Old 08-07-2007, 03:02 PM   #1
Lost Rider OP
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,233
Wicked A Pelican Tank Box ------------ I'm Wired
I've been wanting a Pelican tank box to add to my bike, and I finally put together all the components.
I had some special requirements for the box, and here's what I came up with.
Since I already had a SW-Motech tank bag, with a tank-ring and quick release mount, I had that covered. I finally decided on a Pelican 1200, not too big, not too small. Lockable, removable, waterproof and indestructible.
I took the mount off of the SW-Motech bag, lined it up, drilled 4 holes and was good to go. That's the easy part.
Notice the wires coming out? Well that's where things started to get a little more complex. I wanted the box to have a multi-pin, waterproof connector wired into it so I could remove it very easily, either to bring it with me or to just lose it all together. I managed to find a suitable 9 pin connector at one of the audio companies I work with.
One twist and it's gone.
I wired in 2 power cables for my GPS, and for the dual accessory outlet, each individually fused and grounded. Then I wired in a stereo audio cable to get sound out of my iPhone, iPod, or XM from the Garmin. That leaves me 2 empty pins for future use.
I also shortened the iPhone/iPod charger's cable to keep it neat.
Since I had most of this stuff hard wired into my soft bag, I could move it out of the way to fuel, but could not remove it all together. Not any more!
Now, on to my last hurdle. Since I used a GPS mount that connected to the tank bag, I had to figure out how to mount the Streetpilot and XM antenna to the box. It had to be self contained with no wires coming out of it to a handlebar mount, etc...
I ended up modifying a SW-Motech/Garmin handlebar mount, drilling a hole through one of the halves of the bar mount. 1 screw and nut for the GPS ( It's very solid), and 2 small factory screws to hold the antenna. It takes less that 5 minutes to install or remove the GPS system to the box. Thats good enough for me, since I only use the GPS for out of town trips anyway for the most part.
Flood Warning! Good thing I don't have to worry about rain covers any longer :)
I'm hoping to shorten up the USB cable, but I'm going to talk to Garmin before I get to cutting.
A little e-tape on the inside keeps the rain out when the GPS is off
Here's where the Audio comes out.
Pelican Cases Rock!
Lost Rider is offline   Reply With Quote
Old 08-07-2007, 03:10 PM   #2
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,334
ChiTown Very nice job and also exelent report, very clear and easy to understand, easy to see were some of your professional skills reside.
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 08-07-2007, 03:36 PM   #3
zed88
n00bilicious
zed88's Avatar
Oddometer: 1,297
Thats excellent! I had never thought about a pelican as a tankbag, but now I think I'm going to make one almost exactly how you made yours. Thanks!
zed88 is offline   Reply With Quote
Old 08-07-2007, 04:24 PM   #4
spicychili
spicychili's Avatar
Oddometer: 366
Very nice. I just added a pelican case as a top box to my thumper.
I like pelican boxes. Interesting for a tank bag. Might have to look into that.
'06 R1200GS
'07 G650 X-Challenge
spicychili is offline   Reply With Quote
Old 08-08-2007, 05:45 AM   #5
R_W
wannabe
R_W's Avatar
Oddometer: 4,126
very nice. Sanitary and would be easy to adapt to multiple bikes--just a new pigtail and tank bag ring on every bike in your fleet.
You could get rubber washers and put the bolts back in the lid if the e-tape isn't waterproof enough.
Red hair and black leather, my favorite color scheme...
R_W is offline   Reply With Quote
Old 08-08-2007, 06:20 AM   #6
jdbski
old but getting younger
Oddometer: 447
source for the connectors
I have two questions;
1 can you just buy the connectors, one for the tank and one to attach to a pelican case?
2 what about handlebar clearance when turning the handlebars? does the case get in the way?
thanks jb
jdbski is offline   Reply With Quote
Old 08-08-2007, 07:27 AM   #7
PaulS
Österreicher
PaulS's Avatar
Oddometer: 963
Nice setup, I was looking for something like that. What size/model of pelican box is that ?
PaulS is offline   Reply With Quote
Old 08-08-2007, 07:31 AM   #8
spicychili
spicychili's Avatar
Oddometer: 366
Pelican 1400. Its pretty good size inside. I am pretty happy with it.
Doug
'06 R1200GS
Old 08-08-2007, 07:46 AM   #9
R_W
wannabe
R_W's Avatar
Oddometer: 4,126
If you added the slick internal locks like Roger puts on the caribou luggage that would be very slick, matched so one key for all your bags.
Old 08-08-2007, 09:30 AM   #10
MikeO
Wage slave...
MikeO's Avatar
Oddometer: 6,968
I wouldn't ever ride that bike without the bag fitted...
...those will have your knackers off in a prang...
Mike
All text & original photos © Mike Oughton 2004 - 2015
MikeO is offline   Reply With Quote
Old 08-08-2007, 09:59 AM   #11
RoyB
Dartmouth, Massacusetts
Oddometer: 1,578
VERY NICE!!!!
All I would add is an Amplirider headphone amplifier and a radar detector. Pick up a couple more of the female 9-pin connectorts and a few more tank mounts and this thing could be a perfect multi bike setup..........very easy "bike to bike" and could even be used in a sports car..........Great job!
Roy B
Dartmouth, MA www.rvbprecision.com
2007 BMW K1200R Sport abs,2007 DL650 V Strom abs
2004 Honda VFR abs,2001 Moto Guzzi Rosso Mandello
1971 Honda Trail CT90
RoyB is offline   Reply With Quote
Old 08-08-2007, 04:00 PM   #12
Lost Rider OP
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,233
thanks jb
As far as I know SW-Motech doesn't sell the mount separately, only the tank ring is available separately, since it's bike specific.
No problem with the handlebar clearance, about 1.5 inches to clear on both sides.
I will find out the brand of connector asap and post it here. You can also google "multi pin connector"
I rode in a heavy downpour today and the e-tape kept the water out. :)
Old 03-10-2013, 02:05 PM   #13
N-m
Captain 2 Sexy
Oddometer: 447
Mike
That must be some slang from up north.
Note - I am resurrecting this thread since I already have Pelican's and would like a tank/bar mount. I wonder how this set up is working today?
I cannot find a source for the tank ring and bag part that is not energized. Anyone got a source that is not a dead UK or Oz link? 1995 R1100 GS.
thanks.
N-m screwed with this post 03-10-2013 at 02:13 PM
N-m is offline   Reply With Quote
Old 03-10-2013, 08:02 PM   #14
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,428
thanks.
I don't know if it will fit your bike, but I used a Cortech ring mount for my tank case.
http://www.revzilla.com/motorcycle/c...ryver-tank-bag
'09 Suzuki SV650, '02 KLR250, CRF70 and 80 for the kids IBA # 56419
Newfoundland 2012
James Bay 2014
max384 is offline   Reply With Quote
Old 03-11-2013, 11:00 AM   #15
Lost Rider OP
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,233
Old thread! Glad to see it coming back.
Here's the v2.0 thread with more info, maybe that can be of help.
HPRC Electronics Tank Box Version 2.0 - Think Inside the Box
Photography for me is not about recreating what I saw through
the viewfinder but to show people the way I want to see the world.
LostRider.com
Times are GMT -7.   It's 08:05 AM.
