Old 08-13-2007, 09:15 AM   #31
Steverino
Arrogant Horse's Ass #1
Oddometer: 36,668
Originally Posted by ganshert
I ignored the little voice telling me to "step away from the motorcycle"
WOW, what a machine.
I was able to resist...not sure how much longer I can hold out though.
Steverino is offline   Reply With Quote
Old 08-13-2007, 10:16 AM   #32
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,597
Question
Hey Ned,
Don't know if you've ridden an HP-2, but I'm curious to hear what your thoughts are on the comparison between the two bikes?
Dan
Old 08-13-2007, 10:58 AM   #33
Misery Goat
Positating the negative
Misery Goat's Avatar
Oddometer: 75,205
Originally Posted by Gordy
MG,
Does it do it with the Gobis off? I heard that they were the culprit on the high speed stuff and I have been running without them and have no problems now at full tilt.
I am also running a Scotts that may be masking some of it.
when kev and i were coming back from WF (w/jesses) i was getting it bad around 100 indicated, even in the corners..
i still get the shakes when i'm not running bags they just kick in at higher speeds, say ~110mph..
having a scotts on my 525 i'm starting to see the advantage of having a damper. i'll proly go this route eventually.
"So what you gonna do when the novelty is gone.."-- Joy Division
Same as it ever was
My Wanderlust
Misery Goat is offline   Reply With Quote
Old 08-13-2007, 11:00 AM   #34
Steverino
Oddometer: 36,668
I am calling the police, you were speeding and admitted it. :Shameonyou
Old 08-13-2007, 11:07 AM   #35
Misery Goat
Oddometer: 75,205
i will say Antware posited a theory while in WF. iirc, he contends the shakes are caused by the wind buffeting on the body which transfers the energy into the arms and onto the handlebars. he suggested taking my hands off the bars when this happens.
i agree with him in part, i took my hands off the bars and the shake seemed to subside..though i'm not certain it's the wind causing the shake as i observed the area around my arms/body to be quite calm with only incidental buffeting..the only buffeting i observe is directly on my helmet..
Same as it ever was
My Wanderlust
Old 08-13-2007, 11:09 AM   #36
InfoManiac
Always Learning
InfoManiac's Avatar
Oddometer: 5,889
What is the difference in fuel range between the Adventure and the SuperEnduro?
"Goin' to "The Farm" - wherever it may be - makes JM what it is. It ain't the basement - more like a foundation...... and it's better with rough edges." ---DireWolf
"Knowledge is an unending adventure at the edge of uncertainty" ----- Jacob Bronowski
"I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man." -----Thomas Jefferson
Smugmug coupon ----- 5w5TPcXpTtBdw --- Save $5.00!!
InfoManiac is offline   Reply With Quote
Old 08-13-2007, 11:24 AM   #37
Steverino
Oddometer: 36,668
SE has a 3.7 gallon tank, not sure what the Adventure has.
Old 08-13-2007, 11:32 AM   #38
Meathead
tin man
Meathead's Avatar
Oddometer: 16,659
5.842. DAMHIK.
5.900 would've been enough.
Meathead is offline   Reply With Quote
Old 08-13-2007, 11:34 AM   #39
Steverino
Oddometer: 36,668
Originally Posted by Meathead
5.842. DAMHIK.
did ya have to push it very far?
Old 08-13-2007, 04:45 PM   #40
Jeepboy
Roost
Jeepboy's Avatar
Oddometer: 560
The difference is significant. I typically can go around 160 miles on my ADV before the fuel light comes on. On my SE the fuel light comes on around 90 miles. If you drop the SE after removing the emission crap, you can get far less mileage since having two bowls empty will dump a lot of fuel. One ride I went on was very slimy and I fell over often. The fuel light came on at 40 miles. Always remember to hit the kill switch when you drop the bike to turn off the fuel pump.
"They've done studies, you know. 60% of the time, it works every time." Brian Fantana
My toys:
04 YZ250F
04 950 Adventure S--lost to fire
06 KLX 110
07 950 Super Enduro
http://www.katoom.smugmug.com/
$5 Smugmug coupon: FDURkYt1pFdQw
http://www.youtube.com/Katoom950
Jeepboy is offline   Reply With Quote
Old 08-13-2007, 05:10 PM   #41
Hair
Outside the boxer
Oddometer: 14,151
My fuel reserve light is not working. If I run the bike on the road I am getting between 42 and 44 mpg. Off road with a lot of revs 36 mpg.
My problem is that the bike is running out of fuel at 2.4 gal. There is fuel left in the tank because I can slosh it around and get going again.
I have never run out of fuel on a bike before. But I have with this one twice.
I need to get my tank fixed so I can access the last gal. Then I will start carring a spare gal or two.
It's a pain in the ass. But it's worth it. I would not want more fuel in the front. So I need to settle for hauling it in the rear.
Hair is offline   Reply With Quote
Old 08-13-2007, 05:39 PM   #42
neduro OP
Addict
neduro's Avatar
Oddometer: 12,021
Mine did that- turn on the other fuel tap (there's one on both sides). DAMHIK.
One of my early projects is going to be adding a second tank. I've got a plan figured out... remains to see if it works, mind you, but I'm optimistic. If all goes well, I should have 1.5 extra gallons in a good location, and probably an overall decrease in weight.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 08-13-2007, 06:21 PM   #43
Hair
Outside the boxer
Oddometer: 14,151
I checked them. I think that both of my taps are turned on. I will check them again.
Old 08-13-2007, 06:26 PM   #44
Hair
Outside the boxer
Oddometer: 14,151
Originally Posted by Yellow Pig
Hey Ned,
Dan
I have not ridden an HP-2 but I did have a 1200 GS. I liked my GS. It never was excitting. But at the same time the bike did a lot of things well.
In the end I could not get past the dry clutch, limited forward seating and high gear ratio.
The bike was a dream once I got it rolling. Over time I had gotten to use to working the clutch on my dirt bike. I was slippng the clutch on my GS all the time.
Now both of my bikes function similarly. That has been a big help for me.
If I could I would have both an GS and an SE.
Old 08-13-2007, 06:40 PM   #45
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,403
Oh man, really is that all...
She maybe fun and everything but half the long trips we do, death valley for example already require about a 150miles in between re-fills..
Sound like the rear tanks are the way to go to achive at least 1.5g if not 2 more gallons.
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Times are GMT -7.   It's 04:27 AM.
