08-13-2007, 07:06 PM
#1 |
nikodelrey
Oddometer: 130
where to purchase KLR parts
Just wondering where would one buy a KLR oversized front rotor and steel brake lines from? I looked at arrowhead. Are they reliable? Any place that is better/cheaper? Also I'll be purchasing a doohickey replacement too.
08-13-2007, 07:30 PM
#2 | |
Oddometer: 8,040
08-13-2007, 11:11 PM
#3 |
Lust for dust...
Oddometer: 6,026
I've had good luck with TPI http://www.tpimotorcycleparts.com/ as well as Arrowhead.
Oversized rotor kit- $185. I think that's competitive. I don't think TPI's selection is huge, but service is good and they only charge you actual shipping.
... grease, grit, and mud are runnin' in my blood. |
08-14-2007, 09:53 AM
#4 |
Rooster Bastid
Oddometer: 469
Fred at Arrowhead is definitely the best and most honest. You can get stuff from DualStar and Happy Trails but no guarantees on them having what you want.
May a piece be upon you. |
08-14-2007, 10:25 AM
#5 |
I'm mentally mortarded.
Oddometer: 120
I bought mine direct from Braking at LagunaSeca a few years back. The only issue I had was how easy it was to strip the threads in the aluminum adapter bracket. I had to buy another one...so cheap that I bought two just in case. The brake has been a lifesaver as well as a confidence builder. I nearly killed myself on my first KLR ride when I expected ZX-12R-like braking performance on a downhill run
![]() I also did the steel-braided brake lines and went with green front pads and black rear pads. All I need to do is set up my front suspension with better springs and oil so that it doesn't DIVE so much under braking
"...your actual smileage may vary..." |
08-14-2007, 10:30 AM
#6 | |
Oddometer: 8,040
How much do you weigh? I could bottom out the stock suspension at will with the original brakes. With the new 320mm oversized rotor, if you are anything over 160 pounds you must easily now be able to bottom it out, which under hard emergency braking is a safety issue I'd be concerned about as you don't have control over the bike. You've been running like this for a "few years" ????? |
08-14-2007, 11:55 AM
#7 |
What if its a Samsquamch?
Oddometer: 7,715
LC8World.com - KLRWorld.com Forums - Nighthawk Forums "Life's an adventure, and I refuse to live a boring one." |
08-14-2007, 12:23 PM
#8 |
KLR-riding cheap bastard
Oddometer: 7,439
Fred usually has EXCELENT customer service... sometimes you'll hear a complaint, but that's the exception, not the rule.
i've been hearing a LOT of complaints about Dual-Star in the past year or so. they get LOW marks for customer seervice. KLR650.com sells a lot of products that are rip-off clones of the original products, or just lower grade stuff in general. ronayers.com has OEM parts at discounted prices, but can be SLOW to ship. bikebandit.com also has OEM parts at discount prices... not sure about their shipping for parts, but i've ordered oil and air filters from them and gotten good service.
Sit tall in the saddle, Hold your head up high Keep your eyes fixed where the trail meets the sky And live like you ain't afraid to die And don't be scared, just enjoy your ride. "... in my version of Heaven you get all your dogs back." – Mista Vern "Old dogs don't die, they just wait for you in another place." – Twilight Error I'll show you a place, high on a desert plain, where the streets have no name. |
08-14-2007, 12:27 PM
#9 |
Oddometer: 42,601
Arrowhead is the place.
Right part, right now. I went with the oversized Wave Rotors on both my KLRs, never been happier with my KLR brakes. Plus, they look extra cool. Thanks CA Stu
http://www.youtube.com/watch?v=C6cxNR9ML8k |
08-14-2007, 12:28 PM
#10 | |
Oddometer: 120
6'1"/250lbs of cheerful Samoan-like quality
08-14-2007, 01:01 PM
#11 | |
Oddometer: 8,040
I find this amazing, sorry but I do. If you can only fix one thing, I'd be on the front suspension before the brakes, but ideally both should be done at the same time. Springs/oil are cheap once you've plonked down the $$$ for the brake kit. |
08-14-2007, 01:20 PM
#12 | |
Oddometer: 42,601
I fail to see how a bottomed out suspension locks the front wheel in a straight line in the first place? Also, I'd rather countersteer OR brake in an emergency, not both at the same time. But, what do I know.... Thanks CA Stu
08-14-2007, 01:46 PM
#13 | ||
Oddometer: 8,040
08-14-2007, 01:49 PM
#14 | |
Oddometer: 42,601
Thanks CA Stu PS Do you own a KLR?
08-14-2007, 01:55 PM
#15 | ||
Oddometer: 8,040
crazybrit screwed with this post 08-14-2007 at 02:03 PM |
