Old 08-10-2007, 01:40 AM   #1
wayne640 OP
the twin can man
wayne640's Avatar
Oddometer: 331
Ktm 640 front wheel bearings
Any body have any tips on removing the front wheel bearing from a ktm 640 04 model, now ive never had problems before but stuffed if i can work out how to remove these ones.
As the internal size of the bearing is the same size as the spacer shaft inside the hub, leaving no area to get a punch or such to knock them out.
Any help would be appreciated, and yes i checked the thread index to no avail.
cheers
KTM 640 Adventure
KTM 300 Exc
wayne640 screwed with this post 08-10-2007 at 02:29 AM
wayne640 is offline   Reply With Quote
Old 08-10-2007, 02:27 AM   #2
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 765
Good question.
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is offline   Reply With Quote
Old 08-10-2007, 08:03 AM   #3
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,224
Paging Loadedagain. Loaded to the White Courtesy Phone...
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 08-10-2007, 08:47 AM   #4
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,732
wish i could help mate, but i've never done a set of the newer ones.
if the bearing is the same size as the spacer (which is doubtful as then there would be too little clearance to insert the axle easily, and the spacer would turn in the hub) use a very sharp punch from opposing side and do your best to get it to hook on the bearing edge.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 08-10-2007, 09:53 AM   #5
sherpa
...Robert
sherpa's Avatar
Oddometer: 3,187
While I've never done my 640 bearings I've seen the same thing you describe on other bikes.
The spacer floats in there and needs to be moved to the side inorder to get a purchase on the bearing race. Take a long rod and insert it in the wheel to the opposite end of the spacer and pry it over. This can require quite a bit of force especially on my Husky's rear wheel which calls for 142nm of torque when tightening the axle. This tends to really bind the spacer even when the wheel has been removed.
Hope that helps...let us know if the 640 is as I describe...
Trebor Home Inspections
05 640 Adventure
08 KTM 250 XCFW
I'd trade all my motorcycles for one Flying Dragon.
sherpa is offline   Reply With Quote
Old 08-10-2007, 09:57 AM   #6
meat popsicle
Ignostic
Oddometer: 14,224
damn. is there a special tool listed in the service manual? maybe a pic of that tool would help you understand how to do it?
Old 08-10-2007, 01:51 PM   #7
crazybrit
crazybrit's Avatar
Oddometer: 8,554
Buy a pitposse bearing remover. I long ago gave up on using punches and drifts or worse, screwdrivers. Why risk damage to your hub?
The PitPosse is the best $40 I've spent. I've used it on like 5 bikes now and friends use it all the time also.
Also, don't beat on your sockets to reinstall, cut the old outer race off using a dremel or hacksaw, use this to reinstall and you can use channel-locks to pop the race driver out should it get stuck in the bore (the cut you put into it allows this).
crazybrit is offline   Reply With Quote
Old 08-10-2007, 01:52 PM   #8
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,914
The bearing is mounted and fixed using a shrink fit.
I'd contact a KTM guru/factory mechanic/or otherwise wise old sot to discover how hot the hub must be heated to in order to expand enough to allow the bearings to either be tapped out or drop out all by themselves.
I wouldn't use a blow torch here, but would more likely use a heat gun along with some sort of temperature gun.
Years back I mounted loads of bearings this way on Vespa engines.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 08-10-2007, 02:12 PM   #9
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,595
I concur on the PitPosse kit. I bought one myself, works great on my Jap bikes. However, there is not a big enough driver for my KTM 300XC. Are the bearings smaller on the 640? Jusy my 2 cents worht.
2010 KTM 530 XC-W / 2009 KTM 950SE / 2005.5 KTM 950 ADV (aka the dirt Harley)
“Anyone who believes in indefinite growth in anything physical, on a physically finite planet, is either mad or an economist.” -- Kenneth E. Boulding
bigborefan is offline   Reply With Quote
Old 08-10-2007, 02:20 PM   #10
crazybrit
crazybrit's Avatar
Oddometer: 8,554
Good point. I've not done my 950 yet and IIRC it's 30mm. The 640 got the 950 fe in 2005 IIRC. Not sure what a 2004 is. What are the other front axle sizes, 26mm (recent) and 20mm (older).
There is a 20mm and a 25mm in the PitPosse kit, I've no clue if the 25mm fits, probably not.
Ugh.
Old 08-10-2007, 04:50 PM   #11
wayne640 OP
the twin can man
wayne640's Avatar
Oddometer: 331
Thanks for all the info, heres how its done.
Loaded was correct in his statement..........There is a spacer colar inside the hub and the bearings sit hard up against it either end.
This inside collar at first appear to have no movement, but after a few light taps with a punch. It moves just enough to expose a small amount of lip on the inner bearing race.
The only way i could get the first one out, was to put a long punch through the hub and work my way around the bearing moving the spacer collar each time to expose the bearing lip.
Once the first one is out the spacer tube slides out of the hub and the other side is easy, just a socket on a extension bar and few taps it was out.
After i finally removed the first bearing and the collar tube,the amount of movement it has inside the hub would only be in the thous.The slightest amount of dirt /grease is enough to lock it in, as it was in my case.
But a word of WARNING that tube is made off very soft alloy and marks very easily, wouldnt take much at all to damage the end of it. Trying to knock it out the way so you can get to the bearings.Then that would cause the axle spacer not to sit in the hub properly when you put the wheel back on the bike.
cheers wayne
KTM 640 Adventure
KTM 300 Exc
Old 05-18-2014, 06:46 PM   #12
Queen of Spades
tall drink of water
Queen of Spades's Avatar
Oddometer: 854
Here's the PitPosse bearing removal tool in case others are looking for it. As of May 2014 it is selling for $59.
http://pitposse.com/whbereset.html#
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=fifXkDQpda4 (January 2014 snow ride)
Queen of Spades is offline   Reply With Quote
Old 05-18-2014, 07:08 PM   #13
Beezer
Oddometer: 5,743
I weld an old bolt or a big washer or whatever I have across the race... now ya got something to hit & it'll drive right out.... especially if you go after it right away before things cool off. some bearings will even fall right out after the weld cools a bit because it shrinks
Beezer is offline   Reply With Quote
Old 05-18-2014, 09:24 PM   #14
zach613
Oddometer: 5
If they are like every other dirt bike out their and are a press fit, take a map gas torch and heat the hub a little and then flip the rim over and tap that side against somthing solid. it should drop out or close to it.
zach613 is offline   Reply With Quote
Old 05-19-2014, 12:02 AM   #15
bmwktmbill
Traveler
Oddometer: 5,102
That works and you can sharpen a long round steel rod and work through the wheel axle hole on the bearing on the opposite side after heating with propane or a heat gun.
Why are you changing them, if they are not bad just do the seals and pop off the side shields on the bearing with a knife point, wipe in some fresh grease with your finger and reinstall the side shield, replace the seal.
I have left the seal in place, reached around it to pop the shield, wiped in fresh grease, replaced side shield, go.
Clean any gunk off the axle and clean the axle clamp areas well.
Reinstall the wheel according to the owner's manual sequence.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Times are GMT -7.   It's 02:11 AM.
