would be to add about 1 oz. of weight opposite the valve stem and call it close enough. That seems to be about what mine take when I balance them. I might have heavier than normal valve stems because I use metal 45 degree ones to make it easier to check the pressure. With regular rubber stems perhaps 1/2 oz. would be about right.
The Anakee tires I have been getting have not had any marking indicating the light spot, so I just put them on at random.
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 08-08-2007, 05:02 AM   #14
Ron Ray
Senior Adventurer
Ron Ray's Avatar
Oddometer: 131
Question Tire balancing
Jim, just curious. I know that correct tire balancing improves tire wear. What kind of mileage do you usually get? I've gotten 18-20,000 miles on a front tire and 13-15,000 miles on a rear? That's what I used to get when I ran ME 880s on my LT. Ron Ray
Ron Ray
Lexington,
South Carolina
USA
2007 GS Adventure
Old 08-08-2007, 08:12 AM   #15
JR356
JR356's Avatar
Oddometer: 3,818
Hi,
Consider this;
http://www.ride-on.com/prod_mot.asp
It's a non gooey flat sealant system and dynamic tire balancer.
JR356
JR356 is offline   Reply With Quote
Times are GMT -7.   It's 12:44 PM.
